Using an FTA Receiver with a Bell expressvu DISH - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2004
Old 2004-08-07, 04:03 PM   #1
rightoussoul
Default Using an FTA Receiver with a Bell expressvu DISH
I am in the process of purchasing a FTA reciever i wanted to know, can i use a BELL EXPRESSVU dish to hook up the FTA reciever. i also want to get a bell reciever so i wanted to know do i need to buy 2 dishes or one will be enough to hook both of them up with the same dish. Wether yes or no PLEASE GIVE me advise as to what i should do to get the best quality..
thanks :lol:
rightoussoul is offline
Old 2004-08-07, 05:05 PM   #2
ken0042
Premium Supporter
I really don't think it will work. From what I can tell the FTA channels are on several different satellites. Aiming the dish requires presicion; a centimetre out and you lose the signal. The satellites are scattered across the sky. From what I can see the FTA dishes are a lot larger to make up for this.
The Bell dish is fixed; always pointing at the same satellites.
ken0042 is offline
Old 2004-08-07, 08:22 PM   #3
peano
A motorized dish is the way to go for FTA. There are only two FTA channels on BEV's 91 and they are promotional channels.
peano is offline
Old 2004-08-09, 07:00 AM   #4
etlam34
Default Bell FTA
All audio channels are FTA on Nimiq 1 and 2 (BEV satellites).
etlam34 is offline
Old 2004-08-09, 12:59 PM   #5
I_Want_My_HDTV
You probably want the 33" or 36" dish with LNB and SG 2100 DiSEqC 1.2 motor from here.
I_Want_My_HDTV is offline
Old 2004-08-09, 01:43 PM   #6
Diamond
I do believe you need a superdish for that to work properly.
5900 on Sony Trinton 24 inch
6100 on Samsung 53 DLP
9200 on Sony KV34XBR910
Diamond is offline
Old 2005-01-05, 04:53 PM   #7
tdti1
thanks :lol:
Use the bell dish for bell, The lnbf for bell will not work on the other satellites, you will need a larger dish 90cm or 120cm is good with a motor for ku-band fta.
tdti1 is offline
Old 2005-01-21, 09:01 PM   #8
carl
Thumbs down
...except for all of the CBC Galaxie stuff, which *was* FTA until about half a year ago and is now Nagra-encrypted.
carl is offline
Old 2005-01-25, 11:32 PM   #9
CBProd
im using the regular bell dish to on my pansat receiver. works perfectly even with the bell lnb. but i replaced the lnb, to a dishpro quad. so i can pull in 91 and 82. theres a internal switch in the lnb, so a diseqc switch is not needed.
CBProd is offline
Old 2005-01-26, 09:50 AM   #10
ken0042
Premium Supporter
CBProd- what satellites are you picking up with your set up; besides the Bell ones you mention?
ken0042 is offline
Old 2005-01-26, 06:04 PM   #11
CBProd
92, 81, 119 and 110.
92 and 81 are on coming in on 1 dish, and 119 and 110 have seperate dishes. then all three end up going into a diseqc switch.
CBProd is offline
