#16 |
The elements that I have a picture of in my album with the wire wings on them.
I have made a crude model in Open Office Draw to take measurements with. |
#17 |
Ok got the 4251 up and the 3672 modified by removing the UHF elements and reflectors.
I made 1 inch larger bowties for the 4251 and that made quite a difference. It made my channel 23 (58-1[2]) much better and we will see if it is consistent now. I will post some dimensions when I have a free moment. |
#18 | ||
It should be consistant, youre not in a tropo now. http://www.dxinfocentre.com/tropo.html You may have interesting results on Tuesday though. Quote:
#19 |
Actually it is bordering on a tropo right now...but I think it will be much more consistent.
I'm just hoping it will be. Now all I need to do is figure out the extra elements on the VHF conversion. |
#20 |
OK, regarding these wings, this is 1/2 of the wings director :
You said they were mounted on plastic, so that would mean an air gap between the right section and the left section. Approx, if you dont know exactly, was the air gap length in between them ?
#21 |
Around 1 1/4 inch and I have 5 pairs and yes that is one side.
I don't remember loosing or breaking any so I think that is all of them from that antenna. |
#22 |
Sorry that was wrong. I put it together and the airspace is 2 3/8 inch.
The total length of them together is 67 inches. |
#23 | |
![]() Also, whats this distance ?
#24 |
The wing material is 1/8 inch aluminum wire.
That dimension is 27 9/16 inch. I also uploaded the dimension scans to my picasa album cause you wouldn't be able to read them well from this album. I couldn't get it to load to this one either. The Picasa album is linked to in the first post in this thread. |
#25 |
OK, putting on 3 sets of those "Wing" directors in place of the 3 sets of Cap Hat directors in the same positions on my CM-3671 model, ie 2,3,4 in post 11, results in a Raw Gain of 11.65 dBi, SWR 1.29, Net Gain of 11.58 dBi on channel 10. So thats darn close to what the Cap Hat directors do.
Ill have to study your drawings to see what adjustments Ill have to make.
#26 |
The NEC file:
Code:
CM CM3671 : Channel Master 3671B, converted with 4nec2 on 25-Nov-08 12:47 CM Ken Nist CM-3671 model with UHF relevant pieces removed by 300 ohm CM AGT = 1.0 (0db) at 195mhz, Auto Segmentation = 21 CM The 3 Cap Hat type directors replaced with 3 of the Wing type directors CE GW 1 75 0.95 53.8 0.5 0.95 -53.8 0.5 0.1875 GW 2 67 13 -47.7 0.5 13 47.7 0.5 0.1875 GW 3 61 24.9 44.15 0.5 24.9 -44.15 0.5 0.1875 GW 4 59 37 -41.6 0.5 37 41.6 0.5 0.1875 GW 5 55 49 38.6 0.5 49 -38.6 0.5 0.1875 GW 6 49 61 -35.6 0.5 61 35.6 0.5 0.1875 GW 7 45 73 32.2 0.5 73 -32.2 0.5 0.1875 GW 8 41 85 -29.15 0.5 85 29.15 0.5 0.1875 GW 9 1 92 0.3 0.5 92 -0.3 0.5 