#61 |
It is I think the first 2 tuner version Silicondust made.
They can still be had on ebay too. HDHR-US is what it says on the unit and on the LAN. Oh and I have a 8 1/2 foot 1 inch tube from the broken VHF antenna I was pondering using for a really long UHF antenna using the corner reflector and dipole from my 3672. Not sure what it will do but I'm assuming it will have a really narrow beam with that long of a boom. I just haven't had time to get the a hang of 4nec to model it.
CM-4251, Modified CM-3672, Winegard AP-8780, Vizio VW46L, HDHomeRun (HDHR),& MythTV box |
#62 | |
Ok what is wrong with this model?
#63 |
For one thing, thats a lot of 3/4" tubing, heh. On wire size, you input the radius, which is 1/2 the diameter.
Since the antenna is modeled in free space, theres no need to lift the antenna higher in the Z coordinate. Having the antenna centered on the Z and X coordinates is fine and simplifies things. Youre catching on very well in Geometry edit.
#64 |
http://www.tvfool.com/?option=com_wr...e7793e37d4ef93 |
#65 | |
OK I input 3/8" because that is what I will be using from the old antenna elements that I have acquired. It keeps spitting out an segment error when I run the far field pattern.
So what your saying is I input half the wire diameter? Quote:
#66 |
Some NEC2 "shell" programs use Diameter, but 4nec2 as well as the underlying
NEC2 Engine expect to see RADIUS. After changing GW1-7 and GW107-131 to Radius, AutoGainTest was still WAY OFF. I adjusted Radius of GW132 (simulated SOURCE wire) to 0.006 (feet) for AGT=1.0. No ERRORS or Warnings after rerunning the file. AGT adjustment procedure: http://www.digitalhome.ca/forum/show....php?p=1301430 There are several different wire sizes in GW8-106, small wires forming and surrounding the Bow-Tie element....it might help if more were the same size. The SOURCE wire size may need to be readjusted for AGT=1.0 if you change any of these other wire sizes. Minimum Gain = 10 dBi with a fairly broad Gain peak of 18-19+ dBi on Ch40-51, corresponding to the best part of the SWR curve. Everyone starts with Geometry Editor....but I've found that it is EASIER to "see" what you have if you use SYmbols to define "universal" antenna models and then simply read through the SYmbol definitions to review the various Reflector and Director Lengths, Radii, X-Axis placements, et. al. You can also define a Rescale Factor (e.g. "SY F=1.05"), where "F" is multiplied against ALL of the X, Y, Z variables to change the size and thereby recenter the overall frequency response until the performance is a "best fit". SYmbols are also a pre-requisite for using nikiml's python optimization scripts.... |
#67 |
I see I didn't know it was using radius...so 3/8" diameter aluminum elements would be 3/16"?
I can't change the bowtie unless I make a whole new dipole. I'm using the bowtie that came off my CM3672 UHF section. The pictures and dimensions of which are in my Picasa album. I need it to peak around channel 23. I'm not really good with the math so not sure how to setup the symbols to optimize this antenna. I can wrap my head around the X, Y & Z for placement and initial sizing but that is as far as my middle aged brain can handle. I have what is left of a boom from an old Channel Master VHF antenna which is 104 inches long less the 4 1/2 inches where I'm going to put the mount which is going to behind the reflector. I'm going to use the the aluminum support rods that came off that antenna to support the antenna sticking out from the mast. My thought is that this will keep the mast out of the zone of the directors and help the antenna perform better. So I ended up with right at 8ft of antenna unless the spacings are better at less than 3 1/2 inches apart. Thanks holl_ands and 300ohm
#68 | |||
On a corner reflector yagi antenna, the reflector controls the lower channels gain and the yagi controls the upper high channels range. My summary from other sites on the web: * basic 90 degree corner reflector yagi design guidelines: Design the yagi for the high frequencies, design the corner reflector for the low frequencies. The distance from the CR apex to the driven element should be between 1/3 wavelength and 2/3 wavelength of the lower frequencies. This is where the tweaking comes in. Too small a distance and the SWR is high. Too large a distance and the antenna produces lobes, which take away directionality. The width of the CR should be 1.2 to 1.5 times the width of the driven element. (more is better, but the law of marginal utility applies) The length of one side of the CR should be approx 2 times the CR apex to driven element distance. The Law of Marginal Utility. Its not just a good idea, its the LAW.
#69 |
Ok but is there a way to move the dipole as a unit with a SY card so the position on the boom can be optimized?
holl_ands did you happen to save the resulting nec file so you can upload?
#70 |
Here is your 4nec2 file with the mods I mentioned above:
Code:
