I have a recreation property/cabin I'd like to set up some automation / remote control capabilities for the thermostat ,and would appreciate any suggestions from others that have successfully accomplished this cost savings alternative.
I have internet and wifi... My wish list for capabilities: - control heating, also hopefully temp sensors (to handle internal temp and external) It seems like the simplest would be a system that I could log onto and see the info and make the changes then access through a normal web interface, allowing me to use things like IP cameras. Love to get some suggestions and recommendations, for the overall problem or just for any of the products Thanks! |
Yep, they certainly are available along with temperature sensors, water sensors, CO detectors, IP cameras and so on.
Do you have a broadband internet connection at your cabin? Probably can search this forum (and of course Google) for some ideas.
I have a Control4 system for HVAC, lighting and a few other things. It can do this and more including door sensors, lighting, remote locking and unlocking. The only issue is that it may be more than you are looking to spend - very bare minimum would be $1000 and likely much more, and you have to get everything through a dealer.
IP cameras are relatively cheap to set up and access. For monitoring, something as simple as putting a thermostat/thermometer and other sensors within easy view of an IP cam might be sufficient. Some of the pricier IP cams have remote control capabilities but it's cheaper to set up a couple of fixed units. I wouldn't bother with remote control for heat. An ordinary programmable thermostat should be sufficient.
For just HVAC controls there is a company called ecobee that makes a wi-fi enabled thermostat that also has a web portal to monitor and schedule your HVAC system.
http://www.ecobee.com/product/smart-overview/
Cambridge, ON Rogers, SA 8300HD PVR, Panasonic TC-P42X2 TV, PS3, Yamaha RX-V671, Apple TV 2 |
Thanks for the information, I think for the most part, I'm really just in need of the thermostat I can control via the web via my WIFI that we have there!
Ken |
Try looking for Radio Thermostat CT-30. I picked up a version at Home Depot in the US for $100 (rebranded to Honeywell I think) and it works great over wi-fi. You can access it over the internet through their website or through iOS device with their app. For $100, couldn't really beat it.
If you're in Ontario and you can get into the Peaksaver program, you can get a free thermostat which you can program online.
It doesn't show real time data (in house temperature), but if you're away and a few hours from home, you can program it to warm up/cool down through an online portal. There are a number of online programming options. I find it a lot easier to program it online than through the interface. It is a rebranded Honeywell touch screen thermostat. |
#9 |
^^^^ doesn't this thermostat also mean that Hydro can step in and change your settings?
Update: I looked it up myself. peaksaver® is an electricity demand response program funded by the Ontario Power Authority (OPA) to ease critical strain on the electricity system in Ontario during hot summer weekdays. We are no longer accepting enrollments for the peaksaver® program. Check back for details about a new program offered by Hydro One in the coming weeks. Last edited by notsure; 2011-10-13 at 08:29 PM. Reason: Update |
#10 |
They can for a few hours at a time. I think it was activated 2 or 3 times this summer. That's the only time they activate the system and only when power demand is very high.
A free thermostat, $25 credit, I'm ok with a few times a year having the temp bumped up a couple of degrees. |
#11 |
+1 on control4. Recently installed a system for a customer in muskoka. Worry free system
#12 |
3m-50 filtret wifi thermostat
cm4228hd; kt-200, philips distro |
#13 |
Model # 3M-50 is being taken over by energy hub in the next month.
#14 |
For slightly more upside: Micasa Vera ($200 - $238) + z-wave enabled thermostat ($100 - 250) . A friend uses this to do thermostats for AC in FL rental and front door lock ($150 - $250)
For plug and play single use: google Nest Thermostat.... And enjoy! |
#15 |
It looks like it may be a while before the Nest thermostat is available here. Everything I've seen indicates they don't have enough (any?) stock in the US yet.
