Hand Held Devices for DTV? - Canadian TV, Computing and Home Theatre Forums
Old 2011-08-20, 01:30 PM   #1
cyclist44
Question Hand Held Devices for DTV?
I have a Casio Portable Hand Held 2.3 inch TV-995. It says it has a NTSC Tuner. Does anybody know what I have to do to get OTA digital TV channels. I like to use this TV when the power goes out. My two local channels CBC and Global have already gone digital. TVO has also gone digital so all that is left is the french CBC Channel in analogue.
cyclist44 is offline
Old 2011-08-20, 01:36 PM   #2
majortom
yeah, replace it with a portable LCD TV with an ATSC Tuner.
There's a few different ones floating around.
majortom is offline
Old 2011-08-20, 03:33 PM   #3
recneps77
I picked up a Haier 7" model for $40 a while back. It does the job very well for that price
Newegg may still have them in stock.
recneps77 is offline
Old 2011-08-20, 04:05 PM   #4
HWP
cyclist44,
That TV is ready for retirement.
To keep it working you'd have to attach a converter. The converter would need electricity. You wouldn't be able to use it when the power goes off.
I think I might go out and get a little ATSC handheld TV, too.
OTA, HD7697P, CM7778, Rotator, CM3218, TiVo, HDHomeRun
Apple TV, Netflix, Teksavvy, Unblock-us, Wind, MagicJack
HWP is offline
Old 2011-08-20, 09:13 PM   #5
danbcman
The Haier model HLT71 baterry life 2.5 hours plan your power down viewing well.
danbcman is offline
Old 2011-08-20, 09:20 PM   #6
stampeder
I bought a Haier 9" ATSC-equipped handheld TV last year for $56 at a surplus store just before they ran out. Nothing about it on the Haier web site anymore, though. cyclist44, unfortunately there does not seem to be much selection like that anymore but keep looking for something like that with ATSC capability.
stampeder is offline
Old 2011-08-20, 09:35 PM   #7
danbcman
I got the Haier model HLT71 from london drugs 79 on sale
danbcman is offline
Old 2011-08-20, 10:00 PM   #8
recneps77
Mine's the HLT71 as well.
Was about $45 taxes and eco fee all-in.
It was "refurb" from newegg, but the only thing that looked bad about it was the box (terrible shape, lol). The device itself was perfect.
If battery life is an issue, it's user accessible, and replacements can be found online.
Old 2011-08-20, 10:38 PM   #9
majortom
some 7" models including the haier can be had via internet stores for around 50 bux I think. Was lookin around later on after the OP.
majortom is offline
Old 2011-08-22, 02:12 PM   #10
stampeder
Regarding a couple of new posts, as far as I know there are no "hand held" UPSes, Laptops, etc. so those posts have been removed. Please keep this thread focused on extremely portable and small devices for watching DTV.
Old 2011-08-24, 09:30 AM   #11
doomy
Location: Oshawa, just off the 401, under a cellphone tower, in the shadow of the GM plant
I saw a portable TV in store a few weeks ago displaying an OTA signal from the CBC. Unfortunately I can't tell you more because I didn't really pay much attention to it as I was looking for antennas (which they didn't have any in stock by the way). I also can't remember the official name of the store, but locals in Niagara Falls call it the ebay store. Also, while I'd like to be able to direct people to particular brands or particular big name stores, I have not seen another one since. They are out there though.
doomy is offline
Old 2011-08-24, 10:06 AM   #12
Tom.F.1
I saw an Artec 8.5" portable yesterday at Sayal in Scarborough, 119.99
http://artectv.com/ehtm/products/t28A.htm
They had it hooked up to an Indoor antenna and it only scanned in 3 channels, 5.1, 57.1 & 64.1
I might have looked into it further if it had better reception.
Samsung TV, Pio-Elite AVR, OppoBD, Wharfedale Speakers, Kicker Subs. Bell EVu, DB-4e OTA:)
Tom.F.1 is offline
Old 2011-10-30, 03:02 AM   #13
be236
Default Portable TV for ATSC tuning?
I've not found a post for this subject, so decided to start one.
Basically want to start discussion about using portable LCD TVs such that you can use to tune for OTA signals, using its signal meter and/or manual RF channel edits.
I recently bought an Artec T28A portable 9" LCD to do just that, and can provide more info if there are interested folks.
Basically, I'm looking for another portable ATSC TV that meets these requirements.
1. Sensitive tuner (subjective, I know).
2. Allows manual RF channel entry.
3. Has signal meter (with numbers % shown is better than just bars).
4. Channels added stay in memory and not lost if you turn it off (this problem happens on some portable TVs).
Hearing that Samsung, Sony, and LG are most senstive tuners, do these brands exist in portable TV form (so that you can bring it outside and attach to short RG6 while you position the antenna and view a particular channel and its signal)?
be236 is offline
Old 2011-10-30, 02:45 PM   #14
recneps77
Chances are, a tuner from one of those companies will be in the TV, even though it's brand on the outside doesn't match.
TV manufacturers don't usually make every single component themselves, they source it from others.
Old 2011-10-31, 09:30 AM   #15
Smog
I use the 7" haier tv with it's week tuner as a tool when I'm on the rooftop aligning antennas
CM4228a+CM7777=digital tv 185 km away.
http://www.tvfool.com/?option=com_wr...134931fec40ad0
Smog is offline
OTA Forum Sponsor