0.075 GW 10 5 97 1.8 0.8 92 0.3 0.5 0.075 GW 11 5 97 -1.8 0.8 92 -0.3 0.5 0.075 GW 12 17 97 1.8 0.8 97 26.6 0.8 0.075 GW 13 17 97 -1.8 0.8 97 -26.6 0.8 0.075 GW 14 23 4.85 16.1 1.2 4.85 -16.1 1.2 0.1875 GW 15 23 16.9 15.6 1.2 16.9 -15.6 1.2 0.1875 GW 16 21 28.5 14.5 1.2 28.5 -14.5 1.2 0.1875 GW 17 21 40.5 14.3 1.2 40.5 -14.3 1.2 0.1875 GW 18 19 52.5 13.5 1.2 52.5 -13.5 1.2 0.1875 GW 19 19 64.5 13 1.2 64.5 -13 1.2 0.1875 GW 20 19 76 13 1.2 76 -13 1.2 0.1875 GW 21 17 88 12.3 1.2 88 -12.3 1.2 0.1875 GW 22 17 99.9 12.1 -0.75 99.9 -12.1 -0.75 0.1875 GW 23 15 111 7 -0.7 111 28.2 -0.7 0.1875 GW 24 15 111 -7 -0.7 111 -28.2 -0.7 0.1875 GW 43 3 97 -1.8 0.8 97 1.8 0.8 0.06 GW 45 13 147.7 13.037279 10.0000497 147.7 28.75 0 0.0625 GW 46 13 147.7 28.75 0 147.7 13.037201 -10 0.0625 GW 47 1 147.7 13.037279 10.0000497 147.7 13.738573 10.8797149 0.0625 GW 48 1 147.7 13.037201 -10 147.7 13.738516 -10.879649 0.0625 GW 49 13 147.7 13.738573 10.8797149 147.7 28.250421 1.55401058 0.0625 GW 50 1 147.7 28.75 0 147.7 28.250421 1.55401058 0.0625 GW 51 13 147.7 13.738516 -10.879649 147.7 28.250411 -1.5540169 0.0625 GW 52 1 147.7 28.75 0 147.7 28.250411 -1.5540169 0.0625 GW 53 19 147.7 1.1875 0 147.7 28.75 0 0.1875 GW 54 3 147.7 28.75 0 147.7 33.5625 0 0.1875 GW 55 13 147.7 -13.037279 10.0000496 147.7 -28.75 0 0.0625 GW 56 13 147.7 -28.75 0 147.7 -13.037201 -10 0.0625 GW 57 1 147.7 -13.037279 10.0000496 147.7 -13.738573 10.879715 0.0625 GW 58 1 147.7 -13.037201 -10 147.7 -13.738516 -10.879649 0.0625 GW 59 13 147.7 -13.738573 10.879715 147.7 -28.250421 1.55401063 0.0625 GW 60 1 147.7 -28.75 0 147.7 -28.250421 1.55401063 0.0625 GW 61 13 147.7 -13.738516 -10.879649 147.7 -28.250411 -1.5540169 0.0625 GW 62 1 147.7 -28.75 0 147.7 -28.250411 -1.5540169 0.0625 GW 63 19 147.7 -1.1875 0 147.7 -28.75 0 0.1875 GW 64 3 147.7 -28.75 0 147.7 -33.5625 0 0.1875 GW 65 1 147.7 -1.1875 0 147.7 0 0 0.1875 GW 66 1 147.7 0 0 147.7 1.1875 0 0.1875 GW 67 13 137.13 13.037279 10.0000497 137.13 28.75 0 0.0625 GW 68 13 137.13 28.75 0 137.13 13.037201 -10 0.0625 GW 69 1 137.13 13.037279 10.0000497 137.13 13.738573 10.8797149 0.0625 GW 70 1 137.13 13.037201 -10 137.13 13.738516 -10.879649 0.0625 GW 71 13 137.13 13.738573 10.8797149 137.13 28.250421 1.5540106 0.0625 GW 72 1 137.13 28.75 0 137.13 28.250421 1.5540106 0.0625 GW 73 13 137.13 13.738516 -10.879649 137.13 28.250411 -1.5540169 0.0625 GW 74 1 137.13 28.75 0 137.13 28.250411 -1.5540169 0.0625 GW 75 19 137.13 1.1875 0 137.13 28.75 0 0.1875 GW 76 3 137.13 28.75 0 137.13 33.5625 0 0.1875 GW 77 13 137.13 -13.037279 10.0000496 137.13 -28.75 0 0.0625 GW 78 13 137.13 -28.75 0 137.13 -13.037201 -10 0.0625 GW 79 1 137.13 -13.037279 10.0000496 137.13 -13.738573 10.879715 0.0625 GW 80 1 137.13 -13.037201 -10 137.13 -13.738516 -10.879649 