I have the following antennas and can give exact measurements to .001" if required of every piece.
91XG MXU59 CM3023 CM4228HD CM4228 original I am seeing NEC models predicting results based upon assumed measurements. I honestly don't trust them. If anyone has the time to model with true measurements, I would be happy to provide them. |
#2 | |
Ken Nist had the 91XG and the original CM4228a in front of him when he modeled them, so they should be very accurate.
I think Holl_ands has the actual CM4228HD. You can easily check the measurements of the NEC files with the steps Ive outlined here: http://www.digitalhome.ca/forum/showthread.php?t=107457 But it would be great to have precise measurements of the MXU59 and the CM3023. Quote:
I KNOW that there are (at least) two, physically quite different, OFFICIAL versions
of the CM4221 and the YA-1713....and there may be others.... Since there are so many variations of the 91XG available from various overseas sources, it is possible that they might have physical differences from year to year, so it's worth double checking against Ken Nist's measurements. In nearly every model, we also perform an approximation to the ACTUAL shape of the X-Bows, the shape of the Folded Dipole and other details that "shouldn't" make a difference. Models for CM4221 posted on http://imageevent.com/holl_ands/multibay/4bayrefl were based on 1) ACTUAL dimensions from mclapp, which were significantly DIFFERENT than 2) Ken Nist's cm4221a.ez file posted on http://www.hdtvprimer.com/SIMS/. Model for CM4221HD was based on actual measurements found in smpowell55's posts. My posted 4nec2 models for the fol. antennas are based on my actual measurements: YA-1713, CM4228 and CM4228HD. In each of the other 4nec2 models I've posted, I noted who provided the actual measurements, when appropriate, as well as who prepared the original 4nec2 file if it was someone else. I also describe MY various modifications needed to correct for AGT=1, eliminate/reduce Errors & Warnings and adding my usual set of FR & RP Cards to avoid "fat finger" entry errors. There is no need to be any more accurate than 0.1-inch (or 2.5 mm if you prefer) in element length measurements, since you won't see the difference (under 0.2 dB). I routinely round off GeoEdit output files to just two decimals (which is still overkill) so that I can align all of the data columns to better "see" errors or problem areas. However, for radius measurements, a caliper should be used....or compare to known wire or drill sizes. Thus far, we're missing accurate measurements for MXU59, CM-3023 & HD9095P. I'm also looking for detailed measurements for ANT-2086 4-Bay Bowtie. In all cases we need detailed PHOTOS of the overall antenna as well as close-in shots for the more complicated areas, such as the X-Bows and Feedline connections. ========================================================== PS: If you look at Ken Nist's w9032a.ez model for the PR-9032, you'll see that he "simplified" the Folded Dipole and surrounding Boom Area....and used two parallel (NOT interconnected) wires for each Passive Director (I would have connected, at least, the ends and middle). The small wires in his Folded Dipole & Boom Area may cause problems using the NEC2 Engine, esp. if using one of the Single-Precision "Nec2dXS*.exe" (large number of segments) versions that I am forced to use for many antennas (e.g. Screen Grid Reflectors). The default 4nec2 Engine is the Double-Precision "Nec2dX*.exe" Engine. Ken Nist used (Quad-Precision) NEC4 Engine. |
I will provide detailed measurments and photos ot the CM3023 to start.
Yeah, even wire gauge diameter isnt consistent to .001 inches over its length Ive found with my digital caliper.
And theyre not that precise at the antenna factories either. One way to notice the imprecision is to measure from the end of the boom to the exact center of the rivets on the top of the boom and then compare to the measurements from the end of the boom to the exact center of the rivets on the bottom of the boom. Shifts of 1/16" to 1/8" on the same antenna are quite common.