CM UHF Custom 26 Element Yagi w 7 Reflector Rods, nec2 by kc2cbd, 14Oct2010 CM holl_ands RevA mods: Rref & Rdir convert Diameter to RADIUS, Add FR/RP's. CE SY Rref=0.03125/2 SY Rdir=0.03125/2 GW 1 23 0.3125 0.5989 2.75 0.3125 -0.599 2.75 Rref GW 2 23 0.3125 0.5989 2.25 0.3125 -0.599 2.25 Rref GW 3 23 0.5208 0.5989 2.9245 0.5208 -0.599 2.9245 Rref GW 4 23 0.5208 0.5989 2.0755 0.5208 -0.599 2.0755 Rref GW 5 23 0.7239 0.5989 3.1563 0.7239 -0.599 3.1563 Rref GW 6 23 0.7239 0.5989 1.8437 0.7239 -0.599 1.8437 Rref GW 7 51 0.4166 1.333 2.5 0.4166 -1.333 2.5 Rref GW 8 1 0.7083 0.06 2.425 0.7183 0.1 2.425 4.16667e-3 GW 9 1 0.7183 0.1 2.425 0.7292 0.1342 2.425 4.16667e-3 GW 10 3 0.7292 0.1342 2.425 0.7292 0.255 2.4025 4.16667e-3 GW 11 3 0.7292 0.255 2.4025 0.7292 0.3758 2.3808 4.16667e-3 GW 12 3 0.7292 0.3758 2.3808 0.7292 0.43 2.4917 4.16667e-3 GW 13 3 0.7292 0.43 2.4917 0.7292 0.3758 2.6025 4.16667e-3 GW 14 3 0.7292 0.3758 2.6025 0.7292 0.255 2.5808 4.16667e-3 GW 15 3 0.7292 0.255 2.5808 0.7292 0.1342 2.5583 4.16667e-3 GW 16 3 0.7292 0.1342 2.5583 0.7292 0.0658 2.5583 4.16667e-3 GW 17 1 0.7292 0.0658 2.5583 0.7292 0.0242 2.5583 4.16667e-3 GW 18 1 0.7083 0.06 2.425 0.6983 0.1 2.425 4.16667e-3 GW 19 1 0.6983 0.1 2.425 0.6875 0.1342 2.425 4.16667e-3 GW 20 3 0.6875 0.1342 2.425 0.6875 0.255 2.4025 4.16667e-3 GW 21 3 0.6875 0.255 2.4025 0.6875 0.3758 2.3808 4.16667e-3 GW 22 3 0.6875 0.3758 2.3808 0.6875 0.43 2.4917 4.16667e-3 GW 23 3 0.6875 0.43 2.4917 0.6875 0.3758 2.6025 4.16667e-3 GW 24 3 0.6875 0.3758 2.6025 0.6875 0.255 2.5808 4.16667e-3 GW 25 3 0.6875 0.255 2.5808 0.6875 0.1342 2.5583 4.16667e-3 GW 26 3 0.6875 0.1342 2.5583 0.6875 0.0658 2.5583 4.16667e-3 GW 27 1 0.6875 0.0658 2.5583 0.6875 0.0242 2.5583 4.16667e-3 GW 28 1 0.7292 0.1342 2.425 0.6875 0.1342 2.425 4.16667e-3 GW 29 1 0.7292 0.255 2.4025 0.6875 0.255 2.4025 4.16667e-3 GW 30 1 0.7292 0.3758 2.3808 0.6875 0.3758 2.3808 4.16667e-3 GW 31 1 0.7292 0.43 2.4917 0.6875 0.43 2.4917 4.16667e-3 GW 32 1 0.7292 0.3758 2.6025 0.6875 0.3758 2.6025 4.16667e-3 GW 33 1 0.7292 0.255 2.5808 0.6875 0.255 2.5808 4.16667e-3 GW 34 1 0.7292 0.1342 2.5583 0.6875 0.1342 2.5583 4.16667e-3 GW 35 1 0.7292 0.0658 2.5583 0.6875 0.0658 2.5583 4.16667e-3 GW 36 1 0.7292 0.0242 2.5583 0.6875 0.0242 2.5583 4.16667e-3 GW 37 1 0.67 0.0658 2.5583 0.6875 0.0658 2.5583 4.16667e-3 GW 38 1 0.67 0.0658 2.5583 0.6292 0.0658 2.5583 4.16667e-3 GW 39 3 0.6875 0.0242 2.5583 0.6042 0.0242 2.5583 4.16667e-3 GW 40 1 0.6042 0.0242 2.5583 0.6042 0.0417 2.5583 4.16667e-3 GW 41 1 0.6042 0.0417 2.5583 0.6292 0.0658 2.5583 4.16667e-3 GW 42 3 0.6042 0.0242 2.5583 0.4583 0.0242 2.5583 2.08333e-3 GW 43 3 0.6042 0.0417 2.5583 0.4583 0.0417 2.5583 2.08333e-3 GW 44 1 0.4583 0.0242 2.5583 0.4583 0.0417 2.5583 2.08333e-3 GW 45 3 0.4583 0.0242 2.5583 0.3542 0.0242 2.5583 2.08333e-3 GW 46 3 0.4583 0.0417 2.5583 0.3542 0.0417 2.5583 2.08333e-3 GW 47 1 0.7083 -0.08 2.425 0.7183 -0.11 2.425 4.16667e-3 GW 48 1 0.7183 -0.11 2.425 0.7292 -0.149 2.425 4.16667e-3 GW 49 3 0.7292 -0.149 2.425 0.7292 -0.27 2.4025 4.16667e-3 GW 50 3 0.7292 -0.27 2.4025 0.7292 -0.391 2.3808 4.16667e-3 GW 51 3 0.7292 -0.391 2.3808 0.7292 -0.445 2.4917 4.16667e-3 GW 52 3 0.7292 -0.445 2.4917 0.7292 -0.391 2.6025 4.16667e-3 GW 53 3 0.7292 -0.391 2.6025 0.7292 -0.27 2.5808 4.16667e-3 GW 54 3 0.7292 -0.27 2.5808 0.7292 -0.149 2.5583 4.16667e-3 GW 55 3 0.7292 -0.149 2.5583 0.7292 -0.081 2.5583 4.16667e-3 GW 56 1 0.7292 -0.081 2.5583 0.7292 -0.039 2.5583 4.16667e-3 GW 57 1 0.7083 -0.08 2.425 0.6983 -0.11 2.425 4.16667e-3 GW 58 1 0.6983 -0.11 2.425 0.6875 -0.149 2.425 4.16667e-3 GW 59 3 0.6875 -0.149 2.425 0.6875 -0.27 2.4025 4.16667e-3 GW 60 3 0.6875 -0.27 2.4025 0.6875 -0.391 2.3808 4.16667e-3 GW 61 3 0.6875 -0.391 2.3808 0.6875 -0.445 2.4917 4.16667e-3 GW 62 3 0.6875 -0.445 2.4917 0.6875 -0.391 2.6025 4.16667e-3 GW 63 3 0.6875 -0.391 2.6025 0.6875 -0.27 2.5808 4.16667e-3 GW 64 3 0.6875 -0.27 2.5808 0.6875 -0.149 2.5583 4.16667e-3 GW 65 3 0.6875 -0.149 2.5583 0.6875 -0.081 2.5583 4.16667e-3 GW 66 1 0.6875 -0.081 2.5583 0.6875 -0.039 2.5583 4.16667e-3 GW 67 1 0.7292 -0.149 2.425 0.6875 -0.149 2.425 4.16667e-3 GW 68 1 0.7292 -0.27 2.4025 0.6875 -0.27 2.4025 4.16667e-3 GW 69 1 0.7292 -0.391 2.3808 0.6875 -0.391 2.3808 4.16667e-3 GW 70 1 0.7292 -0.445 2.4917 0.6875 -0.445 2.4917 4.16667e-3 GW 71 1 0.7292 -0.391 2.6025 0.6875 -0.391 2.6025 4.16667e-3 GW 72 1 0.7292 -0.27 2.5808 0.6875 -0.27 2.5808 4.16667e-3 GW 73 1 0.7292 -0.149 2.5583 0.6875 -0.149 2.5583 4.16667e-3 GW 74 1 0.7292 -0.081 2.5583 0.6875 -0.081 2.5583 4.16667e-3 GW 75 1 0.7292 -0.039 2.5583 0.6875 -0.039 2.5583 4.16667e-3 GW 76 1 0.67 -0.081 2.5583 0.6875 -0.081 2.5583 4.16667e-3 GW 77 1 0.67 -0.081 2.5583 0.6292 -0.081 2.5583 4.16667e-3 GW 78 3 0.6875 -0.039 2.5583 0.6042 -0.039 2.5583 4.16667e-3 GW 79 1 0.6042 -0.039 2.5583 0.6042 -0.057 2.5583 4.16667e-3 GW 80 1 0.6042 -0.057 2.5583 0.6292 -0.081 2.5583 4.16667e-3 GW 81 3 0.6042 -0.039 2.5583 0.4583 -0.039 2.5583 