New Shaw Direct LNBF - Page 2 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Direct (formerly Star Choice)
Old 2011-06-30, 11:17 AM   #16
classicsat
From all the research I have done, the Shaw Direct portion of the new satellite will add 16 transponders, so will be 250Mhz below the bottom of the normal FSS Ku band.
It remains to be seen how exactly Shaw will integrate this newer satellite into the current voltage polarity and tone satellite switching, and possibly remain compatible with legacy receivers.
classicsat is offline
Old 2011-07-07, 12:27 AM   #17
Jimsathome
Cool
classicsat,
IMHO, I don't think they'll bother making the new Sat compatible with the existing legacy receivers. I expect the new Bird will carry new HD signals; and to get them you'll need a 6xx series Box and the new LNBs. If you don't get the hardware you'll be out of luck.
But the side benefit would be existing legacy hardware Customers would remain whole just as they are => with no new hardware.
Regards,
Jim
Jimsathome is offline
Old 2011-08-06, 12:48 PM   #18
Snickerdoodles
I had Shaw Direct installed yesterday and received the new LNB. Installer said they've been giving them out for a little more than the last week.
Snickerdoodles is offline
Old 2011-10-21, 01:18 PM   #19
sumshmow
Default XKU LNB
where in Canada can you buy a XKu LNB?
sumshmow is offline
Old 2011-10-21, 04:15 PM   #20
HowieDoin
why would we have to pay for them?...SD should be providing them at no charge to existing subscribers...
HowieDoin is online now
Old 2011-10-21, 10:46 PM   #21
Jimbo54
Shaw Direct supplies them at no charge.
Jimbo54 is offline
Old 2011-10-23, 02:22 PM   #22
Classof83
Isn't the new satellite going in at 107.3 degrees, where Anik F1 currently is? If so, why is a new LNB required? Is that because of the X-band frequencies that are going to be used?
Classof83 is offline
Old 2011-10-23, 11:04 PM   #23
46FD04
The new Triple Satellite Quad XKu LNB is required only if you plan on subscribing to any channels broadcast on the 3rd satellite.
It will be launched in approx 12 months.
There will be three satellites in the two existing orbital slots, and only the new Triple XKu LNB will be able to "see" the new 3rd satellite.
Also, it is important to note that if the Primary Account holder has the new Triple LNB on their dish, all other secondary locations (the Cottage, brother-in-law, etc...) will need one too. Otherwise the secondary location receivers will NOT be able to watch TV.
46FD04 is offline
Old 2011-10-23, 11:25 PM   #24
Sirius Guy
Brother-inlaw = account sharing = illegal, that is why some people will want to buy and XKU lnb...
Legitimate documented cottage systems will not be effected as long as you have a dedicated receiver at that location , otherwise you would need to call to get code changes which would be annoying at best.
Sirius Guy is offline
Old 2011-10-23, 11:34 PM   #25
46FD04
Anyone signed up with the Home-Away-From-Home program ($100 plus tax) will get a new LNB for their legitimate secondary location.
All other Secondary Users will be required to purchase a new Triple LNB which retails for $113 (inc. tax) in the Toronto area.
46FD04 is offline
Old 2011-10-24, 10:34 AM   #26
classicsat
Yes, the new satellite (G1) will be co-locagted ad 107.3 with F1R. The satellite (portion that Shaw Direct have contracted) uses a band 250 Mhz below and to the bottom of the traditional FSS Ku band F1R/F2 uses. A new LNBF is required to get that satellite. As I said earlier, it seems that the LO is about 500 Mhz higher than a normal LNBF, to fit within the band pass capabilites of the tuners (which are known to tune 900 to 2100 Mhz or so).
Old 2011-10-24, 10:40 AM   #27
Classof83
Ok. I have a motorized system that I use currently, with a linear LNB to get other FTA channels, as well as Shaw Direct services that I subscribe to (I really only watch HD, so I normally just tune into 111.1 degrees).
Would I be able to buy an LNBF that does X-band on its own? I haven't found any except some expensive Norsat ones. I'd rather just put one up than a hulking beast provided by Shaw, as I already have other LNB's on my system and I don't want to add to much more due to the motor only being able to handle so much weight.
Old 2011-10-25, 09:32 AM   #28
classicsat
The LNBF does not do the X-band. It is X-Ku, which means Extended Ku.
IMHO, you are best served with a dedicated dish for Shaw Direct, and use your motorise dish for FTA only.
Old 2011-10-25, 09:47 AM   #29
Classof83
Oh, I see.
Well, I've never had problems with my motorized dish for Shaw. I get good levels as well (97 signal strength, 10.4 db EKB). I like having one dish as it's a clean setup, and with the Multi-Star railmount system, I have 5 different LNB's up there to get various things like the NBC Mux, which requires a special skew.
Old 2011-10-25, 11:53 PM   #30
PrinceLH
Is there any similarities to the Directv Slimline LNB that the MPEG4, B Band receivers use?
Winegard PR8800, YA1713, Zenith7777 Preamp, 42" Aquos 120hz, Samsung UP5000 Blu Ray/HDDVD, C/Ku Band, Directv H21, 22.
PrinceLH is online now
