Check Switch Test says wrong connection - Canadian TV, Computing and Home Theatre Forums
Old 2011-06-05, 04:13 PM   #1
sfin
Default Check Switch Test says wrong connection
Hello,
I have one dish pointed to 91 and 82, signal strength is good. When I do the Check Switch test is says I have a wrong connection.
I have one RG6 cable coming from the LNB on the 91 side going into input 1A of an SW44 switch.
I also have one RG6 cable coming from the LNB on the 82 side going into input 2A of the SW44 switch.
I have 2 cables coming out from the SW44 and going into my 9200 receiver. I don't have the power transformer installed.
What do I have hooked up wrong?
Any help is much appreciated,
sfin
sfin is offline
Old 2011-06-05, 04:17 PM   #2
streamer
You need to install the power inserter
streamer is online now
Old 2011-06-05, 04:32 PM   #3
sfin
Default Thanks Streamer
New error now:
Reception error; Details:
---- Satellite Input 1 ----
Missing: Port 1b Sat 91 Even
Missing: Port 2b Sat 82 Even
---- Satellite Input 2 ----
What does this now mean?
From the Power inserter I am going to Port 1 of my 9200 receiver. Is this the only cable I need going in or do I still need a 2nd cable going from the SW44 to receiver?
Thanks in advance,
sfin
sfin is offline
Old 2011-06-05, 04:59 PM   #4
tvnut64
You have to run 4 lines from the LNB to the SW44. 91 lnb to 1A and 2A, 82 lnb to 1B & 2B. That is how mine is wired.
Samsung LN52A650, Samsung LN40A450, Samsung BD-D6500 Blu-Ray, Sony BDP-S350 Blu-Ray, Sony HT-SF2300 HTIB, 2 x 9242
tvnut64 is online now
Old 2011-06-05, 05:24 PM   #5
Installer
tvnut64 is correct, you'll also need to hook up the power inserter.
"The quality of your question will directly effect the quality of your answer"
Installer is offline
Old 2011-06-05, 05:26 PM   #6
sfin
Default Thanks TVNUT and INSTALLER
Is there a way I can make this work with only 2 cables and perhaps a different switch?
sfin is offline
Old 2011-06-05, 06:15 PM   #7
Pinza
Yes, get 2 x SW21's and run 4 lines from the LNBF's to the switch's, then 2 lines to the Receiver, or swap out the 2 x LNBF's for a DPP Twin LNBF, then use 1 line to the rear of the receiver and attatch a DPP Separator, to feed BOTH inputs of the Receiver.
Pinza is online now
Old 2011-06-05, 08:16 PM   #8
sfin
Default Thank you, Pinza
I got it to work with the SW44. I found a few more coax cables around the house, but they aren't RG6. I will be able to change them out tomorrow.
The main thing is I am up and running thanks to the help of you three!!
Thanks,
sfin
sfin is offline
Old 2012-04-17, 06:12 PM   #9
worielly
Default Help with moving a receiver
Hi I haven't got a clue whats going on with the my bell satellite
We moved our receiver to another room because we are renovating and boy was that a mistake!! Cann't get my 9242 HD Receiver working right!!
the error message i'm getting is
Satellite Input 1
Missing: Port 1b Sat 82 Even
Satellite Input 2
Missing: Port 2b Sat 91 Even
I would appreciate any and all help
Wanda
worielly is offline
Old 2012-04-17, 06:26 PM   #10
Pinza
Check the Power Supply/Power Inserter of the SW44.
Is it possible there are splitters on the new lines.?
Pinza is online now
