I was a Bell Expressvu subscriber a few years back when I had a Bell 9200 and 3100. I recently resigned with BellTV
Anyway, the existing dish is still installed and I was wondering when the Bell tech comes out Saturday afternoon if he will install a new twin DPP LNB and separator for the new 9141? If not can I request this or is Bell not installing these as standard? Cheers |
Well if you had the 9200 & 3100 there will most likely be an SW44 at the Dish, so he would most likely try to re-use that. Just have a word with him and he will or should use a DPP for you.
Thanks Pinza
I sold all my old Bell equipment including the SW44.... Only thing remaining is the dish and old LNB's. Maybe I'll climb up and remove the old LNB... Cheers |
If you can yes, that way he will go for the easiest route for him. Which should be DPP.
Did even better - removed the whole dish...
Cheers |
Oh that's cheating.....lol
Pinza,
Well he had to install the Legency LNB and SW44 becuase I had three received added to the account. If it was just the 4100 and 9141 - he would have done it. Oh well....no biggy. Cheers |
Again it is just crazy that Bell do not use the DPP switch's, this would have been so easy with a DPP44.
