Google Calendar Tab - Canadian TV, Computing and Home Theatre Forums
Old 2011-11-30, 08:34 AM   #1
JamesK
Default Google Calendar Tab
I recently found a nice calendar add-on for Thunderbird called "Google Calendar Tab". It adds Google Calendar to Thunderbird and looks & works just like it does when you use a browser for the calendar. I've tried it on both Linux & Windows versions of Thunderbird.
The following program contains immature subject matter.
Viewer discretion is advised.
JamesK is online now
Old 2011-11-30, 10:04 AM   #2
eljay
Premium Supporter
I've been using the Calendar tab in Thunderbird for a number of months and I really like it. It reminds me of the Calendar function in MS Outlook - which I use quite a bit at work - and, IMO, it's much better than the last Thunderbird calendar add-on (Sunbird?) I tried.
-- Edit --
I just checked and what I have isn't the Google calendar plug-in, it's the Lightning 1.0 Calendar extension for Thunderbird. The assessment remains the same.
MY HT SET-UP (PICS & GEAR LIST)
eljay is offline
Old 2011-11-30, 06:19 PM   #3
insider22
Or you can use the calendar online by accessing gmail.com
insider22 is offline