AWG10 has 0.1019-in and AWG12 has 0.0808-in diameter, a 26-percent difference
that causes a small but obvious difference in Gain and esp. SWR performance. A 5-percent accuracy (0.005-in in the above case) should be more than enough and 5-percent accuracy for thicker 3/8-in elements would be about 0.02-in. Of course if you can simply hold a "known" AWG10 and/or AWG12 wire (or drill) next to the feedline, it should be obvious which is the correct gauge...and hopefully no one is using odd-ball gauges.... |
#7 | |
http://www.hdtvprimer.com/ANTENNAS/comparing.html ![]() If so, we have that model here: (Sorry, didnt catch it earlier) Code:
CM CM4248 : Channel Master 4248, converted with 4nec2 on 10-Jul-08 2:25 CM AGT = 1.0 (0 db) at 585 mhz. Autosegmentation = 21 CE GW 8 1 7.2 1.125 -0.8 7.35 1.4 -0.8 0.05 GW 9 1 7.35 1.4 -0.8 7.45 1.7 -0.8 0.05 GW 10 3 7.45 1.7 -0.8 7.45 3.15 -1.07 0.05 GW 11 3 7.45 3.15 -1.07 7.45 4.6 -1.33 0.05 GW 12 3 7.45 4.6 -1.33 7.45 5.25 0 0.05 GW 13 3 7.45 5.25 0 7.45 4.6 1.33 0.05 GW 14 3 7.45 4.6 1.33 7.45 3.15 1.07 0.05 GW 15 3 7.45 3.15 1.07 7.45 1.7 0.8 0.05 GW 16 3 7.45 1.7 0.8 7.45 0.88 0.8 0.05 GW 17 1 7.45 0.88 0.8 7.45 0.38 0.8 0.05 GW 18 1 7.2 1.125 -0.8 7.05 1.4 -0.8 0.05 GW 19 1 7.05 1.4 -0.8 6.95 1.7 -0.8 0.05 GW 20 3 6.95 1.7 -0.8 6.95 3.15 -1.07 0.05 GW 21 3 6.95 3.15 -1.07 6.95 4.6 -1.33 0.05 GW 22 3 6.95 4.6 -1.33 6.95 5.25 0 0.05 GW 23 3 6.95 5.25 0 6.95 4.6 1.33 0.05 GW 24 3 6.95 4.6 1.33 6.95 3.15 1.07 0.05 GW 25 3 6.95 3.15 1.07 6.95 1.7 0.8 0.05 GW 26 3 6.95 1.7 0.8 6.95 0.88 0.8 0.05 GW 27 1 6.95 0.88 0.8 6.95 0.38 0.8 0.05 GW 28 1 7.45 1.7 -0.8 6.95 1.7 -0.8 0.05 GW 29 1 7.45 3.15 -1.07 6.95 3.15 -1.07 0.05 GW 30 1 7.45 4.6 -1.33 6.95 4.6 -1.33 0.05 GW 31 1 7.45 5.25 0 6.95 5.25 0 0.05 GW 32 1 7.45 4.6 1.33 6.95 4.6 1.33 0.05 GW 33 1 7.45 3.15 1.07 6.95 3.15 1.07 0.05 GW 34 1 7.45 1.7 0.8 6.95 1.7 0.8 0.05 GW 35 1 7.45 0.88 0.8 6.95 0.88 0.8 0.05 GW 36 1 7.45 0.38 0.8 6.95 0.38 0.8 0.05 GW 37 1 6.95 0.88 0.8 6.25 0.88 0.8 0.05 GW 38 3 6.95 0.38 0.8 5.95 0.38 0.8 0.05 GW 39 1 5.95 0.38 0.8 5.95 0.58 0.8 0.05 GW 40 1 5.95 0.58 0.8 6.25 0.88 0.8 0.05 GW 41 5 5.95 0.38 0.8 4.2 0.38 0.8 0.05 GW 42 5 5.95 0.58 0.8 4.2 0.58 0.8 0.025 GW 43 1 4.2 0.38 0.8 4.2 0.58 0.8 0.025 GW 44 3 4.2 0.38 0.8 2.95 0.38 0.8 0.025 GW 45 3 4.2 0.58 0.8 2.95 0.58 0.8 0.025 GW 46 1 7.2 -1.125 -0.8 7.35 -1.4 -0.8 0.05 GW 47 1 7.35 -1.4 -0.8 7.45 -1.7 -0.8 0.05 GW 48 3 7.45 -1.7 -0.8 7.45 -3.15 -1.07 0.05 GW 49 3 7.45 -3.15 -1.07 7.45 -4.6 -1.33 0.05 GW 50 3 7.45 -4.6 -1.33 7.45 -5.25 0 0.05 GW 51 3 7.45 -5.25 0 7.45 -4.6 1.33 0.05 GW 52 3 7.45 -4.6 1.33 7.45 -3.15 1.07 0.05 GW 53 3 7.45 -3.15 1.07 7.45 -1.7 0.8 0.05 GW 54 3 7.45 -1.7 0.8 7.45 -0.88 0.8 0.05 GW 55 1 7.45 -0.88 0.8 7.45 -0.38 0.8 0.05 GW 56 1 7.2 -1.125 -0.8 7.05 -1.4 -0.8 0.05 GW 57 1 7.05 -1.4 -0.8 6.95 -1.7 -0.8 0.05 GW 58 3 6.95 -1.7 -0.8 6.95 -3.15 -1.07 0.05 GW 59 3 6.95 -3.15 -1.07 6.95 -4.6 -1.33 0.05 GW 60 3 6.95 -4.6 -1.33 6.95 -5.25 0 0.05 GW 61 3 6.95 -5.25 0 6.95 -4.6 1.33 0.05 GW 62 3 6.95 -4.6 1.33 6.95 -3.15 1.07 0.05 GW 63 3 6.95 -3.15 1.07 6.95 -1.7 0.8 0.05 GW 64 3 6.95 -1.7 0.8 6.95 -0.88 0.8 0.05 GW 65 1 6.95 -0.88 0.8 6.95 -0.38 0.8 0.05 GW 66 1 7.45 -1.7 -0.8 6.95 -1.7 -0.8 0.05 GW 67 1 7.45 -3.15 -1.07 6.95 -3.15 -1.07 0.05 GW 68 1 7.45 -4.6 -1.33 6.95 -4.6 -1.33 0.05 GW 69 1 7.45 -5.25 0 6.95 -5.25 0 0.05 GW 70 1 7.45 -4.6 1.33 6.95 -4.6 1.33 0.05 GW 71 1 7.45 -3.15 1.07 6.95 -3.15 1.07 0.05 GW 72 1 7.45 -1.7 0.8 6.95 -1.7 0.8 0.05 GW 73 1 7.45 -0.88 0.8 6.95 -0.88 0.8 0.05 GW 74 1 7.45 -0.38 0.8 6.95 -0.38 0.8 0.05 GW 75 1 6.95 -0.88 0.8 6.25 -0.88 0.8 0.05 GW 76 3 6.95 -0.38 0.8 5.95 -0.38 0.8 0.05 GW 77 1 5.95 -0.38 0.8 5.95 -0.58 0.8 0.05 GW 78 1 5.95 -0.58 0.8 6.25 -0.88 0.8 0.05 GW 79 5 5.95 -0.38 0.8 4.2 -0.38 0.8 0.05 GW 80 5 5.95 -0.58 0.8 4.2 -0.58 0.8 0.025 GW 81 1 4.2 -0.38 0.8 4.2 -0.58 0.8 0.025 GW 82 3 4.2 -0.38 0.8 2.95 -0.38 0.8 0.025 GW 83 3 4.2 -0.58 0.8 2.95 -0.58 0.8 0.025 GW 84 69 1.49 16.65 1.94 1.49 -16.65 1.94 0.125 GW 85 69 3.35 16.65 4.36 3.35 -16.65 4.36 0.125 GW 86 69 5.21 16.65 6.77 5.21 -16.65 6.77 0.125 GW 87 69 7.07 16.65 9.19 7.07 -16.65 9.19 0.125 GW 88 69 9.81 16.65 12.75 9.81 -16.65 12.75 0.125 GW 89 69 12.55 16.65 16.32 12.55 -16.65 16.32 0.125 GW 90 69 15.29 16.65 19.87 15.29 -16.65 19.87 0.125 GW 91 69 1.49 16.65 -1.94 1.49 -16.65 -1.94 0.125 GW 92 69 3.35 16.65 -4.36 3.35 -16.65 -4.36 0.125 GW 93 69 5.21 16.65 -6.77 5.21 -16.65 -6.77 0.125 GW 94 69 7.07 16.65 -9.19 7.07 -16.65 -9.19 0.125 GW 95 69 9.81 16.65 -12.75 9.81 -16.65 -12.75 0.125 GW 96 69 12.55 16.65 -16.32 12.55 -16.65 -16.32 0.125 GW 97 69 15.29 16.65 -19.87 15.29 -16.65 -19.87 0.125 GW 98 13 12.47 2.86 0 12.47 -2.86 0 0.035 GW 99 13 18.04 2.86 0 18.04 -2.86 0 0.035 GW 100 13 23.61 2.86 0 23.61 -2.86 0 0.035 GW 101 13 29.18 2.86 0 29.18 -2.86 0 0.035 GW 102 13 34.75 2.86 0 34.75 -2.86 0 0.035 GW 103 13 40.32 2.86 0 40.32 -2.86 0 0.035 GW 104 13 45.89 2.86 0 45.89 -2.86 0 0.035 GW 105 13 51.46 2.86 0 51.46 -2.86 0 0.035 GW 106 13 57.03 2.86 0 57.03 -2.86 0 0.035 GW 107 13 62.6 2.86 0 62.6 -2.86 0 0.035 GW 108 13 68.17 2.86 0 68.17 -2.86 0 0.035 GW 109 13 73.74 2.86 0 73.74 -2.86 0 0.035 GW 110 13 79.31 2.86 0 79.31 -2.86 0 0.035 GW 111 13 84.88 2.86 0 84.88 -2.86 0 0.035 GW 112 13 12.87 2.86 0 12.87 -2.86 0 0.035 GW 113 13 18.44 2.86 0 18.44 -2.86 0 0.035 GW 114 13 24.01 2.86 0 24.01 -2.86 0 0.035 GW 115 13 29.58 2.86 0 29.58 -2.86 0 0.035 GW 116 13 35.15 2.86 0 35.15 -2.86 0 0.035 GW 117 13 40.72 2.86 0 40.72 -2.86 0 0.035 GW 118 13 46.29 2.86 0 46.29 -2.86 0 0.035 GW 119 13 51.86 2.86 0 51.86 -2.86 0 0.035 GW 120 13 57.43 2.86 0 57.43 -2.86 0 0.035 GW 121 13 63 2.86 0 63 -2.86 0 0.035 GW 122 13 68.57 2.86 0 68.57 -2.86 0 0.035 GW 123 13 74.14 2.86 0 74.14 -2.86 0 0.035 GW 124 13 79.71 2.86 0 79.71 -2.86 0 0.035 GW 125 13 85.28 2.86 0 85.28 -2.86 0 0.035 GW 126 5 7.2 -1.125 -0.8 7.2 1.125 -0.8 0.0216 GS 0 0 0.0254 ' All in in. GE 0 EK LD 5 0 0 0 2.5e7 0 EX 0 126 3 0 1 0 GN -1 FR 0 1 0 0 585 0
