#46 |
Its in the latter part of this thread, when I was modeling it for tballister of antennahacks :
http://www.digitalhome.ca/forum/show...highlight=xg91 Remember ??
#47 |
i found it in post #198, but it sounds like you worked on it more after, and rescaled it again...
#48 |
Yeah maybe. Ive been playing with it for so long, even I have forgotten most of the models. Ive got a ton of them, heh. But basically, bigger reflector, no need for fancy X directors, just "Fat" directors will do a wonderful job on the 91XG. So yeah, Antennas Direct maybe be throwing away a simple opportunity here. Of course, the shipping box will be bigger and weight will be more, not necessarily a small factor with rising fuel prices.
#49 |
Approximately, what will the price be for the new AD DB4e?
#50 |
Based on their temporary posting of the DB4e on their website a week or two ago, I seem to recall $89 or so as the selling price.
#51 |
The DB4e at $89 will have to be significantly better in terms of gain across the 14 to 51 spectrum than the Channel Master 4221HD; because that antenna can be found for between $39 and $60, and the bottom line is most consumers, now more than ever, want the best value for their dollar.
#52 |
91XG's "X-shaped" Directors could be simplified...and are probably only needed for first
half of the antenna anyway, with simpler Rod Directors on the front. In the UK, simple X-shaped Directors are fairly common, such as in XB-12 & XB-16: http://www.aerialsandtv.com/atvschoi...ials.html#XB16 Even simpler Dipole type Rods are also popular, such as Yagi-18, et. al. Fracarro BLU920F uses simple, Triangular Outline Bowties in a plastic carrier: http://www.fracarro.com/internationa...logo/25-26.pdf BLU920F is slighty longer (95-in vs 90-in) and slightly higher Gain than 91XG, and is now available via Amazon from AbilityHDTV (Maine, USA): http://****************/BLU920F-CH14.../dp/B001BAWALK FYI: Euro Channel EC21 (470 MHz) thru EC49 (698 MHz) is our New UHF Band. UK Band A+B=K Antennas (e.g. XB-16B & XB-16K) are good choices for New UHF Band: http://www.aerialsandtv.com/gaincurves.html http://www.aerialsandtv.com/atvstock...ts.html#Bgroup Don't forget to add 2.15 dB to convert dBd to dBi. |
#53 |
Archerotor,
Keep in mind Antennas Direct has a lifetime warranty on all their antennas. Somethin breaks, they'll replace it free of charge. I'm sure that'd be factored in somehow. Also keep in mind I don't have anything from either CM or AD, so just pointing that out, not pluggin.
uhf/vhf combo rotor chimney mount homebrew vhf hi hpf ap-8700 preamp 4way split lg lcd dtt901 pctuner mythtv |
#54 |
Hey majortom
I've heard about their good no hassle 'fix it' policy. I was keen on trying an 91XG and looked at the Canadian "Save and Replay" website: $109 for the unit, and with shipping and tax it would be a little over $150 there; so it's overall (Canadian) cost that factors in, particulary when you're in an area that doesn't have OTA stores. The DB4e looks interesting in that the balun looks redesigned- at least externally. I like that AD has taken the time to come out with an antenna better suited to the 14 to 51 range, and would like to see Antennacraft have something that is new because right now for UHF only they have the U4000/U8000 and the MXU47/MXU59. |
#55 |
I couldn't find the DB4e on the Antennas Direct website. If it's coming out in less than a month, why would AD pull the link to the antenna? I suppose they might want to sell as much of their inventory of old DB4's before the new one cuts into its sales.
#56 |
The new bow ties should be back on the website soon (unless the boss changes his mind). We put them up previously with the intention of being able to accept pre-orders, but the new back end e-commerce system wasn't set up properly for it. It was decided to pull the listings while the e-comm issues were resolved and the DB2e descriptions were corrected. The web geeks have been working on it this week, so it looks like we'll be able to put them back up soon with the capability for pre-orders (maybe).
We expect to have inventory and to begin shipping the first week of November. Keep in mind that we do not ship direct to consumer outside the 48 contiguous states, so our Canadian customers should contact our Canadian partners (including the sponsor of this forum) if you want them imported. We can offer the product to our dealers all we want to, but they have to see demand on the buyer's side to convince them to carry new products. The balun is unchanged from the most recent versions of the legacy DB2 and DB4 models. There was a running change last year for the balun enclosure where it went from the square enclosure to the "hockey puck" style. The PCB (UP2N) inside has been unchanged for several years and we do not have any current plans to change it on our UHF antennas. Yes, we do have a very liberal warranty. We often even cover the unfortunate event where it's clearly not a warrant-able item. Holland, I investigated UK Band K antennas last year to see if there were any that offered the opportunity to import as potential replacements for our existing 91XG. I was unable to find any that out performed our existing product, so the search continues. I am not aware of any active plans to re-scale the 91XG. Cheers! |
#57 |
Thanks for the detailed reply, ADTech.
It reinforces Antennas Direct commitment to the consumer. |
#58 |
AD Tech, can you tell us if the DB2e and DB4e will arrive in small parts to be assembled (like the 91XG and C4) or as one big chunk? I only ask because I'm curious about whether it will fit through a small attic access openning.
#59 |
It will be the same as how the current DB2 and DB4 have been packaged for years. Pull it all out of the box and install the standoffs between the front and rear sections with the bolts.
#60 |
Archerotor, placing links is not allowed and not sure about naming companies outside the allowed threads, but I believe there is an Antenna Direct Canadian distributor listed on their website that has stores in the Vancouver area (Surrey and Coquitlam). You should find them listed on the AD website.
They sell both the 91XG and DB4 for good prices and you could pick up to avoid shipping costs. And yes, Antenna Directs after sales service is extremely good.
South Burnaby - Best TV Fool @ 1' AGL (modified 91XG, M4, HD8800) |
