OTA Station Status: Atlantic Provinces/Eastern Quebec - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Over-The-Air (OTA) Digital Television > OTA Station & Network Operational Status
Old 2011-08-29, 03:49 PM   #1
downbeat
Question OTA Station Status: Atlantic Provinces/Eastern Quebec
This thread is for reporting the operational status of television stations and networks in New Brunswick and eastern Maine, Nova Scotia, Prince Edward Island and Newfoundland and Labrador.
Also for stations in Eastern Quebec (Lower St. Lawrence, Lower North Shore).
Please do not post reception reports here. Instead, use the reception thread covering the same region.
Last edited by downbeat; 2013-01-23 at 02:20 AM. Reason: Added Eastern/Atlantic Quebec to this thread
downbeat is offline
Old 2011-09-04, 05:42 AM   #2
Altavistagoogle
Exclamation CTV Moncton Sept. 8
Official confirmation that CTV Altantic will be AWOL in Moncton untill at least September 8th. I'm pretty sure I sprained my back trying to catch that channel with my rabbit ears in my window (although the HD TV induced lack of exercise might have something to do with that as well ).
You'd think the delay would be the kind of info that would be on the CTV Atlantic web site. Almost as if they want to keep it a secret from advertisers.
Altavistagoogle is offline
Old 2011-09-05, 08:52 PM   #3
Wharfe
CBC in St. John's was off the air earlier today, and I hear they have had some other outages as well. Guess they still have issues to work out. Unsure if they're trying to improve the poor signal in some parts of town or not.
Wharfe is offline
Old 2011-09-05, 09:59 PM   #4
stampeder
Question CBC Fredericton Audio
Apparently the Dolby Digital 5.1 audio on CBAT-DT Fredericton is messed up. Can anyone confirm?
stampeder is offline
Old 2011-09-05, 10:05 PM   #5
que3jxp
stampeder
It should also be noted that CBAT-DT is not properly broadcasting their channel ID. When I check the channel on my HDHomeRun, it takes forever for the channel ID to finally populate. CTV and Global are near instant to show their ID and the channel mapping.
que3jxp is offline
Old 2011-09-06, 01:09 PM   #6
jjniv
I am experiencing both mentioned problems with CBC Fredericton, CBAT-DT.
The apparent channel number seems to bounce between 4.1 and 31.1 As I change channels up and down, it will sometimes appear at one number, other times the other. I often experience a long delay before the channel "appears" after changing to it.
The only audio channel I can access for CBC is the one with the described video. My TV (a cheap 17" Audiovox) doesn't "see" any other audio channels available, so the TV control that is supposed to toggle between audio channels has no effect.
I wasn't sure if my problems were related to limitations with the TV/tuner I am using, or an issue with the broadcast. Interested to hear I am not alone.
jjniv is offline
Old 2011-09-06, 01:54 PM   #7
que3jxp
The only thing saving me is that it is processed by my HDHomeRun and SageTV. In Sage, I force the tuning of the physical channel and I have the channel remapped to the guide data for the old analog channel. (Guide data is still not straight at Zap2It which is where SageTV and also Windows Media Center get their data.)
que3jxp is offline
Old 2011-09-08, 10:25 AM   #8
hitch33
Tried CTV Moncton this morning and analog is still broadcasting. Any news Altavistagoogle?
hitch33 is offline
Old 2011-09-09, 03:46 AM   #9
downbeat
Default CTV Moncton (CKCW-DT)
According to reception reports, CTV Moncton (CKCW-DT) has switched to digital on Channel 29. Please carry on reception messages in the following thread.
http://www.digitalhome.ca/forum/showthread.php?t=41143
downbeat is offline
Old 2011-09-18, 08:19 PM   #10
Wharfe
Anyone have any info on CBC here in St. John's?
I've heard that they have been experiencing problems with their new Digital OTA signal. They are on the air, but even in my home very close to the tower I can barely pick it up, let alone other places in the city. What a disaster..
Wharfe is offline
Old 2011-09-23, 09:09 AM   #11
nielsdaj
Default Fredericton CBC (CBAT-DT) - Transmitting?
I have not been able to receive Fredericton's CBC on channel 31. I live in Keswick Ridge and am located on the west side of the ridge (and I realize that this could be the problem). I have good antennae on a tower and use a rotor and a pre-amp. This allows me to get excellent reception of CTV, Global, WAGM (2 signals) and PBS (3 signals). I do get the currently broadcasted analog CBC (4) from Saint John but they have reduced its power to the point that it the picture is seriously degraded.
I phoned CBC a couple of weeks ago and the person there said that the Fredericton transmitter was undergoing repairs. I called again yesterday and was told that as far as they know it is transmitting. I wish there was a web site or a person one could get a definitive answer from.(I do check on ALL of the popular web sites but question their being up -to-date.) I keep asking because #1 I want to know, and #2 I want CBC to know that there is interest and need for continued support of OTA transmissions.
So, if anyone reading can confirm that they ARE transmitting, then I shall continue my quest. I do realize that they are transmitting at a very low power compared to CTV and Global, but I am only 11 or so miles away.
Thanks in advance. And thanks for this wonderful site.
nielsdaj is offline
Old 2011-09-23, 09:50 AM   #12
que3jxp
I can confirm that it is still up and running. I am on the north face of McLeod Hill about 340 ft ASL.
They do indeed broadcast at a lower power than Global so that may be a source of issues.
que3jxp is offline
Old 2011-09-23, 09:29 PM   #13
lordhelmet
Just a thought but you may want to ask who their on-site tower contractor is - if there's repairs the tower company may know the status and expected timeline to greenlight full power better than the station.
lordhelmet is offline
Old 2011-10-07, 05:21 PM   #14
que3jxp
Anyone having issues with signal stability from CTV Saint John here in the Fredericton market or anywhere else where it may be picked up?
It is all over the map and breaking up a lot for me over the last couple days.
No issues with the locally located CBC or global so I doubt it is an issue on my end.
que3jxp is offline
Old 2011-10-07, 05:22 PM   #15
rpokane
Actually my issue has been Global. CTV has been fine.
rpokane is offline
