#1 | |
Location: OTtAwa (Byward Market); Sony Bravia KDL46SL140; Mini State HDMS9100
At 9:00am Global went off the air. Hopefully it will be in digital when it comes back!
And they're on with a bizarre PSIP of 6.1 channel name uJC-4LA
The signal is appallingly weak. I enjoy better reception from the 2-Edge HC channels and this channel is LOS. Update: now it's showing up as channel 4.1 after a rescan and CBOT was bumped to 25.10 Wtf Global?? |
Well the headline says it all. RF 6, vert ch 6-1 S/N = 27 signal strength full scale= 97 |
here's a screen cap of Global @ 10:30.
http://www.flickr.com/photos/6603455...in/photostream I hope they turnthe knobs to the right |
Global's corrected their channel name to "CIII-DT" instead of "uJC-4LA". Still showing up as 4.1 though.
Location: Carp, ON. HD8800 and Ch6 Dipole to CM7777 in attic.
Well, it looks like I'm going into the attic. As I feared, Global is too weak for me to receive.
I've got a homemade channel 7 yagi pointed at Watertown, with 6 is coming in from the back. The analog signal was weak, and the picture was quite grainy, but I was optimistic that it would be good enough to pull in the digital signal. Since the WNYF repeater went up on 28.1 and 28.2,the channel 7 antenna became redundant, so I'll replace it with a channel 6 dipole I built and see how well that works for the digital signal. Wish me luck, Josh |
#9 |
Global is currently on RF6 an mapping to 4.1
CBOT-DT has been booted off to 25.10 I can't imagine CBC will be terribly amused by this. |
#10 |
No Global here in downtown Ottawa at noon Monday. Tried every possible antenna angle in the apartment. Nothing. Even shut off all computers and electronic devices that would normally kill the signal.
#11 |
Location: Franktown, Ontario CM4228HD with 7777 to two Samsung LCDs and WinTV on my WiFi network
No Global here in Franktown on either TV or my Hauppauge 850. And CBOT is still on RF 25(4-1) here too.
#12 |
I just scanned again and confirmed that I still see Global from Richmond. I can't actually confirm that there's a picture, because I'm at work and just have shell access to my mythtv box. That is, I can scan but I can't watch.
#13 | |
Could everyone please report the type of antenna you are using for VHF-LO when reporting your results? I am using a 5Y6S and seem to be receiving a good signal so far.
Link to my TVFool results is in my profile Homepage URL. I suggest others do the same. |
#14 |
I've got pic and sound on ch6 within my Npvr software so if the situation remains as is I'm good to go.
#15 |
I still have no sound or pic. I'm using a CM4228HD antenna in my attic. I'm getting all of the other digital channels and analog too. So unless channel 6 is broadcasting at an extremely low signal, I'm not sure why I'm still not picking it up. I just did a scan to see if it would make a difference but it doesn't.
I have plain rabbit ears on my TV in the bedroom. I'll go up and try that one, but if I can't pick it up with the CM4228HD in the attic, it seems strange I would pick it up with rabbit ears. I'll check though. |
