#61 |
I used the toslink cable on my DVD player, no problems at all. Also tested my audio receiver and it works fine.
Expressvu has no knowledge of the 6100 at all so that does not help at all. They would just step me through the standard stuff, unplug the receiver, do a reset. Or as they said the last time, you have to use the RCA cables for some stations and toslink for other stations. I don't think so. They did honestly try to solve the issue. On the plus side at least the VCR will record with this receiver. The other receiver would not record at all. |
#62 |
Hey Rick
Where exactly is your 6100s Optical Cable plugged into on your Receiver? What is the Input called on the back of your Receiever, also what is the make/ model/year ? |
#63 |
My audio receiver is a Panasonic SC-HT400. Purchased in 2003, however the manual dates 2002.
I have two Optical ports. Digital In-Optical 1 (TV) and Optical (2) (DVD). You can use either one and change the settings. I have attempted to use both without any luck. DVD however works fine. |
#64 |
does anyone no if i get a 6100 reciever and subcribe to hd channels will i be able to view them on my standard tv as super definition until i can aford a new tv.
#65 |
spoonky,
Yes you can choose to output everything to 480P to a standard definition TV as long as your TV has S-video or component inputs. SatGuru |
#66 |
You mean it can output to 480i, I would assume, since standard TV's cannot accept a progressive input.
Greg |
#67 |
Yes u can use the 6100 on a regular TV via Composite, S-Video or Component Outputs.
480i,480p,720p,1080i |
#68 |
Yes, you can have those formats being input to the STB, but the OUPUT to your TV is only going to be 480i because that is ALL a standard TV can recognize out of those 4 resolutions listed.
We're talking a STANDARD TV here, not an SDTV i.e. Standard DIGITAL TV. |
#69 |
True, he's only going to get a standard NTSC signal, but considering the HD channels get a lot more bandwidth than the regular channels, his picture is going to look a lot better than on the SD channels. Right now, on my 6000, if I use the s-video output only, NBC HD looks a lot sharper than the regular NBC feed.
#70 |
Good answer!
#71 |
thanks for all of you that replied i appretate it.you answered my question expertly not like the answer i got from express vu on there site
#72 |
I sent an email to Bell asking about the toslink bug and when the next software update will occur. Here is the canned response.
Thank you for taking the time to contact us with regards to your account. We hope that you are enjoying your Bell ExpressVu Satellite system. At this time, we do not have any information when the software for the 6100 will be updated. We appreciate you taking the time to provide us with your feedback regarding problems with the 6100. We encourage all feedback and concerns from all our Bell ExpressVu customers and potential customers as this will help us to maintain excellent quality products and services that we strive to provide. We will forward your comments to our Technology Department for further review and consideration. |
#73 |
A couple important questions.
1) Does it come with a DVI cable? 2) If you use a DVi to HDMI cable will the sound still be able to output through the optical port (if it has one). I don't want to hook up a HDMI cable and then no sound comes out of other ports. |
#74 |
Mark Oliver,
1) Does not come with a DVI cable, comes with the same nice component cable the 6000 came with. 2) In regards to HDMI it will transmit video only and audio will still be transmitted via toslink. SatGuru |
#75 |
Anybody else notice that the audio level coming from the 6100 is low. I have a 400 watt audio system (no TOSlink) and I pretty much have this cranked to max to get 'loud' volume out of this system. Is there some way to boost it?
| Tags |
| 6120, expressvu |
