#16 |
Mpeg 4 has better compression, that is why they will have more bandwidth at the end of the day. Having said that, once again Eastlink is over stating what they have accomplished. Yes they have introduced Mpeg 4, but not to all HD channels, in fact they have only converted a few Mux's and have a substantial way to go.
#17 |
I take it that the new boxes are also backwards MPEG2 compatible.
#18 |
Yes they are.
#19 | |
#20 |
Ok, got the new unit today; A DCX3400-M. Little problem I hope you can help me with. I can change channels just fine, however the DVR part of it such as pausing and rewinding live TV isn't working. It's as if it's simply working as a receiver.
#21 |
How long has it been plugged in for? How much of the guide is loaded? I know it can take a good number of minutes before certain things start functioning. I would try power cycling it again. Failing that, you could have a bad unit. Call them before trying to exchange it.
Just a side note, when I first got my 6416 swapped for a 3400, I had no channels authorized, not even TVO on channel 2. Turns out it was how the CSR at the retail outlet added them to my account when switching them. My DCX700 was listed "before" the 3400. The tech fixed it on his handheld device then voila, everything was fixed. Was it brought to your house or did you pick it up yourself? |
#22 |
Been pretty much plugged in all day now. Made me wonder if perhaps they had locked the mode out. I tried it both on the DVR's remote and the Harmony we have, and same deal. There's simply no response from those buttons/commands. Brought it to our house ourself, although we did talk to a technician in getting things started, but that was before I realized there was a problem.
#23 |
If you haven't done it already, I'd be calling their tech support. Sounds odd. It could even be something like a data cable not plugged into the drive. I've seen it on new PCs out of the box. Regardless it should be swapped out. I'm curious as to what happens if you try to set up a recording through the IPG?
#24 |
Something else I just though of....when they switch to MPEG4 for all the HD channels, will the recordings on our DVRs be smaller in size too since it is compressed more?
#25 |
Turns out it needed a simple reboot. I guess it wasn't initializing correctly. Odd that it would be like that right on first boot though. As for recordings, when it wasn't working right, it would allow me to record, but then when trying to play them back, it would throw an error message to the effect of saying "Check your main DVR." Err well, it is the main DVR lol. Guess it has something to do with permissions and the fact that it wasn't initializing correctly. The multi-room DVR capabilities seem to have thrown in a few extra problems that the old grey boxes didn't have. All good now though
Interesting thing to note is initially, likely due to it not being initialized correctly, it was giving me 1080p as default, but the picture wasn't as great as it is now when using 720p. I think something was also messed up giving me not that great a picture. Much sharper now. |
#26 |
Good to hear.
#27 | |
#28 |
I'll take my last post in this thread back.
My dilemma... On my DCX3400 when recording SD and MPEG2 HD, the recordings will play, FF, REW, and delete just fine. MPEG4 channels are another story. Extremely choppy and nearly freezing when FFing or rewinding, then hit Play and I'm minute or so further than I should be. In short, I'm just better off not skipping the ads. As for the deleting the recording part, if the current tuner is set to an MPEG4 channel and I delete an MPEG2 recording, the box is locked for a good 10 seconds before it continues on. Even the remote indicator on the front of the panel sticks on during this time. If the recording matches the current tuner as in MPEG2 Or MPEG4 - no problems. Now, with the HD conversion to MPEG4 here in Timmins which is happening very soon, I'm worried that this DVR is going to be worthless. Has anyone in a full MPEG4 environment had theses issues? My DCX3400 is connected to my TV via HDMI. The current software on the DCX is 78.54-a28p4.1005.r-6 and the firmware is 24.29. I'm curious if this is the same in other parts of their territory. I've power-cycled this thing numerous times, makes no difference. I have numerous recordings that I don't really want to lose but if I have to I will bring it in to get replaced. I just want to do in case this is "normal". |
#29 |
Mines doing the exact same thing. Hard to fast forward when it seems to jump 5 minutes ahead at times. Have you noticed sometimes when you fast forward it seems to go back and forth in jerky movements.
#30 |
YES!!!
I've only ever seen that effect when recording on CBC Montreal (616) I've seen different types of wonky performance on MPEG4 channels. MPEG2 is fine. Viewing the channel live, it's perfect.Clarifying the last sentence in my previous post... "I just don't want to bring it in for a replacement if this is considered normal." I'd reset the box myself but can't find info on how to do it with this model. Everything I've found is for the DCT64xx series. |
| Tags |
| eastlink, motorola, mpeg 4 |