2.08333e-3 GW 82 3 0.6042 -0.057 2.5583 0.4583 -0.057 2.5583 2.08333e-3 GW 83 1 0.4583 -0.039 2.5583 0.4583 -0.057 2.5583 2.08333e-3 GW 84 3 0.4583 -0.039 2.5583 0.3542 -0.039 2.5583 2.08333e-3 GW 85 3 0.4583 -0.057 2.5583 0.3542 -0.057 2.5583 2.08333e-3 GW 86 3 0.67 0.0658 2.5583 0.6708 0.1217 2.5583 4.16667e-3 GW 87 1 0.6708 0.1217 2.5583 0.6708 0.1633 2.5583 4.16667e-3 GW 88 3 0.6292 0.0658 2.5583 0.6292 0.1217 2.5583 4.16667e-3 GW 89 1 0.6292 0.1217 2.5583 0.6292 0.1633 2.5583 4.16667e-3 GW 90 1 0.6708 0.1217 2.5583 0.6292 0.1217 2.5583 4.16667e-3 GW 91 1 0.6708 0.1633 2.5583 0.6292 0.1633 2.5583 4.16667e-3 GW 92 1 0.6292 0.1217 2.5583 0.5917 0.1425 2.5583 7.08333e-3 GW 93 1 0.6292 0.1633 2.5583 0.5917 0.1425 2.5583 7.08333e-3 GW 94 1 0.5917 0.1425 2.5583 0.5583 0.1425 2.5583 0.01041667 GW 95 3 0.67 -0.081 2.5583 0.6708 -0.137 2.5583 4.16667e-3 GW 96 1 0.6708 -0.137 2.5583 0.6708 -0.178 2.5583 4.16667e-3 GW 97 3 0.6292 -0.081 2.5583 0.6292 -0.137 2.5583 4.16667e-3 GW 98 1 0.6292 -0.137 2.5583 0.6292 -0.178 2.5583 4.16667e-3 GW 99 1 0.6708 -0.137 2.5583 0.6292 -0.137 2.5583 4.16667e-3 GW 100 1 0.6708 -0.178 2.5583 0.6292 -0.178 2.5583 4.16667e-3 GW 101 1 0.6292 -0.137 2.5583 0.5917 -0.158 2.5583 7.08333e-3 GW 102 1 0.6292 -0.178 2.5583 0.5917 -0.158 2.5583 7.08333e-3 GW 103 1 0.5917 -0.158 2.5583 0.5583 -0.158 2.5583 0.01041667 GW 104 3 0.7083 -0.08 2.425 0.7083 -0.01 2.425 2.11753e-3 GW 105 1 0.7083 0.06 2.425 0.7083 0.01 2.425 2.11753e-3 GW 106 3 0.7292 0.0242 2.5583 0.7292 -0.039 2.5583 2.11753e-3 GW 107 11 1.0003 0.25 2.5 1.0003 -0.25 2.5 Rdir GW 108 11 1.2913 0.25 2.5 1.2913 -0.25 2.5 Rdir GW 109 11 1.5833 0.25 2.5 1.5833 -0.25 2.5 Rdir GW 110 11 1.8753 0.25 2.5 1.8753 -0.25 2.5 Rdir GW 111 11 2.1666 0.25 2.5 2.1666 -0.25 2.5 Rdir GW 112 11 2.4583 0.25 2.5 2.4583 -0.25 2.5 Rdir GW 113 11 2.75 0.25 2.5 2.75 -0.25 2.5 Rdir GW 114 11 3.0416 0.25 2.5 3.0416 -0.25 2.5 Rdir GW 115 11 3.3333 0.25 2.5 3.3333 -0.25 2.5 Rdir GW 116 11 3.6249 0.25 2.5 3.6249 -0.25 2.5 Rdir GW 117 11 3.9166 0.25 2.5 3.9166 -0.25 2.5 Rdir GW 118 11 4.2083 0.25 2.5 4.2083 -0.25 2.5 Rdir GW 119 11 4.5 0.25 2.5 4.5 -0.25 2.5 Rdir GW 120 11 4.7916 0.25 2.5 4.7916 -0.25 2.5 Rdir GW 121 11 5.0833 0.25 2.5 5.0833 -0.25 2.5 Rdir GW 122 11 5.375 0.25 2.5 5.375 -0.25 2.5 Rdir GW 123 11 5.6667 0.25 2.5 5.6667 -0.25 2.5 Rdir GW 124 11 5.9583 0.25 2.5 5.9583 -0.25 2.5 Rdir GW 125 11 6.25 0.25 2.5 6.25 -0.25 2.5 Rdir GW 126 11 6.5417 0.25 2.5 6.5417 -0.25 2.5 Rdir GW 127 11 6.8333 0.25 2.5 6.8333 -0.25 2.5 Rdir GW 128 11 7.125 0.25 2.5 7.125 -0.25 2.5 Rdir GW 129 11 7.4167 0.25 2.5 7.4167 -0.25 2.5 Rdir GW 130 11 7.7083 0.25 2.5 7.7083 -0.25 2.5 Rdir GW 131 11 8 0.25 2.5 8 -0.25 2.5 Rdir GW 132 1 0.7083 0.01 2.425 0.7083 -0.01 2.425 0.006 ' Adjust for AGT=1.0 GS 0 0 0.3048 ' All in feet...YES FEET!!!! GE 0 EK LD 5 1 0 0 2.49e7 0 EX 0 132 1 0 1 0 GN -1 ' FR 0 1 0 0 470 0 ' fm kc2cbd ' RP 0 1 73 1510 90 0 1 5 0 0 ' fm kc2cbd ' FR Freq Sweep choices in order of increasing calculation time (fm holl_ands): ' FR 0 0 0 0 470 0 ' Fixed Freq FR 0 29 0 0 470 12 ' Freq Sweep 470-806 every 12 MHz - OLD UHF BAND ' FR 0 34 0 0 410 12 ' Freq Sweep 410-806 every 12 MHz - Even Wider Sweep ' FR 0 39 0 0 470 6 ' Freq Sweep 470-698 every 6 MHz - PREFERRED FOR UHF ' FR 0 77 0 0 470 3 ' Freq Sweep 470-698 every 3 MHz ' FR 0 153 0 0 470 1.5 ' Freq Sweep 470-698 every 1.5 MHz ' FR 0 71 0 0 300 10 ' Freq Sweep 300-1000 every 10 MHz - WIDEBAND SWEEP ' FR Hi-VHF choices: ' FR 0 15 0 0 174 3 ' Freq Sweep 174-216 every 3 MHz ' FR 0 29 0 0 174 1.5 ' Freq Sweep 174-216 every 1.5 MHz - PREFERRED ' FR 0 45 0 0 162 1.5 ' Freq Sweep 162-228 every 1.5 MHz - Add +/- 12 MHz BW ' FR 0 27 0 0 189 1.5 ' Freq Sweep 186-228 every 1.5 MHz - SPECIAL ' FR 0 43 0 0 174 1 ' Freq Sweep 174-216 every 1 MHz - Hi-Rez ' FR 0 23 0 0 198 1 ' Freq Sweep 198-220 every 1 MHz - Hi-Rez - Ch13 SPECIAL ' FR 0 26 0 0 150 6 ' Freq Sweep 150-300 every 6 MHz - WIDEBAND SWEEP ' FR Lo-VHF choices: ' FR 0 19 0 0 54 3 ' Frequency Sweep every 3 MHz for Ch2-6 + FM ' FR 0 35 0 0 54 1 ' Frequency Sweep every 1 MHz for Ch2-6 ' FR 0 36 0 0 75 1 ' Frequency Sweep every 1 MHz for Ch5 + Ch6 + FM ' FR 0 28 0 0 54 6 ' Wide Freq Sweep every 6 MHz for Ch2-13 ' FR 0 64 0 0 54 12 ' Super Wide Freq Sweep 54-810 every 12 MHz ' RP choices in order of increasing calculation time: ' RP 0 1 1 1510 90 90 1 1 0 0 ' 1D Gain toward 0-deg Azimuth - SIDE GAIN ' RP 0 1 1 1510 90 0 1 1 0 0 ' 1D Gain toward 90-deg Azimuth - FORWARD GAIN ' RP 0 1 1 1510 90 180 1 1 0 0 ' 1D Gain toward 270-deg Azimuth - REVERSE GAIN ' RP 0 1 37 1510 90 0 1 5 0 0 ' 2D (Left only) Azimuthal Gain Slice RP 0 1 73 1510 90 0 1 5 0 0 ' 2D Azimuthal Gain Slice - PREFERRED ' RP 0 73 1 1510 90 0 5 1 0 0 ' 2D Elevation Gain Slice ' RP 0 73 73 1510 90 0 5 5 0 0 ' 3D Lower Hemisphere reveals antenna (Fixed Freq) ' RP 0 285 73 1510 90 0 5 5 0 0 ' 3D Full Coverage obscures antenna (Fixed Freq) EN |
#71 |
Thanks holl_ands I will remember that for next time.
