MediaPortal 1.2.0 Released - Canadian TV, Computing and Home Theatre Forums
Old 2011-09-19, 01:58 PM   #1
ScaryBob
Default MediaPortal 1.2.0 Released
The free, open source HTPC media center for the technically inclined... some configuration and assembly required. MediaPortal 1.2.0 includes hundreds of bug fixes and a new skin.
Download MediaPortal here
ScaryBob is offline
Old 2011-09-19, 04:07 PM   #2
danbcman
So from the reading at the site it looks to me I can take a WinXp computer and instal this and the package should work.
danbcman is offline
Old 2011-09-19, 04:35 PM   #3
e268
I have used it in the past, and it was good (I think it was still the beta version 0.9 or something like that). Then I changed over to GB-PVR since I mainly use it for recording tv shows. Since I bought the Rogers STB PVR Sa8300, I have stopped using them. They are both good for winxp.
Yammy RXV2400 & CDC815, Celestion DL8 fr Mission 73Ci ctr Sansui rear Velodyne CHT8, Vaio TT180, i7-920@3.8Ghz
e268 is offline
Old 2011-09-19, 10:47 PM   #4
danbcman
Yea it installed real easy and directed me to the sites for additional needed files.
I how ever don't seem to be able to watch my ota in it I think I am not clear on what it really does, it did install nicely. I will make an image of it as it is tuned up to date and take it from there.
I did find the quick setup guide and in fact got the card configured and scaned and found all my OTA the one thing I am missing is where and how I just view the Tv in Media Portal
danbcman is offline
Old 2011-09-19, 11:04 PM   #5
ScaryBob
The TV server needs to be configured for watching TV. Channel scanning is required, even for analog channels. There are a number of other things that need to be configured for some cards, such as identifying hybrid tuners to prevent conflicts and guide services (not included.) Overall, MediaPortal has become quite a nice package but its strength is also its big drawback. Free means that things like guide or streaming services and some codecs are not included. It's abundance of features require a lot of configuration, which has a learning curve. The most difficult parts are configuring the TV server and codecs.
ScaryBob is offline
Old 2011-09-20, 12:25 PM   #6
danbcman
As much as I hate to say it it seems the weakest link in getting this going may be me
I am currently scanning anolog of which I expect to find none.
danbcman is offline
Old 2011-09-21, 06:08 PM   #7
Tikker
I used media portal for quite a while until I discovered Media Browser
no real complains about media portal once it was working
Media Browser was about 15 minutes from download to fully configured, media portal was many many hours to make it work properly
Tikker is offline
Old 2011-09-21, 06:13 PM   #8
Snake785
hmm...last time I tried MediaPortal I found performance to be very slow...I might give this one a try to see if it's any faster.
Snake785 is offline
Old 2011-09-26, 03:08 PM   #9
danbcman
Media Browser
Is functionally different than the Media Portal like comparing apples and oranges ?
danbcman is offline
Old 2011-09-26, 03:23 PM   #10
ScaryBob
I've had some time to use MediaPortal 1.2 now. The upside is that it seems faster than past versions. On the downside, reliability seems to have taken a hit compared to 1.1.
ScaryBob is offline
Old 2011-09-27, 10:04 AM   #11
Tikker
Originally Posted by danbcman View Post
Media Browser
MediaPortal and Media Browser are somewhat similar, except for the TiVo like portion (media browser doesn't do it)
as Media Browser is essentially a plugin for media center that interfaces with xml files to present your data in a pretty way (you need to already have media center)
media portal is basically media center, that presents your data in a pretty way
I imagine you could find skins for both to make them look virtually identical
Tikker is offline