0.0625 GW 81 13 137.13 -13.738573 10.879715 137.13 -28.250421 1.5540107 0.0625 GW 82 1 137.13 -28.75 0 137.13 -28.250421 1.5540107 0.0625 GW 83 13 137.13 -13.738516 -10.879649 137.13 -28.250411 -1.5540169 0.0625 GW 84 1 137.13 -28.75 0 137.13 -28.250411 -1.5540169 0.0625 GW 85 19 137.13 -1.1875 0 137.13 -28.75 0 0.1875 GW 86 3 137.13 -28.75 0 137.13 -33.5625 0 0.1875 GW 87 1 137.13 -1.1875 0 137.13 0 0 0.1875 GW 88 1 137.13 0 0 137.13 1.1875 0 0.1875 GW 89 13 126.65 13.037279 10.00005 126.65 28.75 0 0.0625 GW 90 13 126.65 28.75 0 126.65 13.037201 -10 0.0625 GW 91 1 126.65 13.037279 10.00005 126.65 13.738573 10.879715 0.0625 GW 92 1 126.65 13.037201 -10 126.65 13.738516 -10.879649 0.0625 GW 93 13 126.65 13.738573 10.879715 126.65 28.250421 1.5540106 0.0625 GW 94 1 126.65 28.75 0 126.65 28.250421 1.5540106 0.0625 GW 95 13 126.65 13.738516 -10.879649 126.65 28.250411 -1.5540169 0.0625 GW 96 1 126.65 28.75 0 126.65 28.250411 -1.5540169 0.0625 GW 97 19 126.65 1.1875 0 126.65 28.75 0 0.1875 GW 98 3 126.65 28.75 0 126.65 33.5625 0 0.1875 GW 99 13 126.65 -13.037279 10.00005 126.65 -28.75 0 0.0625 GW 100 13 126.65 -28.75 0 126.65 -13.037201 -10 0.0625 GW 101 1 126.65 -13.037279 10.00005 126.65 -13.738573 10.879715 0.0625 GW 102 1 126.65 -13.037201 -10 126.65 -13.738516 -10.879649 0.0625 GW 103 13 126.65 -13.738573 10.879715 126.65 -28.250421 1.5540106 0.0625 GW 104 1 126.65 -28.75 0 126.65 -28.250421 1.5540106 0.0625 GW 105 13 126.65 -13.738516 -10.879649 126.65 -28.250411 -1.5540169 0.0625 GW 106 1 126.65 -28.75 0 126.65 -28.250411 -1.5540169 0.0625 GW 107 19 126.65 -1.1875 0 126.65 -28.75 0 0.1875 GW 108 3 126.65 -28.75 0 126.65 -33.5625 0 0.1875 GW 109 1 126.65 -1.1875 0 126.65 0 0 0.1875 GW 110 1 126.65 0 0 126.65 1.1875 0 0.1875 GS 0 0 0.0254 ' All in in. GE 0 EK TL 1 38 2 34 300 0.3556 TL 2 34 3 31 300 0.3556 TL 3 31 4 30 300 0.3556 TL 4 30 5 28 300 0.3556 TL 5 28 6 25 300 0.3556 TL 6 25 7 23 300 0.3556 TL 7 23 8 21 300 0.3556 TL 8 21 9 1 300 0.2032 LD 5 0 0 0 2.5e7 0 EX 0 43 2 0 1 0 GN -1 FR 0 1 0 0 195 0
#27 |
I want to model a build of a UHF antenna using the parts from my 3672.
I think I can model the antenna but I'm having difficulty understanding how to model the dipole that came from that antenna. 300ohm those dimensions on that dipole are off so I will need to scan a new page for the dipole by itself. I will trace it out and document it's measurements. The feed gaps are strange on it the top between the matching rods has a 3/4 inch gap but the bottom where the balun connects has a 1 3/4 inch gap. I also haven't determined if I need those small attachment that go from the UHF dipole to the matching rods. |
#28 | |
