I bought a Macbook Pro about a year ago via applestore.ca
I want to trade in my MB Pro but the salesguy said I need the "two" disks that came with the MB Pro. Does it come with disks? If so I have no idea what I did with them Thanks |
It probably came with OS X and another with iLife or something similar.
Hmmm I found "Mac OS X Snow Leopard" install DVD and Ilife and I works.
#4 | |
See here: http://porting.openoffice.org/mac/fa...g/img/disk.JPG
Panasonic TH-42PE7U plasma, Toshiba HD-D3, PS3, Shaw DCX3400, Yamaha HTR-6160, Polk 6.1, Belkin PF30, Harmony 700 |
#5 | |
Is it hard to sell without them? Thanks for all your replies! |
I don't think the disks are a deal maker or breaker, but might give the prospective buyer a bit more confidence that they're not buying a stolen computer (doubtful that a thief would have the right disks).
If I'm buying, I don't think I'd care. In fact, I have bought two Macs used, and didn't care about (or use) the disks that were included. The original boxes would have assured me that I was dealing with an honest seller. |
Guess I will find out .....I will call apple care tomorrow and see how much the disks will cost me...give them my serial number etc. If its going to cost and arm/leg I won't do it....otherwise I will post without disks.
It's not like I have to get rid of it anyways. Its perfectly working and hardly used. |
What's the trade in value of your old MBP?
#9 |
The discs we got with our MBP's are specific enough to have MBP 17" on mine and MBP15" or Mrs Pinza's.
They have never been in the machines. |
#10 |
#11 |
IIRC, the disks won't allow an OS install on a "different" machine (I didn't notice once, and tried to use my imac's disk in the MBP - no go). Not sure about the iLife support software, but I'd guess it's model-specific as well.
#12 |
I figured what the problem was....my original Snow Leopard disk was scratched/undreadable. I purchased a new on $29 and was able to erase my hdd and restore it to factory settings. Now I have it on the market
Thanks |