I appreciate the help.
#72 |
Here is an example of what I have recently been working on.
It's an 8-Element Yagi (without the extra Reflector Rods) 4nec2 file that is setup to find an "Optimized" solution by randomly picking a bunch of "trial" antennas where the elements Lengths and Spacing between Elements are random variables within the specified "Min, Max" ranges. Download & instructions for nikiml's python scripts are found here: http://clients.teksavvy.com/~nickm/scripts.html The scripts conveniently take care of AutoSegmentation, including reassignment of the "center" segment for the EX Card....NOT sure re TL Card.... Once you see the pattern, it should be easy to add more Directors and Reflector Rods. If you use a single variable to make most of the Directors the same size (as you have), the search will run faster, however, I would make the first one (or two) Directors individually variable, since they have a big influence on SWR. BTW: Python optimization for the below file ran for about 1-1/2 DAYS on my Triple Core Phenom II processor...and some are "only" 12-hours. Most (not all) of my models use SYmbols: http://imageevent.com/holl_ands ======================================================== This particular 4nec2 file has an unusually large (40+ dB across Ch13) Front/Back Ratio, although at the expense of Raw Gain (only 10-11 dB across Ch14) and Front/Rear Ratio. I have many more runs, using different target-functions...my best is 13.7 dBi, but with some minor detriment to F/B & F/R.....so I'm getting closer to K6STI's.... Compare to K6STI's 8-Element Ch13 Yagi (up to 13.3 dB Raw Gain with high F/B & F/R): http://imageevent.com/holl_ands/yagis/ch138elk6sti I'll (probably) be posting detailed results for the fol. 4nec2 file sometime "soon": Code:
CM CM Input file: Ch13_8El_WiderFD_Yagi_MLE_F2R_Close.nec CM Sweep ranges: CM R0 = (210, 2, 4) with target levels (14, 14) CM SWR target: 2.5 CM Target function: ((0.8*max_ml/1.0)**2)+6*max_gain_diff+2*max_f2b_diff CM CM Score 12.5462 CM CM CM Ch13 9-El. WIDER Folded Dipole Yagi, non-FD optimized 4nec2 by nikiml, 10Sep2011 CM holl_ands mods: Added Folded Dipole via GW6-8 and FW and F2 SYmbol cards. CM Added Rsrc to adjust AGT=1.0 with AutoSeg(17), added RP/FR cards. CM BIGGER 4-in Sep. Between Elements in Folded Dipole. MLE target-function CM Di=Separation Distance between Element(i-1) & Element(i). CM Li=Overall Length of Element(i). FW=Width Between Folded Dipole Loops. CE SY S1=0 SY D2=10.12036' 5, 16.5 SY S2=S1+D2 SY D3=4.954352' 3, 10.5 SY S3=S2+D3 SY D4=10.03518' 5, 18.5 SY S4=S3+D4 SY D5=14.00297' 10.5, 20.5 SY S5=S4+D5 SY D6=11.69661' 10.5, 20.5 SY S6=S5+D6 SY D7=19.29743' 10.5, 20.5 SY S7=S6+D7 SY D8=11.11153' 10.5, 20.5 SY S8=S7+D8 'CM Element Lengths (min, max): SY L1=29.13055' 20, 32 SY L2=29.74233' 20, 30 SY L3=24.67559' 21, 29 SY L4=20.15589' 20, 28 SY L5=23.07118' 10, 28 SY L6=20.76012' 10, 28 SY L7=23.06282' 10, 28 SY L8=23.28597' 10, 28 SY Relem=0.125 SY RACT=0.125 SY Rsrc=0.123 SY FW=4 SY Fpas=0.5 SY Foff=FW/2+Fpas' Folded Dipole Offset above Center of 1-in Boom SY F2=FW-Foff' Distance between Center of Boom and Folded Dipole Element ' First Element is Passive Reflector GW 1 21 0.0 -L1/2 Fpas 0 L1/2 Fpas Relem ' Folded Dipole Element and interconnecting wires (rectangular vice rounded) GW 5 23 S2 -L2/2 -F2 S2 L2/2 -F2 Rsrc GW 6 3 S2 L2/2 Foff S2 L2/2 -F2 RACT GW 7 3 S2 -L2/2 Foff S2 -L2/2 -F2 RACT GW 8 21 S2 -L2/2 Foff S2 L2/2 Foff RACT ' Passive Directors GW 9 17 S3 -L3/2 Fpas S3 L3/2 Fpas Relem GW 10 14 S4 -L4/2 Fpas S4 L4/2 Fpas Relem GW 11 16 S5 -L5/2 Fpas S5 L5/2 Fpas Relem GW 12 15 S6 -L6/2 Fpas S6 L6/2 Fpas Relem GW 13 16 S7 -L7/2 Fpas S7 L7/2 Fpas Relem GW 14 16 S8 -L8/2 Fpas S8 L8/2 Fpas Relem ' GS 0 0 0.0254 ' All in inches. GE 0 EK 0 LD 5 0 0 0 24900000 ' Alum. Elements EX 0 5 12 0 1 0 GN -1 ' FR 0 1 0 0 211 1 ' fm nikiml ' RP 0 1 73 1510 90 0 1 5 0 0 ' fm nikiml ' FR Freq Sweep choices in order of increasing calculation time (fm holl_ands): ' FR 0 0 0 0 470 0 ' Fixed Freq ' FR 0 29 0 0 470 12 ' Freq Sweep 470-806 every 12 MHz - OLD UHF BAND ' FR 0 34 0 0 410 12 ' Freq Sweep 410-806 every 12 MHz - Even Wider Sweep ' FR 0 39 0 0 470 6 ' Freq Sweep 470-698 every 6 MHz - PREFERRED FOR UHF ' FR 0 77 0 0 470 3 ' Freq Sweep 470-698 every 3 MHz ' FR 0 153 0 0 470 1.5 ' Freq Sweep 470-698 every 1.5 MHz ' FR 0 71 0 0 300 10 ' Freq Sweep 300-1000 