Panasonic DLP display problem - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > HDTV: Front and Rear Projection Screens and Televisions
Old 2011-06-09, 09:05 PM   #1
Tezster
Default Panasonic DLP display problem
My Panny DLP started exhibiting corrupted display earlier this evening (see video clip below). I've tried both component and HDMI inputs - both suffer the similar display problem, but it's much worse on component. None of the on-screen TV menus are affected.
I would replace the bulb, but this doesn't look like a bulb issue. The TV is well over 5 years old, so it's beyond even the extended warranty plan that was bought with it.
I guess my question is if this is the end of the line for this TV.
My Living Room HT setup
Tezster is offline