Basically you model a flat bar or strip of sheet metal in 3D form. I use the thickness gauge of the metal as the wire diameter size. Heres Ken Nists model of the CM-3671 with the UHF elements on. The driven uhf element is similar, but different than yours, but note the technique. Code:
CM CM3671 : Channel Master 3671B, converted with 4nec2 on 25-Nov-08 12:47 CE GW 1 1 132.95 0.15 -2 132.95 -0.15 -2 0.048 GW 2 33 132.95 0.15 -2 122.95 0.15 -2 0.012 GW 3 33 132.95 -0.15 -2 122.95 -0.15 -2 0.012 GW 4 2 122.15 0.35 -1.8 122.95 0.15 -2 0.025 GW 5 2 122.15 -0.35 -1.8 122.95 -0.15 -2 0.025 GW 6 3 121.15 1.125 -0.8 122.15 0.35 -1.8 0.05 GW 7 3 121.15 -1.125 -0.8 122.15 -0.35 -1.8 0.05 GW 8 165 0.95 53.8 0.5 0.95 -53.8 0.5 0.1875 GW 9 147 13 -47.7 0.5 13 47.7 0.5 0.1875 GW 10 135 24.9 44.15 0.5 24.9 -44.15 0.5 0.1875 GW 11 127 37 -41.6 0.5 37 41.6 0.5 0.1875 GW 12 119 49 38.6 0.5 49 -38.6 0.5 0.1875 GW 13 109 61 -35.6 0.5 61 35.6 0.5 0.1875 GW 14 99 73 32.2 0.5 73 -32.2 0.5 0.1875 GW 15 89 85 -29.15 0.5 85 29.15 0.5 0.1875 GW 16 1 92 0.3 0.5 92 -0.3 0.5 0.075 GW 17 9 97 1.8 0.8 92 0.3 0.5 0.075 GW 18 9 97 -1.8 0.8 92 -0.3 0.5 0.075 GW 19 39 97 1.8 0.8 97 26.6 0.8 0.075 GW 20 39 97 -1.8 0.8 97 -26.6 0.8 0.075 GW 21 39 97 -1.8 0.8 119.35 -1.8 0.8 0.1875 GW 22 39 97 1.8 0.8 119.35 1.8 0.8 0.1875 GW 23 50 4.85 16.1 1.2 4.85 -16.1 1.2 0.1875 GW 24 48 16.9 15.6 1.2 16.9 -15.6 1.2 0.1875 GW 25 45 28.5 14.5 1.2 28.5 -14.5 1.2 0.1875 GW 26 44 40.5 14.3 1.2 40.5 -14.3 1.2 0.1875 GW 27 42 52.5 13.5 1.2 52.5 -13.5 1.2 0.1875 GW 28 40 64.5 13 1.2 64.5 -13 1.2 0.1875 GW 29 40 76 13 1.2 76 -13 1.2 0.1875 GW 30 38 88 12.3 1.2 88 -12.3 1.2 0.1875 GW 31 37 99.9 12.1 -0.75 99.9 -12.1 -0.75 0.1875 GW 32 26 118 8.35 -1 118 -8.35 -1 0.1875 GW 33 33 111 7 -0.7 111 28.2 -0.7 0.1875 GW 34 33 111 -7 -0.7 111 -28.2 -0.7 0.1875 GW 35 22 116.67 6.9 3.6 116.67 -6.9 3.6 0.1875 GW 36 22 118.9 6.9 5.95 118.9 -6.9 5.95 0.1875 GW 37 22 121.7 6.9 8.72 121.7 -6.9 8.72 0.1875 GW 38 37 126 11.8 12.9 126 -11.8 12.9 0.1875 GW 39 37 130.37 11.8 17.15 130.37 -11.8 17.15 0.1875 GW 40 22 116.67 6.9 -3.6 116.67 -6.9 -3.6 0.1875 GW 41 22 118.9 6.9 -5.95 118.9 -6.9 -5.95 0.1875 GW 42 22 121.7 6.9 -8.72 121.7 -6.9 -8.72 0.1875 GW 43 37 126 11.8 -12.9 126 -11.8 -12.9 0.1875 GW 44 37 130.37 11.8 -17.15 130.37 -11.8 -17.15 0.1875 GW 45 1 121.15 1.125 -0.8 121.3 1.4 -0.8 0.05 GW 46 1 121.3 1.4 -0.8 121.4 1.7 -0.8 0.05 GW 47 3 121.4 1.7 -0.8 121.4 3.15 -1.07 0.05 GW 48 3 121.4 3.15 -1.07 121.4 4.6 -1.33 0.05 GW 49 3 121.4 4.6 -1.33 121.4 5.25 0 0.05 GW 50 3 121.4 5.25 0 121.4 4.6 1.33 0.05 GW 51 3 121.4 4.6 1.33 121.4 3.15 1.07 0.05 GW 52 3 121.4 3.15 1.07 121.4 1.7 0.8 0.05 GW 53 2 121.4 1.7 0.8 121.4 0.88 0.8 0.05 GW 54 1 121.4 0.88 0.8 121.4 0.38 0.8 0.05 GW 55 1 121.15 1.125 -0.8 121 1.4 -0.8 0.05 GW 56 1 121 1.4 -0.8 120.9 1.7 -0.8 0.05 GW 57 3 120.9 1.7 -0.8 120.9 3.15 -1.07 0.05 GW 