every 10 MHz - WIDEBAND SWEEP ' FR Hi-VHF choices: ' FR 0 15 0 0 174 3 ' Freq Sweep 174-216 every 3 MHz ' FR 0 29 0 0 174 1.5 ' Freq Sweep 174-216 every 1.5 MHz - PREFERRED ' FR 0 45 0 0 162 1.5 ' Freq Sweep 162-228 every 1.5 MHz - Add +/- 12 MHz BW ' FR 0 27 0 0 189 1.5 ' Freq Sweep 186-228 every 1.5 MHz - SPECIAL ' FR 0 43 0 0 174 1 ' Freq Sweep 174-216 every 1 MHz - Hi-Rez FR 0 23 0 0 198 1 ' Freq Sweep 198-220 every 1 MHz - Hi-Rez - Ch13 SPECIAL ' FR 0 26 0 0 150 6 ' Freq Sweep 150-300 every 6 MHz - WIDEBAND SWEEP ' FR Lo-VHF choices: ' FR 0 19 0 0 54 3 ' Frequency Sweep every 3 MHz for Ch2-6 + FM ' FR 0 35 0 0 54 1 ' Frequency Sweep every 1 MHz for Ch2-6 ' FR 0 36 0 0 75 1 ' Frequency Sweep every 1 MHz for Ch5 + Ch6 + FM ' FR 0 28 0 0 54 6 ' Wide Freq Sweep every 6 MHz for Ch2-13 ' FR 0 64 0 0 54 12 ' Super Wide Freq Sweep 54-810 every 12 MHz ' RP choices in order of increasing calculation time: ' RP 0 1 1 1510 90 90 1 1 0 0 ' 1D Gain toward 0-deg Azimuth - SIDE GAIN ' RP 0 1 1 1510 90 0 1 1 0 0 ' 1D Gain toward 90-deg Azimuth - FORWARD GAIN ' RP 0 1 1 1510 90 180 1 1 0 0 ' 1D Gain toward 270-deg Azimuth - REVERSE GAIN ' RP 0 1 37 1510 90 0 1 5 0 0 ' 2D (Left only) Azimuthal Gain Slice RP 0 1 73 1510 90 0 1 5 0 0' 2D Azimuthal Gain Slice - PREFERRED ' RP 0 73 1 1510 90 0 5 1 0 0 ' 2D Elevation Gain Slice ' RP 0 73 73 1510 90 0 5 5 0 0 ' 3D Lower Hemisphere reveals antenna (Fixed Freq) ' RP 0 285 73 1510 90 0 5 5 0 0 ' 3D Full Coverage obscures antenna (Fixed Freq) EN those trial solutions with ml (Mismatch Loss) exceeding my desired "cut-off" point. Also, in this particular run I did NOT include f2r in the target-function and the relative "importance" of gain error needs to be much more than for f2b. In general, I would NOT use the "special case" target-function in the below *.bat file, since it trades off TOO much Raw Gain. [Tweak...Tweak....Tweak....and Tweak again.....] The python *.bat control file: Code:
cd c:\Python27 python -m nec.opt --num-cores=3 -s(210,2,4) --auto-segmentation=21 --swr-target=2.5 -t(14,14) --f2b-target=35.0 --target-function=((0.8*max_ml/1.0)**2)+6*max_gain_diff+2*max_f2b_diff Ch13_8El_WiderFD_Yagi_MLE_F2R_Close.nec pause |
#73 |
Cool
Figured out what didn't look right. Was missing corner reflectors. Still can't get the AGT to 1 though. Code:
CM Custom UHF Yagi CM by kc2cbd CM 14Oct2011 CE GW 1 23 0.25 0.5989 0.25 0.25 -0.599 0.25 0.015625 GW 2 23 0.25 0.5989 -0.25 0.25 -0.599 -0.25 0.015625 GW 3 23 0.4583 0.5989 0.4245 0.4583 -0.599 0.4245 0.015625 GW 4 23 0.4583 0.5989 -0.4245 0.4583 -0.599 -0.4245 0.015625 GW 5 23 0.6614 0.5989 0.6563 0.6614 -0.599 0.6563 0.015625 GW 6 23 0.6614 0.5989 -0.6563 0.6614 -0.599 -0.6563 0.015625 GW 7 29 1.11458 0.71875 1.015625 1.11458 -0.71875 1.01563 0.015625 GW 8 29 1.11458 0.71875 -1.01563 1.11458 -0.71875 -1.01563 0.015625 GW 9 29 1.46875 0.71875 1.3646 1.46875 -0.7188 1.3646 0.015625 GW 10 29 1.46875 0.71875 -1.36459 1.46875 -0.71875 -1.3646 0.015625 GW 11 51 0.3541 1.333 -1.366e-16 0.3541 -1.333 -1.366e-16 0.015625 GW 12 1 0.6458 0.06 -0.075 0.6558 0.1 -0.075 4.16667e-3 GW 13 1 0.6558 0.1 -0.075 0.6667 0.1342 -0.075 4.16667e-3 GW 14 3 0.6667 0.1342 -0.075 0.6667 0.255 -0.0975 4.16667e-3 GW 15 3 0.6667 0.255 -0.0975 0.6667 0.3758 -0.1192 4.16667e-3 GW 16 3 0.6667 0.3758 -0.1192 0.6667 0.43 -8.3e-3 4.16667e-3 GW 17 3 0.6667 0.43 -8.3e-3 0.6667 0.3758 0.1025 4.16667e-3 GW 18 3 0.6667 0.3758 0.1025 0.6667 0.255 0.0808 4.16667e-3 GW 19 3 0.6667 0.255 0.0808 0.6667 0.1342 0.0583 4.16667e-3 GW 20 3 0.6667 0.1342 0.0583 0.6667 0.0658 0.0583 4.16667e-3 GW 21 1 0.6667 0.0658 0.0583 0.6667 0.0242 0.0583 4.16667e-3 GW 22 1 0.6458 0.06 -0.075 0.6358 0.1 -0.075 4.16667e-3 GW 23 1 0.6358 0.1 -0.075 0.625 0.1342 -0.075 4.16667e-3 GW 24 3 0.625 0.1342 -0.075 0.625 0.255 -0.0975 4.16667e-3 GW 25 3 0.625 0.255 -0.0975 0.625 0.3758 -0.1192 4.16667e-3 GW 26 3 0.625 0.3758 -0.1192 0.625 0.43 -8.3e-3 4.16667e-3 GW 27 3 0.625 0.43 -8.3e-3 0.625 0.3758 0.1025 4.16667e-3 GW 28 3 0.625 0.3758 0.1025 0.625 0.255 0.0808 4.16667e-3 GW 29 3 0.625 0.255 0.0808 0.625 0.1342 0.0583 4.16667e-3 GW 30 3 0.625 0.1342 0.0583 0.625 0.0658 0.0583 4.16667e-3 GW 31 1 0.625 0.0658 0.0583 0.625 0.0242 0.0583 4.16667e-3 GW 32 1 0.6667 0.1342 -0.075 0.625 0.1342 -0.075 4.16667e-3 GW 33 1 0.6667 0.255 -0.0975 0.625 0.255 -0.0975 4.16667e-3 GW 34 1 0.6667 0.3758 -0.1192 0.625 0.3758 -0.1192 4.16667e-3 