Hi, I have a Samsung LCD TV that I got a year ago. I've had a problem ever since though. I've got a couple gaming consoles, Nintendo 64, & Sega Saturn, but I can't plug them into my TV because the TV lacks an S-Video input. I could buy composite cables for them, but s-video is better than composite. Does there exist some kind of adaptor I can buy that will let me plug in my s-video into the component, or HDMI?
thanks |
You can buy a S-Vid to component devices. Just google and you should find plenty of retailers who sell it.
No idea if it will make a big difference
I have. Maybe I'm blind or something but I don't see any. The ones appearing are 7 pin, when S-Video is 4 pin.
One other option is to run an A/V receiver that supports S-Video and will upconvert. My Yamaha RX-A1000 does that, although it's not the cheapest option. unfortunately most low-end receivers don't have S-Video anymore.
Just use composite - not much difference between the two, or run s-video to the TV with an S-video to composite adaptor.
I doubt that any additional device will "better" the signal since both are SD.
#6 | |
If you can't find an AVR with s-video, many of them upconvert composite to component (and newer ones to hdmi). It is worth pointing out that many AVRs will let you send composite/s-video inputs to Zone 2, allowing you to use multiple machines at once (on separate TVs). That said, it would probably be easier/cheaper to go the s-video->component adaptor (or s-video->hdmi) route, or just use composite. |
There are a couple of variants of S-video - one being the standard 4-pin version, but there is also a 7-pin variant which is pin compatible with the 4pin. So you can connect a standard 4-pin S-Video cable to the 7-pin connector and you should be fine.
S-Video is noticeably better than plain composite video. It's still SD but the colour separation is more accurate. I could easily tell the difference on my 27" Trinitron. On a bigger TV I suspect the difference would be even more pronounced.
How much money it's worth spending to be able to use it - that's another question. |