58 3 120.9 3.15 -1.07 120.9 4.6 -1.33 0.05 GW 59 3 120.9 4.6 -1.33 120.9 5.25 0 0.05 GW 60 3 120.9 5.25 0 120.9 4.6 1.33 0.05 GW 61 3 120.9 4.6 1.33 120.9 3.15 1.07 0.05 GW 62 3 120.9 3.15 1.07 120.9 1.7 0.8 0.05 GW 63 2 120.9 1.7 0.8 120.9 0.88 0.8 0.05 GW 64 1 120.9 0.88 0.8 120.9 0.38 0.8 0.05 GW 65 1 121.4 1.7 -0.8 120.9 1.7 -0.8 0.05 GW 66 1 121.4 3.15 -1.07 120.9 3.15 -1.07 0.05 GW 67 1 121.4 4.6 -1.33 120.9 4.6 -1.33 0.05 GW 68 1 121.4 5.25 0 120.9 5.25 0 0.05 GW 69 1 121.4 4.6 1.33 120.9 4.6 1.33 0.05 GW 70 1 121.4 3.15 1.07 120.9 3.15 1.07 0.05 GW 71 1 121.4 1.7 0.8 120.9 1.7 0.8 0.05 GW 72 1 121.4 0.88 0.8 120.9 0.88 0.8 0.05 GW 73 1 121.4 0.38 0.8 120.9 0.38 0.8 0.05 GW 74 1 120.69 0.88 0.8 120.9 0.88 0.8 0.05 GW 75 1 120.69 0.88 0.8 120.2 0.88 0.8 0.05 GW 76 2 120.9 0.38 0.8 119.9 0.38 0.8 0.05 GW 77 1 119.9 0.38 0.8 119.9 0.59 0.8 0.05 GW 78 1 119.9 0.59 0.8 120.2 0.88 0.8 0.05 GW 79 3 119.9 0.38 0.8 118.15 0.38 0.8 0.025 GW 80 3 119.9 0.59 0.8 118.15 0.59 0.8 0.025 GW 81 1 118.15 0.38 0.8 118.15 0.59 0.8 0.025 GW 82 2 118.15 0.38 0.8 116.9 0.38 0.8 0.025 GW 83 2 118.15 0.59 0.8 116.9 0.59 0.8 0.025 GW 84 1 121.15 -1.125 -0.8 121.3 -1.4 -0.8 0.05 GW 85 1 121.3 -1.4 -0.8 121.4 -1.7 -0.8 0.05 GW 86 3 121.4 -1.7 -0.8 121.4 -3.15 -1.07 0.05 GW 87 3 121.4 -3.15 -1.07 121.4 -4.6 -1.33 0.05 GW 88 3 121.4 -4.6 -1.33 121.4 -5.25 0 0.05 GW 89 3 121.4 -5.25 0 121.4 -4.6 1.33 0.05 GW 90 3 121.4 -4.6 1.33 121.4 -3.15 1.07 0.05 GW 91 3 121.4 -3.15 1.07 121.4 -1.7 0.8 0.05 GW 92 2 121.4 -1.7 0.8 121.4 -0.88 0.8 0.05 GW 93 1 121.4 -0.88 0.8 121.4 -0.38 0.8 0.05 GW 94 1 121.15 -1.125 -0.8 121 -1.4 -0.8 0.05 GW 95 1 121 -1.4 -0.8 120.9 -1.7 -0.8 0.05 GW 96 3 120.9 -1.7 -0.8 120.9 -3.15 -1.07 0.05 GW 97 3 120.9 -3.15 -1.07 120.9 -4.6 -1.33 0.05 GW 98 3 120.9 -4.6 -1.33 120.9 -5.25 0 0.05 GW 99 3 120.9 -5.25 0 120.9 -4.6 1.33 0.05 GW 100 3 120.9 -4.6 1.33 120.9 -3.15 1.07 0.05 GW 101 3 120.9 -3.15 1.07 120.9 -1.7 0.8 0.05 GW 102 2 120.9 -1.7 0.8 120.9 -0.88 0.8 0.05 GW 103 1 120.9 -0.88 0.8 120.9 -0.38 0.8 0.05 GW 104 1 121.4 -1.7 -0.8 120.9 -1.7 -0.8 0.05 GW 105 1 121.4 -3.15 -1.07 120.9 -3.15 -1.07 0.05 GW 106 1 121.4 -4.6 -1.33 120.9 -4.6 -1.33 0.05 GW 107 1 121.4 -5.25 0 120.9 -5.25 0 0.05 GW 108 1 121.4 -4.6 1.33 120.9 -4.6 1.33 0.05 GW 109 1 121.4 -3.15 1.07 120.9 -3.15 1.07 0.05 GW 110 1 121.4 -1.7 0.8 120.9 -1.7 0.8 0.05 GW 111 1 121.4 -0.88 0.8 120.9 -0.88 0.8 0.05 GW 112 1 121.4 -0.38 0.8 120.9 -0.38 0.8 0.05 GW 113 1 120.69 -0.88 0.8 120.9 -0.88 0.8 0.05 GW 114 1 120.69 -0.88 0.8 120.2 -0.88 0.8 0.05 GW 115 2 120.9 -0.38 0.8 119.9 -0.38 0.8 0.05 GW 116 1 119.9 -0.38 0.8 119.9 -0.59 0.8 0.05 GW 117 1 119.9 -0.59 0.8 120.2 -0.88 0.8 0.05 GW 118 3 119.9 -0.38 0.8 118.15 -0.38 0.8 0.025 GW 119 3 119.9 -0.59 0.8 118.15 -0.59 