Question about multi lnb install - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2004
Old 2004-07-14, 12:54 PM   #1
jclark
Default Question about multi lnb install
I currently have a 20" dish with a single LNB, I have purchased the y adapter and a second LNB. Will I need to repoint the dish, as it is already getting 100% signal from 91. Also, both LNB's are identical, is the 82, 91 degree just for reference when hooking up to the switch?
Cheers
jclark is offline
Old 2004-07-15, 09:15 AM   #2
StreetPreacher
Default Re: Question about multi lnb install
The LNB's are identical, and yes the markings are just for reference.
As far as repointing goes, if you're getting 100% from 91 AND have already set the SKEW on the dish, then you should just be able to plug and play.
If you haven't set the SKEW, then do that first and see how it affects the 91 reception, adjust elevation and azimuth to optomize it again, then plug in the second LNB and you should be good to go!
-Sp
StreetPreacher is offline
Old 2004-07-15, 09:39 AM   #3
jclark
Thanks for the advice, I take it the skew has to be adjusted when you upgrade a single lnb to a dual lnb setup?
jclark is offline
Old 2004-07-15, 10:42 AM   #4
StreetPreacher
Yes, the skew setting is what allows the dish to see both sat's at the same time. The severity of the SKEW setting will vary depending on your location, and in my experience it was quite easy to adjust, as it isn't nearly as specific as the elevation and azimuth settings. It seems you can be a few degrees off on SKEW and still get a signal from both birds (assuming the other 2 settings are correct).
Good Luck!
Old 2004-07-15, 11:51 AM   #5
jclark
Thanks very much for the info!
jclark is offline
Old 2004-07-15, 06:50 PM   #6
jclark
Started playing tonight, I can get 91 no problem but 82 always says wrong satellite.. I don't have a skew adjustment on this dish is it even possible to get the two of them in
jclark is offline
Old 2004-07-15, 07:00 PM   #7
jclark
I just measured the dish, it's a 24" dish will that work. All the pdf's i can find on multi lnb install talk about 20" dishes.
jclark is offline
Old 2004-12-21, 07:24 PM   #8
dishpaj
Default instal
hey jclark .. did u ever get this to work? I am in the same situation.
dishpaj is offline
Old 2004-12-23, 11:11 AM   #9
iknowbell
You can't get both sats with anything other than a skew-able 20" dish.
iknowbell is offline
