Any EPG like XMLTV available for Fibe? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Bell Canada Enterprises (BCE) > Bell Fibe TV
Old 2011-10-08, 08:35 PM   #1
Just Bill
Default Any EPG like XMLTV available for Fibe?
I'm looking for EPG data for Fibe, so far I've found none.
Just Bill is offline
Old 2011-10-09, 10:26 AM   #2
Dr.Dave
Schedulesdirect.org provides a data feed licensed from Tribune Media Services via Zap2it.com for approved applications. Fibe TV is available in Zap2it.com, so it should also be in the XMLTV.
Dr.Dave is offline
Old 2011-10-09, 10:41 AM   #3
Just Bill
Thanks, I guess I need the Magic Postal Code then, because I could not find it. I'm using SageTV BTW, so that's why I wanted it.
I've remapped the Rogers channels to the Fibe Channels for now, but it was a painful process.
Old 2011-10-09, 11:01 AM   #4
Dr.Dave
If you have Fibe TV and are using Schedulesdirect, you can try some of the postal codes in this thread:
http://www.digitalhome.ca/forum/showthread.php?t=129867
I would think that any postal code that works for Zap2it.com should work for Schedulesdirect.
Dr.Dave is offline