GW 35 1 0.6667 0.43 -8.3e-3 0.625 0.43 -8.3e-3 4.16667e-3 GW 36 1 0.6667 0.3758 0.1025 0.625 0.3758 0.1025 4.16667e-3 GW 37 1 0.6667 0.255 0.0808 0.625 0.255 0.0808 4.16667e-3 GW 38 1 0.6667 0.1342 0.0583 0.625 0.1342 0.0583 4.16667e-3 GW 39 1 0.6667 0.0658 0.0583 0.625 0.0658 0.0583 4.16667e-3 GW 40 1 0.6667 0.0242 0.0583 0.625 0.0242 0.0583 4.16667e-3 GW 41 1 0.6075 0.0658 0.0583 0.625 0.0658 0.0583 4.16667e-3 GW 42 1 0.6075 0.0658 0.0583 0.5667 0.0658 0.0583 4.16667e-3 GW 43 3 0.625 0.0242 0.0583 0.5417 0.0242 0.0583 4.16667e-3 GW 44 1 0.5417 0.0242 0.0583 0.5417 0.0417 0.0583 4.16667e-3 GW 45 1 0.5417 0.0417 0.0583 0.5667 0.0658 0.0583 4.16667e-3 GW 46 3 0.5417 0.0242 0.0583 0.3958 0.0242 0.0583 2.08333e-3 GW 47 3 0.5417 0.0417 0.0583 0.3958 0.0417 0.0583 2.08333e-3 GW 48 1 0.3958 0.0242 0.0583 0.3958 0.0417 0.0583 2.08333e-3 GW 49 3 0.3958 0.0242 0.0583 0.2917 0.0242 0.0583 2.08333e-3 GW 50 3 0.3958 0.0417 0.0583 0.2917 0.0417 0.0583 2.08333e-3 GW 51 1 0.6458 -0.08 -0.075 0.6558 -0.11 -0.075 4.16667e-3 GW 52 1 0.6558 -0.11 -0.075 0.6667 -0.149 -0.075 4.16667e-3 GW 53 3 0.6667 -0.149 -0.075 0.6667 -0.27 -0.0975 4.16667e-3 GW 54 3 0.6667 -0.27 -0.0975 0.6667 -0.391 -0.1192 4.16667e-3 GW 55 3 0.6667 -0.391 -0.1192 0.6667 -0.445 -8.3e-3 4.16667e-3 GW 56 3 0.6667 -0.445 -8.3e-3 0.6667 -0.391 0.1025 4.16667e-3 GW 57 3 0.6667 -0.391 0.1025 0.6667 -0.27 0.0808 4.16667e-3 GW 58 3 0.6667 -0.27 0.0808 0.6667 -0.149 0.0583 4.16667e-3 GW 59 3 0.6667 -0.149 0.0583 0.6667 -0.081 0.0583 4.16667e-3 GW 60 1 0.6667 -0.081 0.0583 0.6667 -0.039 0.0583 4.16667e-3 GW 61 1 0.6458 -0.08 -0.075 0.6358 -0.11 -0.075 4.16667e-3 GW 62 1 0.6358 -0.11 -0.075 0.625 -0.149 -0.075 4.16667e-3 GW 63 3 0.625 -0.149 -0.075 0.625 -0.27 -0.0975 4.16667e-3 GW 64 3 0.625 -0.27 -0.0975 0.625 -0.391 -0.1192 4.16667e-3 GW 65 3 0.625 -0.391 -0.1192 0.625 -0.445 -8.3e-3 4.16667e-3 GW 66 3 0.625 -0.445 -8.3e-3 0.625 -0.391 0.1025 4.16667e-3 GW 67 3 0.625 -0.391 0.1025 0.625 -0.27 0.0808 4.16667e-3 GW 68 3 0.625 -0.27 0.0808 0.625 -0.149 0.0583 4.16667e-3 GW 69 3 0.625 -0.149 0.0583 0.625 -0.081 0.0583 4.16667e-3 GW 70 1 0.625 -0.081 0.0583 0.625 -0.039 0.0583 4.16667e-3 GW 71 1 0.6667 -0.149 -0.075 0.625 -0.149 -0.075 4.16667e-3 GW 72 1 0.6667 -0.27 -0.0975 0.625 -0.27 -0.0975 4.16667e-3 GW 73 1 0.6667 -0.391 -0.1192 0.625 -0.391 -0.1192 4.16667e-3 GW 74 1 0.6667 -0.445 -8.3e-3 0.625 -0.445 -8.3e-3 4.16667e-3 GW 75 1 0.6667 -0.391 0.1025 0.625 -0.391 0.1025 4.16667e-3 GW 76 1 0.6667 -0.27 0.0808 0.625 -0.27 0.0808 4.16667e-3 GW 77 1 0.6667 -0.149 0.0583 0.625 -0.149 0.0583 4.16667e-3 GW 78 1 0.6667 -0.081 0.0583 0.625 -0.081 0.0583 4.16667e-3 GW 79 1 0.6667 -0.039 0.0583 0.625 -0.039 0.0583 4.16667e-3 GW 80 1 0.6075 -0.081 0.0583 0.625 -0.081 0.0583 4.16667e-3 GW 81 1 0.6075 -0.081 0.0583 0.5667 -0.081 0.0583 4.16667e-3 GW 82 3 0.625 -0.039 0.0583 0.5417 -0.039 0.0583 4.16667e-3 GW 83 1 0.5417 -0.039 0.0583 0.5417 -0.057 0.0583 4.16667e-3 GW 84 1 0.5417 -0.057 0.0583 0.5667 -0.081 0.0583 4.16667e-3 GW 85 3 0.5417 -0.039 0.0583 0.3958 -0.039 0.0583 2.08333e-3 GW 86 3 0.5417 -0.057 0.0583 0.3958 -0.057 0.0583 2.08333e-3 GW 87 1 0.3958 -0.039 0.0583 0.3958 -0.057 0.0583 2.08333e-3 GW 88 3 0.3958 -0.039 0.0583 0.2917 -0.039 0.0583 2.08333e-3 GW 89 3 0.3958 -0.057 0.0583 0.2917 -0.057 0.0583 2.08333e-3 GW 90 3 0.6075 0.0658 0.0583 0.6083 0.1217 0.0583 4.16667e-3 GW 91 1 0.6083 0.1217 0.0583 0.6083 0.1633 0.0583 4.16667e-3 GW 92 3 0.5667 0.0658 0.0583 0.5667 0.1217 0.0583 4.16667e-3 GW 93 1 0.5667 0.1217 0.0583 0.5667 0.1633 0.0583 4.16667e-3 GW 94 1 0.6083 0.1217 0.0583 0.5667 0.1217 0.0583 4.16667e-3 GW 95 1 0.6083 0.1633 0.0583 0.5667 0.1633 0.0583 4.16667e-3 GW 96 1 0.5667 0.1217 0.0583 0.5292 0.1425 0.0583 7.08333e-3 GW 97 1 0.5667 0.1633 0.0583 0.5292 0.1425 0.0583 7.08333e-3 GW 98 1 0.5292 0.1425 0.0583 0.4958 0.1425 0.0583 0.01041667 GW 99 3 0.6075 -0.081 0.0583 0.6083 -0.137 0.0583 4.16667e-3 GW 100 1 0.6083 -0.137 0.0583 0.6083 -0.178 0.0583 4.16667e-3 GW 101 3 0.5667 -0.081 0.0583 0.5667 -0.137 0.0583 4.16667e-3 GW 102 1 0.5667 -0.137 0.0583 0.5667 -0.178 0.0583 4.16667e-3 GW 103 1 0.6083 -0.137 0.0583 0.5667 -0.137 0.0583 4.16667e-3 GW 104 1 0.6083 -0.178 0.0583 0.5667 -0.178 0.0583 4.16667e-3 GW 105 1 0.5667 -0.137 0.0583 0.5292 -0.158 0.0583 7.08333e-3 GW 106 1 0.5667 -0.178 0.0583 0.5292 -0.158 0.0583 7.08333e-3 GW 107 1 0.5292 -0.158 0.0583 0.4958 -0.158 0.0583 0.01041667 GW 108 3 0.6458 -0.08 -0.075 0.6458 -0.01 -0.075 2.11753e-3 GW 109 1 0.6458 0.06 -0.075 0.6458 0.01 -0.075 2.11753e-3 GW 110 3 0.6667 0.0242 0.0583 0.6667 -0.039 0.0583 2.11753e-3 GW 111 11 0.9378 0.25 -1.366e-16 0.9378 -0.25 -1.366e-16 0.015625 GW 112 11 1.2288 0.25 -1.366e-16 1.2288 -0.25 -1.366e-16 0.015625 GW 113 11 1.5208 0.25 -1.366e-16 1.5208 -0.25 -1.366e-16 0.015625 GW 114 11 1.8128 0.25 -1.366e-16 1.8128 -0.25 -1.366e-16 0.03125 GW 115 11 2.1041 0.25 -1.366e-16 2.1041 -0.25 -1.366e-16 0.015625 GW 116 11 2.3958 0.25 -1.366e-16 2.3958 -0.25 -1.366e-16 0.03125 GW 117 11 2.6875 0.25 -1.366e-16 2.6875 -0.25 -1.366e-16 0.015625 GW 118 11 2.9791 0.25 -1.366e-16 2.9791 -0.25 -1.366e-16 0.015625 GW 119 11 3.2708 0.25 -1.366e-16 3.2708 -0.25 -1.366e-16 0.015625 GW 120 11 3.5624 0.25 -1.366e-16 3.5624 -0.25 -1.366e-16 0.015625 GW 121 11 3.8541 0.25 -1.366e-16 3.8541 -0.25 -1.366e-16 0.015625 GW 122 11 4.1458 0.25 -1.366e-16 4.1458 -0.25 -1.366e-16 0.015625 GW 123 11 4.4375 0.25 -1.366e-16 4.4375 -0.25 -1.366e-16 0.015625 GW 124 11 4.7291 0.25 -1.366e-16 4.7291 -0.25 -1.366e-16 0.015625 GW 125 11 5.0208 0.25 -1.366e-16 5.0208 -0.25 -1.366e-16 0.015625 GW 126 11 5.3125 0.25 -1.366e-16 5.3125 -0.25 -1.366e-16 0.015625 GW 127 11 5.6042 0.25 -1.366e-16 5.6042 -0.25 -1.366e-16 0.015625 GW 128 11 5.8958 0.25 -1.366e-16 5.8958 -0.25 -1.366e-16 0.015625 GW 129 11 6.1875 0.25 -1.366e-16 6.1875 -0.25 -1.366e-16 0.015625 GW 130 11 6.4792 0.25 -1.366e-16 6.4792 -0.25 -1.366e-16 0.015625 GW 131 11 6.7708 0.25 -1.366e-16 6.7708 -0.25 -1.366e-16 0.015625 GW 132 11 7.0625 0.25 -1.366e-16 7.0625 -0.25 -1.366e-16 0.015625 GW 133 11 7.3542 0.25 -1.366e-16 7.3542 -0.25 -1.366e-16 0.015625 GW 134 11 7.6458 0.25 -1.366e-16 7.6458 -0.25 -1.366e-16 0.015625 GW 135 11 7.9375 0.25 -1.366e-16 7.9375 -0.25 -1.366e-16 0.015625 GW 136 1 0.6458 0.01 -0.075 0.6458 -0.01 -0.075 0.006 GS 0 0 0.3048 GE 0 LD 5 1 0 0 24900000 GN -1 EK EX 0 136 1 0 1 0 0 0 FR 0 9 0 0 470 0.5 RP 0 1 73 1510 90 0 1 5 0 0 EN
#74 |
Just so you all know I'm running 4nec2 in Linux under wine.
I do have the python-necpp installed.
#75 |
Ok I went back to a CM3671 file that I think 300ohm supplied somewhere.
I removed all but the UHF dipole. For some reason there are alot of odd radii in the nec file. I can't get this resulting model to produce a AGT of 1. I figure that is part of the problem with my model above, because I used this for the dipole in that model. I figured why reinvent the wheel when that is the dipole I'm trying to use on my new antenna. Code:
CM CM3671_UHF_Dipole_Only.nec CM CM3671 UHF dipole only : converted 15 Oct 2011 CM Extracted from file CM3671.nec CE GW 1 3 0.4083 0.0167 1.4667 0.475 0 1.45 2.08333e-3 GW 2 3 0.4083 -0.042 1.4667 0.475 -0.025 1.45 2.08333e-3 GW 3 3 0.325 0.0813 1.55 0.4083 0.0167 1.4667 4.16667e-3 GW 4 3 0.325 -0.106 1.55 0.4083 -0.042 1.4667 4.16667e-3 GW 5 1 0.325 0.0813 1.55 0.3375 0.1042 1.55 4.16667e-3 GW 6 1 0.3375 0.1042 1.55 0.3458 0.1292 1.55 4.16667e-3 GW 7 3 0.3458 0.1292 1.55 0.3458 0.25 1.5275 4.16667e-3 GW 8 3 0.3458 0.25 1.5275 0.3458 0.3708 1.5058 4.16667e-3 GW 9 3 0.3458 0.3708 1.5058 0.3458 0.425 1.6167 4.16667e-3 GW 10 3 0.3458 0.425 1.6167 0.3458 0.3708 1.7275 4.16667e-3 GW 11 3 0.3458 0.3708 1.7275 0.3458 0.25 1.7058 4.16667e-3 GW 12 3 0.3458 0.25 1.7058 0.3458 0.1292 1.6833 4.16667e-3 GW 13 3 0.3458 0.1292 1.6833 0.3458 0.0608 1.6833 4.16667e-3 GW 14 1 0.3458 0.0608 1.6833 0.3458 0.0192 1.6833 4.16667e-3 GW 15 1 0.325 0.0813 1.55 0.3125 0.1042 1.55 4.16667e-3 GW 16 1 0.3125 0.1042 1.55 0.3041 0.1292 1.55 4.16667e-3 GW 17 3 0.3041 0.1292 1.55 0.3041 0.25 1.5275 4.16667e-3 GW 18 3 0.3041 0.25 1.5275 0.3041 0.3708 1.5058 4.16667e-3 GW 19 3 0.3041 0.3708 1.5058 0.3041 0.425 1.6167 4.16667e-3 GW 20 3 0.3041 0.425 1.6167 0.3041 0.3708 1.7275 4.16667e-3 GW 21 3 0.3041 0.3708 1.7275 0.3041 0.25 1.7058 4.16667e-3 GW 22 3 0.3041 0.25 1.7058 0.3041 0.1292 1.6833 4.16667e-3 GW 23 3 0.3041 0.1292 1.6833 0.3041 0.0608 1.6833 4.16667e-3 GW 24 1 0.3041 0.0608 1.6833 0.3041 0.0192 1.6833 4.16667e-3 GW 25 1 0.3458 0.1292 1.55 0.3041 0.1292 1.55 4.16667e-3 GW 26 1 0.3458 0.25 1.5275 0.3041 0.25 1.5275 4.16667e-3 GW 27 1 0.3458 0.3708 1.5058 0.3041 0.3708 1.5058 4.16667e-3 GW 28 1 0.3458 0.425 1.6167 0.3041 0.425 1.6167 4.16667e-3 GW 29 1 0.3458 0.3708 1.7275 0.3041 0.3708 1.7275 4.16667e-3 GW 30 1 0.3458 0.25 