HDMI Cables - What is considered "good"? - Canadian TV, Computing and Home Theatre Forums
Closed Thread
Old 2011-09-07, 06:35 PM   #1
Positive Climb
Default HDMI Cables - What is considered "good"?
I'm looking at buying HD cables as I now have a PS3. I saw some Philips cables at Wal Mart for $20. Also saw some $40 Monster cables. What is the main difference? Will I notice anything huge? I watched a CBC documentary a few years back and they said there is no difference.
Can somebody please explain.
Thank you
Positive Climb is offline
Old 2011-09-07, 06:39 PM   #2
Cockroach
No difference for the most part. Just hype and marketing. Some of us are using cables that didn't even cost $5.
Cockroach is offline
Old 2011-09-07, 06:57 PM   #3
jayoldschool
With distances under about 25', they either work or they don't. The signal is digital. Paying more money for a "monster" just gives you something to brag to your buddies about... unless they acutally know about home theatre (then they will just feel sorry for you). I agree with croach, my cables are all under 5 bucks (except my 35' run in my theatre).
jayoldschool is online now
Old 2011-09-07, 06:59 PM   #4
eljay
Premium Supporter
I've bought lots of "coaxial" (RCA-to-RCA) and HDMI cables from Monoprice(.com) and never had a problem with any of them. They're good quality, inexpensive and they ship fairly quickly.
MY HT SET-UP (PICS & GEAR LIST)
eljay is offline
Old 2011-09-07, 09:14 PM   #5
jlet
Also see this Sticky: "Do I Need Luxury Cables?" http://www.digitalhome.ca/forum/showthread.php?t=30452
SA8300HD; Panasonic TH-50PZ850; Sony STR-DA5ES; Tannoy: Arden, S8C, S8LR; SVS 16-46PC+; Oppo 971; Harmony 659/680
jlet is offline
Old 2011-09-07, 09:41 PM   #6
Costa
I do not reccomend 'Monster' and any of the expensive brands. Their cables are so thick that they put strain and may damage your components. Their lifetime warranties dont cover your equipment.
I've seen HDMI cables at Dollarama, not sure how long they'd last but the too thin gauge wires may break much easier and shielding/jackets may not be enough to protect the lines from interference.
I can confirm that Monoprice carries are excellent set of cables for the price. For 25ft+, I would suggest 26 awg or better, 30 awg is fine for 6-12 ft. Ferrite cores help with interence, but arent required.
Everything
Costa is offline
Old 2011-09-07, 09:54 PM   #7
Barry N
Bought the cheapest set of 4 HDMI cables for $20.00 @ Costco. They work perfectly.
I've learned a lot from my mistakes.
I'm thinking of making some more.
Barry N is offline
Old 2011-09-09, 03:10 AM   #8
prestonck
I always thought digital is digital as in image or no image, judging from my experience there is no to little difference in picture quality between a high cost HDMI cable and a low cost HDMI cable, if anything the quality differs in the materials and or durability.
prestonck is offline
Old 2011-09-09, 04:51 PM   #9
Positive Climb
Thanks guys. I ended up getting an 8ft ONI electronics cable. Works perfectly. Cost me under $20.
Old 2011-09-17, 10:21 PM   #10
DPyro
Just don't buy the ones from Wallmart. I had to return them and ended up ordering from monoprice anyway. I've heard Amazon has some cheap cables too.
DPyro is offline
Old 2011-09-17, 10:37 PM   #11
snorlax
Used a $4 cable from a dollar store to replace a Microsoft branded HDMI cable that came with my XBox 360 Elite. The Microsoft cable was loose in the socket of my upconverting DVD recorder and the picture would come and go. The $4 cable fits tight and works great. Moral: price does not equal quality in HDMI at least.
Rogers Employee. My posts should not be considered as coming from an authorized corporate source.
snorlax is offline
Old 2011-09-20, 10:06 AM   #12
hugh
Closing. Pls see link referred to in post #5 for further discussion.
hugh is offline
Closed Thread
