BSC 621 2D lnb w/ C and Ku outputs connected to switch's LNb1 and LNB2 inputs. Switch output runs to Sg2100 motor, then to Openbox S10 receiver.
Receiver is set to: C Band: 5150 22MHZ: off Diseq1: Port 1 Diseq1.2: disabled Diseq1.3: Motor Ku Band: 9150-10600 Universal 22MHZ: auto Diseq1: Port2 Diseq1.2: disabled Diseq1.3: Motor Results: No signal, no movement Set Diseq1.3 to USALS --> movement but limited signal since alignment is off (did pick up 20 music channels); the music transponder's signal is 70%quality. However, if I switch Diseq1.3 to MOTOR, signal drops to 29-30%. Any thoughts? Cheers, K |