0.8 0.025 GW 120 1 118.15 -0.38 0.8 118.15 -0.59 0.8 0.025 GW 121 2 118.15 -0.38 0.8 116.9 -0.38 0.8 0.025 GW 122 2 118.15 -0.59 0.8 116.9 -0.59 0.8 0.025 GW 123 2 120.69 0.88 0.8 120.7 1.55 0.8 0.05 GW 124 1 120.7 1.55 0.8 120.7 2.05 0.8 0.05 GW 125 2 120.2 0.88 0.8 120.2 1.55 0.8 0.05 GW 126 1 120.2 1.55 0.8 120.2 2.05 0.8 0.05 GW 127 1 120.7 1.55 0.8 120.2 1.55 0.8 0.05 GW 128 1 120.7 2.05 0.8 120.2 2.05 0.8 0.05 GW 129 1 120.2 1.55 0.8 119.75 1.8 0.8 0.085 GW 130 1 120.2 2.05 0.8 119.75 1.8 0.8 0.085 GW 131 1 119.75 1.8 0.8 119.35 1.8 0.8 0.125 GW 132 2 120.69 -0.88 0.8 120.7 -1.55 0.8 0.05 GW 133 1 120.7 -1.55 0.8 120.7 -2.05 0.8 0.05 GW 134 2 120.2 -0.88 0.8 120.2 -1.55 0.8 0.05 GW 135 1 120.2 -1.55 0.8 120.2 -2.05 0.8 0.05 GW 136 1 120.7 -1.55 0.8 120.2 -1.55 0.8 0.05 GW 137 1 120.7 -2.05 0.8 120.2 -2.05 0.8 0.05 GW 138 1 120.2 -1.55 0.8 119.75 -1.8 0.8 0.085 GW 139 1 120.2 -2.05 0.8 119.75 -1.8 0.8 0.085 GW 140 1 119.75 -1.8 0.8 119.35 -1.8 0.8 0.125 GW 141 9 123.4 2.97 0.5 123.4 -2.97 0.5 0.06 GW 142 9 123.9 2.97 0.5 123.9 -2.97 0.5 0.06 GW 143 9 129.88 2.97 0.5 129.88 -2.97 0.5 0.06 GW 144 9 133.35 2.97 0.5 133.35 -2.97 0.5 0.06 GW 145 9 140.42 2.97 0.5 140.42 -2.97 0.5 0.06 GW 146 9 143.85 2.97 0.5 143.85 -2.97 0.5 0.06 GW 147 9 150.7 2.97 0.5 150.7 -2.97 0.5 0.06 GW 148 9 130.38 2.97 0.5 130.38 -2.97 0.5 0.06 GW 149 9 133.85 2.97 0.5 133.85 -2.97 0.5 0.06 GW 150 9 140.92 2.97 0.5 140.92 -2.97 0.5 0.06 GW 151 9 144.35 2.97 0.5 144.35 -2.97 0.5 0.06 GW 152 9 151.2 2.97 0.5 151.2 -2.97 0.5 0.06 GW 153 9 154.45 2.77 0.5 154.45 -2.77 0.5 0.06 GW 154 9 157.95 2.77 0.5 157.95 -2.77 0.5 0.06 GW 155 9 161.45 2.77 0.5 161.45 -2.77 0.5 0.06 GW 156 9 164.95 2.77 0.5 164.95 -2.77 0.5 0.06 GW 157 9 168.45 2.77 0.5 168.45 -2.77 0.5 0.06 GW 158 9 171.95 2.77 0.5 171.95 -2.77 0.5 0.06 GW 159 9 154.95 2.77 0.5 154.95 -2.77 0.5 0.06 GW 160 9 158.45 2.77 0.5 158.45 -2.77 0.5 0.06 GW 161 9 161.95 2.77 0.5 161.95 -2.77 0.5 0.06 GW 162 9 165.45 2.77 0.5 165.45 -2.77 0.5 0.06 GW 163 9 168.95 2.77 0.5 168.95 -2.77 0.5 0.06 GW 164 9 172.45 2.77 0.5 172.45 -2.77 0.5 0.06 GW 165 7 126.65 0.35 1 126.65 4.2 1 0.1875 GW 166 7 126.65 -0.35 1 126.65 -4.2 1 0.1875 GW 167 7 137.13 0.35 1 137.13 4.2 1 0.1875 GW 168 7 137.13 -0.35 1 137.13 -4.2 1 0.1875 GW 169 7 147.7 0.35 1 147.7 4.2 1 0.1875 GW 170 7 147.7 -0.35 1 147.7 -4.2 1 0.1875 GW 171 2 126.65 -6.5 1 126.65 -7.75 1 0.1875 GW 172 28 126.65 -8.5 1 126.65 -26.4 1 0.1875 GW 173 2 126.65 -7.75 1 126.65 -8.5 1 0.1875 GW 174 2 126.65 -7.75 1 127.74 -7.75 1 0.06 GW 175 1 126.65 -8.5 1 127.34 -8.5 1 0.06 GW 176 2 128.99 -12.3 1 128.24 -12.3 1 0.06 GW 177 2 128.99 -9.98 1 128.24 -10.14 1 0.06 GW 178 4 128.99 -12.3 1 128.99 -9.98 1 0.06 GW 179 4 128.24 -12.3 1 128.24 -10.14 1 0.06 GW 180 4 128.99 -9.98 