Official: 6120 Thread - Page 24 - Canadian TV, Computing and Home Theatre Forums
Old 2005-11-17, 02:48 PM   #346
FuzzyQball
Default 6120 vs 6100
I just checked my new terminal and although Bell advertises a 6120, but I got a 6100. Is there any significant differnece between these two units? From rading the threads, it seems as if the 6100 has been around a lot longer
Glenn
FuzzyQball is offline
Old 2005-11-17, 02:54 PM   #347
ken0042
Premium Supporter
6100 is the receiver. 6120 is a package that includes a 6100 and a dish.
"There are 10 types of people in this world; those who understand binary and those who don't."
ken0042 is offline
Old 2005-11-20, 10:13 PM   #348
Ampler
There actually is no such thing as a 6120 receiver. It's just the 6100 packaged with the dish, LMBs, upgrade kit, etc.
Ampler is offline
Old 2005-11-23, 06:25 AM   #349
tmoffatt
Default Pioneer DVR533H-S DVD recorder code number?
Does anyone have the IR code number for the 6120 to record to the Pioneer DVR-533H-S DVD recorder?
Thanks - Tom Moffatt
tmoffatt is offline
Old 2005-11-23, 03:16 PM   #350
FuzzyQball
Thanks for the replys. I am still getting used to this forum's format and did not see the replies until today. So I guess I don't have to give BEV heck then? BTW I am enjoying the HD channels. More channels than I could get with Rogers at my location, and less errors and other hicoughs with the HD signal so far
Glenn
Old 2005-11-25, 11:30 AM   #351
Ampler
I was actually curious as to if there were IR codes for any DVD recorders. I'm using a VCR code right now.
Ampler is offline
Old 2005-12-03, 06:55 PM   #352
cave2
Can somebody confirm the 6120 comes with the legacy LNB, not the DishPro LNB?
Thanks in advance.
Cave
cave2 is offline
Old 2005-12-03, 07:41 PM   #353
Altaman
Bell does not sell anything that is Dishpro except the receivers themselves...so not there is only the legacy LNB's.
alt
Altaman is offline
Old 2005-12-04, 01:26 AM   #354
cave2
Ah, thanks Altaman.
cave2 is offline
Old 2006-01-12, 11:05 AM   #355
vaillan57
Default HDTV Programes
Originally Posted by cave2
Ah, thanks Altaman.
I was watching a french programe last night " Tout le monde en parle ",on channel 860 and it was the hole sceen ,16x9,the picture look good,how do I know its beeing broadcast in HD
SONY 50"| Expressvu 6100 Hd | 3100 & 4500 | North Bay ON
vaillan57 is offline
Old 2006-01-12, 12:25 PM   #356
FuzzyQball
I not sure what the best method is, but I just play with the zoom feature, and if it fills the who screen with normal zoom then it's HD. It would of been nice if there was some indication from the receiver. Programs that are SD on the HD channels will show black bars on the side if no zoom is used. Other than that, the clarity of the picture will be much better than normal SD. It's pretty obvious most of the time. One thing you should see is black or gray side bars during the commerials since most of them are still in SD.
Glenn
Old 2006-01-28, 11:32 AM   #357
KenM
Default Resetting Rx too often
I have a 6100 and it seems as though I have to unplug (reset) it far too frequently. It happened again last night, managed to get a hold of 1-888-skydish @ 5:30 AM. I could view the guide, but there was no picture on any channels. They also told me to check-off "HRV"(I think) instead of "Off Air" (where it was checked) in the HDTV set-up sub menu.
They also told me not to use a power bar , because the draw from my TV is causing this to happen I can't believe that but.......
Has anyone else experienced this kind of problem?
KenM is offline
Old 2006-01-30, 03:43 PM   #358
Boooger
Unhappy Need Ir Codes!
I just got the Philips Pronto Pro TSU6000 and i need to set up my Bell ExpressVu 6120 receiver but cannot find the hex codes ANYWHERE!
Please help!!
Boooger is offline
Old 2006-01-30, 04:02 PM   #359
Reave
What are the symptoms.. why do you have to reset?
Reave is offline
Old 2006-01-30, 04:49 PM   #360
KenM
The symptom is no picture at all.
I do get the guide, but the upper right corner remains a blank.
Also, when I select menu, the tabs show-up against a black background instead of the customary blue.
KenM is offline
Tags
6120, expressvu