Looks like it. Ok MXU59 it is.
#9 |
Right now, the CM4248 (3023) peaks at channel 62. The corner reflector on it is still an excellent size for the new uhf range as is. And I believe the driven element on it peaks at channel 23 when modeled by itself. To make it peak at say channel 46, all that would be needed is some rescaling of the directors and their spacings.
Heres another site that references the CM4248 and the CM3023 as the same thing. http://www.interceptradio.com/wiki/index.php/TV_Antenna
#10 |
Do we have side-by-side comparisons of NET gain for these three antennas?
** Thus far, we're missing accurate measurements for MXU59, CM-3023 & HD9095P. ** Which of these have the best low UHF net gain (say, RF 32 and lower)? |
#11 |
Several years ago I was told that Antennacraft used aluminum wire with a diameter of 0.11" for the phasing lines in their FM log-Yagis. Their engineers called it eleven-wire. I learned this from someone who had Antennacraft manufacture FM antennas for him.
Brian |
#12 |
That would be AWG9 (d=0.1144-in), a mere 10-percent larger than AWG10.
Yup, d=0.11-in for all three of K6STI's AntennaCraft FM-6, FM-10 & FM-13 models: http://www.ham-radio.com/k6sti/ I found d=0.11-in (r=1.45-mm) in 300ohm's 4nec2 model for the A-C U8000 UHF 8-Bay Bowtie and I found d=0.12-in (r=0.06) used in tripelo's 4nec2 model for A-C Y10-7-13 Hi-VHF Dual-Driven Yagi, which he probably rounded off from the actual r=0.0572-in. [PS: Values vary a bit between wire tables.] So AntennaCraft appears to be consistently using r=0.0572-in (AWG9) feedlines across (at least) FM, Hi-VHF and UHF frequency bands. |
#13 |
Gee, I wonder why the Antennacraft guys referred to it as eleven-wire if it was really AWG 9? But I'll bet you're right. I'd use 0.1144" in my models instead of 0.11" if I were absolutely sure. I wonder if anyone at Antennacraft would answer a question. (I've asked for antenna dimensions on the Winegard forum, and the company won't give them out.)
Incidentally, here is an exact formula to convert American Wire Gauge to wire diameter: Code:
D = .005 * 92 ^ ((36 - G) / 39) Brian |
#14 |
300 ohm, You said that by "rescaling of the director and their spacings" of a cm3023 that it could be made to peak at a lower channel. Could you give the dimensions to peak at channel 44? Also could the gain be increased by adding more boom with directors and spacings of the same dimensions? Thanks.
#15 | ||
Directors follow the laws of marginal utility. That is the first few produce a very good increase in additional gain. The second few, not so much. The third few produce even less. With 14 directors already, youll probably need another 7 with a 3+ ft increase in boom length to produce an additional db in gain. That makes for a long antenna, heh.