1 127.74 -7.75 1 0.06 GW 181 3 128.24 -10.14 1 127.34 -8.5 1 0.06 GW 182 2 127.34 -8.5 1 127.74 -7.75 1 0.06 GW 183 2 126.65 -7.75 1 125.56 -7.75 1 0.06 GW 184 1 126.65 -8.5 1 125.96 -8.5 1 0.06 GW 185 2 124.31 -12.3 1 125.06 -12.3 1 0.06 GW 186 2 124.31 -9.98 1 125.06 -10.14 1 0.06 GW 187 4 124.31 -12.3 1 124.31 -9.98 1 0.06 GW 188 4 125.06 -12.3 1 125.06 -10.14 1 0.06 GW 189 4 124.31 -9.98 1 125.56 -7.75 1 0.06 GW 190 3 125.06 -10.14 1 125.96 -8.5 1 0.06 GW 191 2 125.96 -8.5 1 125.56 -7.75 1 0.06 GW 192 2 126.65 6.5 1 126.65 7.75 1 0.1875 GW 193 28 126.65 8.5 1 126.65 26.4 1 0.1875 GW 194 2 126.65 7.75 1 126.65 8.5 1 0.1875 GW 195 2 126.65 7.75 1 127.74 7.75 1 0.06 GW 196 1 126.65 8.5 1 127.34 8.5 1 0.06 GW 197 2 128.99 12.3 1 128.24 12.3 1 0.06 GW 198 2 128.99 9.98 1 128.24 10.14 1 0.06 GW 199 4 128.99 12.3 1 128.99 9.98 1 0.06 GW 200 4 128.24 12.3 1 128.24 10.14 1 0.06 GW 201 4 128.99 9.98 1 127.74 7.75 1 0.06 GW 202 3 128.24 10.14 1 127.34 8.5 1 0.06 GW 203 2 127.34 8.5 1 127.74 7.75 1 0.06 GW 204 2 126.65 7.75 1 125.56 7.75 1 0.06 GW 205 1 126.65 8.5 1 125.96 8.5 1 0.06 GW 206 2 124.31 12.3 1 125.06 12.3 1 0.06 GW 207 2 124.31 9.98 1 125.06 10.14 1 0.06 GW 208 4 124.31 12.3 1 124.31 9.98 1 0.06 GW 209 4 125.06 12.3 1 125.06 10.14 1 0.06 GW 210 4 124.31 9.98 1 125.56 7.75 1 0.06 GW 211 3 125.06 10.14 1 125.96 8.5 1 0.06 GW 212 2 125.96 8.5 1 125.56 7.75 1 0.06 GW 213 2 137.13 -6.5 1 137.13 -7.75 1 0.1875 GW 214 28 137.13 -8.5 1 137.13 -26.4 1 0.1875 GW 215 2 137.13 -7.75 1 137.13 -8.5 1 0.1875 GW 216 2 137.13 -7.75 1 138.22 -7.75 1 0.06 GW 217 1 137.13 -8.5 1 137.82 -8.5 1 0.06 GW 218 2 139.47 -12.3 1 138.72 -12.3 1 0.06 GW 219 2 139.47 -9.98 1 138.72 -10.14 1 0.06 GW 220 4 139.47 -12.3 1 139.47 -9.98 1 0.06 GW 221 4 138.72 -12.3 1 138.72 -10.14 1 0.06 GW 222 4 139.47 -9.98 1 138.22 -7.75 1 0.06 GW 223 3 138.72 -10.14 1 137.82 -8.5 1 0.06 GW 224 2 137.82 -8.5 1 138.22 -7.75 1 0.06 GW 225 2 137.13 -7.75 1 136.04 -7.75 1 0.06 GW 226 1 137.13 -8.5 1 136.44 -8.5 1 0.06 GW 227 2 134.79 -12.3 1 135.54 -12.3 1 0.06 GW 228 2 134.79 -9.98 1 135.54 -10.14 1 0.06 GW 229 4 134.79 -12.3 1 134.79 -9.98 1 0.06 GW 230 4 135.54 -12.3 1 135.54 -10.14 1 0.06 GW 231 4 134.79 -9.98 1 136.04 -7.75 1 0.06 GW 232 3 135.54 -10.14 1 136.44 -8.5 1 0.06 GW 233 2 136.44 -8.5 1 136.04 -7.75 1 0.06 GW 234 2 137.13 6.5 1 137.13 7.75 1 0.1875 GW 235 28 137.13 8.5 1 137.13 26.4 1 0.1875 GW 236 2 137.13 7.75 1 137.13 8.5 1 0.1875 GW 237 2 137.13 7.75 1 138.22 7.75 1 0.06 GW 238 1 137.13 8.5 1 137.82 8.5 1 0.06 GW 239 2 139.47 12.3 1 138.72 12.3 1 0.06 GW 240 2 139.47 9.98 1 138.72 10.14 1 0.06 GW 241 4 139.47 12.3 1 139.47 9.98 1 0.06 GW 242 4 138.72 12.3 1 138.72 10.14 1 0.06 GW 243 4 139.47 9.98 1 138.22 7.75 1 0.06 GW 244 3 138.72 10.14 1 137.82 8.5 1 