#286 |
Premium Supporter
I know they are trying to 'pre-provision' the boxes before installation in an effort to reduce install times and even possibly have a self-install option. Perhaps that is what happened in your case. That or there do seem to be a wide range of 'experiences' with how these units operate at any given location so it really could be hard to say.
Keep the reports coming though as we might be able to see a pattern emerge eventually.
If you want more then ask for it rather than going hungry. If you want more than I have then you should ask. They're going to park their car over there. |
#287 |
I'm sure I read this somewhere before but just did a search on Splitters and can't find the info. Can someone assist.
I have Shaw coming out to fix a Gateway installation issue. Think I have that fixed myself but we'll see. While the tech is out, should I ask them to replace my splitters? Not sure if the existing ones were installed by me or Shaw a few years ago. They only are rated up to 1GHz. We probably need to update the splitter/coax routing anyway. |
#288 |
My gateway installer replaced my 1 year old splitter with the same make/model splitter without asking. The splitter is not expensive when compared to a service call.
#289 |
Do you know if the splitter needs to be rated to > 1 GHz?
#290 |
no need for greater than 1Gz...the MoCa filter is a 1Ghz low pass filter (blocks everything above 1Ghz)
So that would imply that everything inside the MoCa network will be running under the 1Ghz frequency.. |
#291 |
The both splitters are rated between 5Mhz - 1GHz.
He replaced my 1-to-4 splitter with an 1-to-3 splitter. This splitter has two 7db outputs for my internet modem and the phone modem. The remaining 3db output is connected, thought a MoCA filter, to an 1-to-2 splitter. This gateway splitter has 3db input and outputs. I don't know why the gateway circuit uses 3db splitter and not 7db. |
#292 |
Those markings indicate losses from the input, so(in your case) the gateway is getting a bit higher signal.
#293 |
Sorry if this has been discussed before, but I could not find it. Where exactly does Shaw install the Gateway? I thought i read something before about it being in a mechanical room? I don't have that in my townhouse. If it needs to be near the Shaw access box, then that is in my garage. But it's freezing cold there now, or very hot in the summer.
I think i am confused. Someone please explain to me where it gets installed. Thanks! |
#294 |
The gateway can be installed anywhere in your home. You are right, hot and cold is not good for the hard drive.
#295 | |
#296 |
I would recommend placing the Gateway close to your cable modem if possible if you plan on making use of DLNA when that's enabled.
I'm not sure how this will work, but you'll either need to link them up or maybe even use the Gateway's built-in cable modem in place of your existing one. |
#297 |
Modems are always tough to deal with.
#298 |
The "exit" button on the Harmony will behave the same as the zoom button on the Shaw portal remote with that MP2000 configuration.
#299 |
Premium Supporter
The Gateway modem will not be activated, from what I understand, so you will still require a separate unit as we have now.
As GWNorth states, the 'Exit' button should be mapped to the 'Zoom' function on the Shaw remote. I just tested it on my Harmony that I set up with that same code load and it is this way.
#300 |
OK, thanks for the info. I'll just go with the default MP2000 load for now then tweak as I familiarize myself with Gateway/Portal interface functionality. U/G to BB50 and Gateway with 5 portals scheduled for Sunday...wish me luck!