1.7058 0.3041 0.25 1.7058 4.16667e-3 GW 31 1 0.3458 0.1292 1.6833 0.3041 0.1292 1.6833 4.16667e-3 GW 32 1 0.3458 0.0608 1.6833 0.3041 0.0608 1.6833 4.16667e-3 GW 33 1 0.3458 0.0192 1.6833 0.3041 0.0192 1.6833 4.16667e-3 GW 34 1 0.2866 0.0608 1.6833 0.3041 0.0608 1.6833 4.16667e-3 GW 35 1 0.2866 0.0608 1.6833 0.2458 0.0608 1.6833 4.16667e-3 GW 36 3 0.3041 0.0192 1.6833 0.2208 0.0192 1.6833 4.16667e-3 GW 37 1 0.2208 0.0192 1.6833 0.2208 0.0367 1.6833 4.16667e-3 GW 38 1 0.2208 0.0367 1.6833 0.2458 0.0608 1.6833 4.16667e-3 GW 39 3 0.2208 0.0192 1.6833 0.075 0.0192 1.6833 2.08333e-3 GW 40 3 0.2208 0.0367 1.6833 0.075 0.0367 1.6833 2.08333e-3 GW 41 1 0.075 0.0192 1.6833 0.075 0.0367 1.6833 2.08333e-3 GW 42 3 0.075 0.0192 1.6833 -0.0297 0.0192 1.6833 2.08333e-3 GW 43 3 0.075 0.0367 1.6833 -0.0297 0.0367 1.6833 2.08333e-3 GW 44 1 0.325 -0.106 1.55 0.3375 -0.129 1.55 4.16667e-3 GW 45 1 0.3375 -0.129 1.55 0.3458 -0.154 1.55 4.16667e-3 GW 46 3 0.3458 -0.154 1.55 0.3458 -0.275 1.5275 4.16667e-3 GW 47 3 0.3458 -0.275 1.5275 0.3458 -0.396 1.5058 4.16667e-3 GW 48 3 0.3458 -0.396 1.5058 0.3458 -0.45 1.6167 4.16667e-3 GW 49 3 0.3458 -0.45 1.6167 0.3458 -0.396 1.7275 4.16667e-3 GW 50 3 0.3458 -0.396 1.7275 0.3458 -0.275 1.7058 4.16667e-3 GW 51 3 0.3458 -0.275 1.7058 0.3458 -0.154 1.6833 4.16667e-3 GW 52 3 0.3458 -0.154 1.6833 0.3458 -0.086 1.6833 4.16667e-3 GW 53 1 0.3458 -0.086 1.6833 0.3458 -0.044 1.6833 4.16667e-3 GW 54 1 0.325 -0.106 1.55 0.3125 -0.129 1.55 4.16667e-3 GW 55 1 0.3125 -0.129 1.55 0.3041 -0.154 1.55 4.16667e-3 GW 56 3 0.3041 -0.154 1.55 0.3041 -0.275 1.5275 4.16667e-3 GW 57 3 0.3041 -0.275 1.5275 0.3041 -0.396 1.5058 4.16667e-3 GW 58 3 0.3041 -0.396 1.5058 0.3041 -0.45 1.6167 4.16667e-3 GW 59 3 0.3041 -0.45 1.6167 0.3041 -0.396 1.7275 4.16667e-3 GW 60 3 0.3041 -0.396 1.7275 0.3041 -0.275 1.7058 4.16667e-3 GW 61 3 0.3041 -0.275 1.7058 0.3041 -0.154 1.6833 4.16667e-3 GW 62 3 0.3041 -0.154 1.6833 0.3041 -0.086 1.6833 4.16667e-3 GW 63 1 0.3041 -0.086 1.6833 0.3041 -0.044 1.6833 4.16667e-3 GW 64 1 0.3458 -0.154 1.55 0.3041 -0.154 1.55 4.16667e-3 GW 65 1 0.3458 -0.275 1.5275 0.3041 -0.275 1.5275 4.16667e-3 GW 66 1 0.3458 -0.396 1.5058 0.3041 -0.396 1.5058 4.16667e-3 GW 67 1 0.3458 -0.45 1.6167 0.3041 -0.45 1.6167 4.16667e-3 GW 68 1 0.3458 -0.396 1.7275 0.3041 -0.396 1.7275 4.16667e-3 GW 69 1 0.3458 -0.275 1.7058 0.3041 -0.275 1.7058 4.16667e-3 GW 70 1 0.3458 -0.154 1.6833 0.3041 -0.154 1.6833 4.16667e-3 GW 71 1 0.3458 -0.086 1.6833 0.3041 -0.086 1.6833 4.16667e-3 GW 72 1 0.3458 -0.044 1.6833 0.3041 -0.044 1.6833 4.16667e-3 GW 73 1 0.2866 -0.086 1.6833 0.3041 -0.086 1.6833 4.16667e-3 GW 74 1 0.2866 -0.086 1.6833 0.2458 -0.086 1.6833 4.16667e-3 GW 75 3 0.3041 -0.044 1.6833 0.2208 -0.044 1.6833 4.16667e-3 GW 76 1 0.2208 -0.044 1.6833 0.2208 -0.062 1.6833 4.16667e-3 GW 77 1 0.2208 -0.062 1.6833 0.2458 -0.086 1.6833 4.16667e-3 GW 78 3 0.2208 -0.044 1.6833 0.075 -0.044 1.6833 2.08333e-3 GW 79 3 0.2208 -0.062 1.6833 0.075 -0.062 1.6833 2.08333e-3 GW 80 1 0.075 -0.044 1.6833 0.075 -0.062 1.6833 2.08333e-3 GW 81 3 0.075 -0.044 1.6833 -0.0297 -0.044 1.6833 2.08333e-3 GW 82 3 0.075 -0.062 1.6833 -0.0297 -0.062 1.6833 2.08333e-3 GW 83 1 0.2866 0.0608 1.6833 0.2875 0.1167 1.6833 4.16667e-3 GW 84 1 0.2875 0.1167 1.6833 0.2875 0.1583 1.6833 4.16667e-3 GW 85 1 0.2458 0.0608 1.6833 0.2458 0.1167 1.6833 4.16667e-3 GW 86 1 0.2458 0.1167 1.6833 0.2458 0.1583 1.6833 4.16667e-3 GW 87 1 0.2875 0.1167 1.6833 0.2458 0.1167 1.6833 4.16667e-3 GW 88 1 0.2875 0.1583 1.6833 0.2458 0.1583 1.6833 4.16667e-3 GW 89 1 0.2458 0.1167 1.6833 0.2083 0.1375 1.6833 7.08333e-3 GW 90 1 0.2458 0.1583 1.6833 0.2083 0.1375 1.6833 7.08333e-3 GW 91 1 0.2083 0.1375 1.6833 0.175 0.1375 1.6833 0.01041667 GW 92 1 0.2866 -0.086 1.6833 0.2875 -0.142 1.6833 4.16667e-3 GW 93 1 0.2875 -0.142 1.6833 0.2875 -0.183 1.6833 4.16667e-3 GW 94 1 0.2458 -0.086 1.6833 0.2458 -0.142 1.6833 4.16667e-3 GW 95 1 0.2458 -0.142 1.6833 0.2458 -0.183 1.6833 4.16667e-3 GW 96 1 0.2875 -0.142 1.6833 0.2458 -0.142 1.6833 4.16667e-3 GW 97 1 0.2875 -0.183 1.6833 0.2458 -0.183 1.6833 4.16667e-3 GW 98 1 0.2458 -0.142 1.6833 0.2083 -0.163 1.6833 7.08333e-3 GW 99 1 0.2458 -0.183 1.6833 0.2083 -0.163 1.6833 7.08333e-3 GW 100 1 0.2083 -0.163 1.6833 0.175 -0.163 1.6833 0.01041667 GW 101 1 0.475 0 1.45 0.475 -0.025 1.45 0.006 GS 0 0 0.3048 GE 0 LD 5 0 0 0 24900000 GN -1 EK EX 0 101 1 0 1 0 0 FR 0 0 0 0 583.95 0 EN