0.06 GW 245 2 137.82 8.5 1 138.22 7.75 1 0.06 GW 246 2 137.13 7.75 1 136.04 7.75 1 0.06 GW 247 1 137.13 8.5 1 136.44 8.5 1 0.06 GW 248 2 134.79 12.3 1 135.54 12.3 1 0.06 GW 249 2 134.79 9.98 1 135.54 10.14 1 0.06 GW 250 4 134.79 12.3 1 134.79 9.98 1 0.06 GW 251 4 135.54 12.3 1 135.54 10.14 1 0.06 GW 252 4 134.79 9.98 1 136.04 7.75 1 0.06 GW 253 3 135.54 10.14 1 136.44 8.5 1 0.06 GW 254 2 136.44 8.5 1 136.04 7.75 1 0.06 GW 255 2 147.7 -6.5 1 147.7 -7.75 1 0.1875 GW 256 28 147.7 -8.5 1 147.7 -26.4 1 0.1875 GW 257 2 147.7 -7.75 1 147.7 -8.5 1 0.1875 GW 258 2 147.7 -7.75 1 148.79 -7.75 1 0.06 GW 259 1 147.7 -8.5 1 148.39 -8.5 1 0.06 GW 260 2 150.04 -12.3 1 149.29 -12.3 1 0.06 GW 261 2 150.04 -9.98 1 149.29 -10.14 1 0.06 GW 262 4 150.04 -12.3 1 150.04 -9.98 1 0.06 GW 263 4 149.29 -12.3 1 149.29 -10.14 1 0.06 GW 264 4 150.04 -9.98 1 148.79 -7.75 1 0.06 GW 265 3 149.29 -10.14 1 148.39 -8.5 1 0.06 GW 266 2 148.39 -8.5 1 148.79 -7.75 1 0.06 GW 267 2 147.7 -7.75 1 146.61 -7.75 1 0.06 GW 268 1 147.7 -8.5 1 147.01 -8.5 1 0.06 GW 269 2 145.36 -12.3 1 146.11 -12.3 1 0.06 GW 270 2 145.36 -9.98 1 146.11 -10.14 1 0.06 GW 271 4 145.36 -12.3 1 145.36 -9.98 1 0.06 GW 272 4 146.11 -12.3 1 146.11 -10.14 1 0.06 GW 273 4 145.36 -9.98 1 146.61 -7.75 1 0.06 GW 274 3 146.11 -10.14 1 147.01 -8.5 1 0.06 GW 275 2 147.01 -8.5 1 146.61 -7.75 1 0.06 GW 276 2 147.7 6.5 1 147.7 7.75 1 0.1875 GW 277 28 147.7 8.5 1 147.7 26.4 1 0.1875 GW 278 2 147.7 7.75 1 147.7 8.5 1 0.1875 GW 279 2 147.7 7.75 1 148.79 7.75 1 0.06 GW 280 1 147.7 8.5 1 148.39 8.5 1 0.06 GW 281 2 150.04 12.3 1 149.29 12.3 1 0.06 GW 282 2 150.04 9.98 1 149.29 10.14 1 0.06 GW 283 4 150.04 12.3 1 150.04 9.98 1 0.06 GW 284 4 149.29 12.3 1 149.29 10.14 1 0.06 GW 285 4 150.04 9.98 1 148.79 7.75 1 0.06 GW 286 3 149.29 10.14 1 148.39 8.5 1 0.06 GW 287 2 148.39 8.5 1 148.79 7.75 1 0.06 GW 288 2 147.7 7.75 1 146.61 7.75 1 0.06 GW 289 1 147.7 8.5 1 147.01 8.5 1 0.06 GW 290 2 145.36 12.3 1 146.11 12.3 1 0.06 GW 291 2 145.36 9.98 1 146.11 10.14 1 0.06 GW 292 4 145.36 12.3 1 145.36 9.98 1 0.06 GW 293 4 146.11 12.3 1 146.11 10.14 1 0.06 GW 294 4 145.36 9.98 1 146.61 7.75 1 0.06 GW 295 3 146.11 10.14 1 147.01 8.5 1 0.06 GW 296 2 147.01 8.5 1 146.61 7.75 1 0.06 GS 0 0 0.0254 ' All in in. GE 0 EK TL 8 83 9 74 300 0.3556 TL 9 74 10 68 300 0.3556 TL 10 68 11 64 300 0.3556 TL 11 64 12 60 300 0.3556 TL 12 60 13 55 300 0.3556 TL 13 55 14 50 300 0.3556 TL 14 50 15 45 300 0.3556 TL 15 45 16 1 300 0.2032 LD 5 0 0 0 2.5e7 0 EX 0 1 1 0 1 0 GN -1 FR 0 1 0 0 195 0
#29 | |
#30 |
If they are close together, those arent wires but representations of thin bars. Ive notice Ken Nist doesnt always box out a sheet metal strip, like the case of the uhf directors in the picture above, but it probably produces the same effect RF wise.
