NAS Recommendations - Canadian TV, Computing and Home Theatre Forums
Old 2011-11-01, 06:40 PM   #1
QuickSilver
Default NAS Recommendations
I currently run an Acer Easystore with WHS as the OS. It's sole purpose is to be my NAS. I do not use any of the WHS features for backups, iTunes server, etc. It has shared folders that server my ripped media. Ranging from 5-7gb MKV rips of my movies, DIVX rips of my old DVD's and some odd TV shows that Bell does not show.
I am considering moving away from it as it has begun to show signs of its age. Multiple shutoff's for no reason and freezing.
The NAS would serve:
  • Mac Mini running Plex
  • Apple TV 2 running XBMC
  • iMac (Plex Client)
  • Apple TV 1st Gen for Bedroom
I am looking for recommendations for a replacement. I have been looking at a few products but was wondering what you run for a NAS if you do.
My budget is $300.00 - $500.00
RAID is a plus. I love how the WHS allows drive addition.
Low Power consumption would be nice.
QuickSilver is offline
Old 2011-11-02, 10:17 AM   #2
Tikker
you're not really going to find simple drive addition for a low cost these days
that being said, as a simple NAS solution for media storage/streaming you can go with pretty much anything
lots around here have had relatively good luck with the dlink 323's
qnap makes good NAS
I've got a couple of Linksys NAS units that I've played with over the years
IMO I still prefer to build a low power machine on my own, pair it with my OS of choice, and run a full fileserver, rather than a NAS.
Tikker is online now
Old 2011-11-02, 10:35 AM   #3
hugh
Which 4-Bay NAS Enclosure would you buy might be of interest to you.
If you just want 2 bays then the D-Link units for under $150 seem to make an excellent choice. I have had my Dlink DNS-323 NAS running for years serving up files without a problem.
I have yet to buy my 4 bay (just haven't had the time) but hope to in the next month or two.
hugh is offline
Old 2011-11-02, 11:09 AM   #4
QuickSilver
Thanks. That link is helpful not sure it missed it when I searched I really need 4 bays as I currently have 3X1TB drives in my 340.
Old 2011-11-04, 12:53 AM   #5
jeneral
If you're technically savvy, you may want to consider replacing the power supply in your Easystore. Overheating (unlikely unless a fan is dead) or a weak power supply (more likely) could be the culprits for the issues you are having. The freezing could be due to bad sectors on your hard disks. Check the event viewer for any errors. Good luck.
jeneral is online now
Old 2011-11-04, 01:40 AM   #6
HDTV101
I'd setup a Linux box running a software RAID. Run a cron job to rsync your backups... the nice thing about rsync is incremental backups... only changing what has changed in the backup directory. Build a cheap system using a tower case... you'll have lots of room for the 8gb's worth of RAIDed hard drive space!
HDTV101 is offline
Old 2011-11-04, 12:10 PM   #7
WarrenC12
I'll toss in a vote for FreeNAS if you're comfortable with some tinkering. I built one recently with an old chassis and a RocketRAID 1740 SATA card I bought used for $50.
It's a great flexible solution, and allows you to run things like a BT client, DLNA server or other apps without jumping through excess hoops.
WarrenC12 is online now
Old 2011-11-04, 12:31 PM   #8
QuickSilver
Well I am not sure at this point what type of specifications I would need if I were to build one myself. As per my original post in regards to how my media is accessed it would seem to me that my devices only need direct file access to the system. I would think very little processing power is needed in my situation.
Old 2011-11-04, 12:35 PM   #9
hugh
Yeah, a 2 or 4 bay NAS is all you need. Its cheap and there is no muss and fuss.
hugh is offline
Old 2011-11-04, 12:37 PM   #10
QuickSilver
So the spec's really don't matter? The easystore had 2gb of ram and an Atom processor.
Old 2011-11-06, 09:50 AM   #11
Tikker
For simple file streaming where the end device does all the heavy lifting you don't need much horsepower at the server/nas end
My original file server was based on a celeron 400 with less than 1gb of ram.
Only reason to beef up the fileserver is if you want to do stuff on it
Rip/encode movies. Torrent. Etc
Old 2011-11-06, 10:19 AM   #12
NeilN
Just check out the max bandwidth speed. For example the DNS-323 is a gigabit NAS but can only stream max ~17 megabytes/sec as it's limited by the processor.
NeilN is online now
Old 2011-11-06, 01:46 PM   #13
markf
I've mentioned this in other threads, but if all you need is a file server, you can use an older laptop running Linux. I have an old Pentium M 1.3 GHz, with 256 or 512 MB RAM with drives hooked up externally. The laptop was run over by a car, so the screen is cracked and the keyboard is broken, but for the few times I've ever needed to configure it directly on the machine (and not through Webmin), I just hook up a keyboard.
So if you pick up an old cheap laptop (very power efficient vs a tower), install Linux on it and hook your drives up through USB (there are 2 and 4 bay external enclosures well within your budget, and you can always add as you need) you may be able to create a custom solution.
May not be your thing, but I'm very happy with this in my setup.
markf is offline
Old 2011-11-06, 05:57 PM   #14
QuickSilver
I am looking at the QNAP TS-412. It is fairly low on the spec list as only having 256mb of ram. I also need to find out if it will run with my 3 WD Green 1TB drives.
I have immediate plans to do anything on whatever NAS I do end up purchasing in terms of processing downloads, database, etc. I do not it to handle largish (7-10)gb MKV files to my mini and the Apple TV. My home network is full gigabit.
Old 2011-11-07, 07:17 AM   #15
DentedMarble
I'll throw my hat in. The QNAP's are really nice pieces of hardware from what I have seen.
Having said that I second the vote for a home built LINUX server. This is what I use and it serves well and has room for expansion both in function as well as hard drives.
Off the shelf NAS' are going to be limited by what apps are available. For the cost of a WNAP it'd be a shame to have spent that kind of money only down the road to find out you'd wish you had more functionality.
DM
DentedMarble is offline
