OTA Channel 10 Overlap in Southern Ontario/Rochester? - Canadian TV, Computing and Home Theatre Forums
Old 2011-04-22, 11:26 AM   #1
rob50312
Question OTA Channel 10 Overlap in Southern Ontario/Rochester?
While I hope the FCC rejects it when CKVR wants to increase their channel 10 power when they find out how poor their digital coverage will be.With Rochesters < 500 foot towers no reason for not allowing power increase.
CM 4248 at Buffalo,XG43 at Toronto,M4 at Buffalo,CH 11 yagi at Ham.
Last edited by stampeder; 2011-05-13 at 12:43 PM. Reason: moved to it's own thread
rob50312 is offline
Old 2011-05-04, 11:38 AM   #2
GeorgeMx
Why? The FCC rejected the power increase request because it would violate the agreement between the FCC and IC that governs interference between the two countries. The FCC gave WHEC 30 days to amend the application to come into compliance with the agreement. WHEC will probably require a directional antenna to make higher power work.
VHF stations clearly require much higher ERP than currently permitted by IC and FCC to provide coverage equal to their original analog contours. The agencies need to reach agreement on new higher levels and amend their regulations accordingly. When they do, this kind of problem will go away.
GeorgeMx is offline
Old 2011-05-04, 06:25 PM   #3
rob50312
Thumbs down
Yet CFPL London and CKVR will have a much larger interference zone but its okay with Broadcaster because there both the same owners and CFPL gets 45KW.Rochester signals barely reach Canadian soil yet get denied.Protectionism not management as usual with our regulators.
rob50312 is offline
Old 2011-05-04, 06:48 PM   #4
GeorgeMx
As I said, the FCC denied the power increase, not IC. From a technical perspective, IC and FCC both have an obligation to protect the signals of their broadcasters in their respective jurisdictions. The agreement between the FCC and IC provides the framework for protecting signals. This issue is about engineering RF coverage, not ideology.
GeorgeMx is offline
Old 2011-05-04, 09:06 PM   #5
rob50312
While then why are their so many Canadian signals causing problems with US reception of US signals.This whole thing is very much one sided and thats why it appears to be protectionism.CKVR on Channel 10 is poor management.Interference from adjacents and co-channel just stupid.Many other frequencies available and allotted for Barrie.Channel 10 should never be allotted for use in Barrie.
rob50312 is offline
Old 2011-05-04, 10:24 PM   #6
rob50312
WHEC needs to use a directional antenna away from Canada to protect
Barrie even tho they have been omni on 10 since 1960 while all the Toronto stations are much closer to Rochester and have omni patterns.Further Rochester towers are less than 150 metres while Toronto around 450 metres and its Rochester that needs the directional signals.Does not seem fair to me.CFTO -dt currently causing problems with a Rochester station on 40 yet barrie/rochester is no good.
rob50312 is offline
Old 2011-05-11, 11:19 PM   #7
GeorgeMx
CFPL has been omni from the start just like WHEC but has to go directional to increase power while protecting US stations on channel 10 in Ohio and Michigan. The technical issue goes both ways across the border.
Channel 10 can be used in Barrie and London if both stations are able to replicate their official analog contours using the channel. The allocation was done long before the difficulties with VHF coverage were evident. Interference between the two stations is not relevant if it occurs outside the official recognised contours.
GeorgeMx is offline
Old 2011-05-12, 06:17 PM   #8
rob50312
I am in Mississauga according to the contour i am in the adjacent interference zone for reception on CKVR-dt from CFTO-dt.I am inside their proposed coverage zone and had no issue receiving CKVR on analog 3.People in the Guelph area will get co channel as the contours with CFPL overlap.Good job planning I think not.People in Barrie are in reversed situation with adjacent problems.Its CKVR thats changing frequency and there are many better choices available.Channel 10 should not be used in Barrie
rob50312 is offline
Old 2011-05-12, 07:08 PM   #9
tvlurker
I think that the real problem with using channel 10 for both London and Barrie, is that although CTV as the common owner is free to waive any interference problems, those in the interference zone may have no alternative, and these are the only two /A\ stations in the area. From a public interest point of view, this is not good planning.
It's possible, though, with a VHF Yagi, a 20 dB delta between the signals should be achievable for at least one of the channel 10s.
tvlurker is offline
Old 2011-05-12, 08:45 PM   #10
GeorgeMx
Originally Posted by rob50312 View Post
I am in Mississauga
You probably receive 38, 39, 40 and 41 where you live without problems so why do you think 9 and 10 will be an issue?
GeorgeMx is offline
Old 2011-05-12, 10:22 PM   #11
rob50312
George thats true but channel 39 WIVB is at 790kw vs CFTO at 17kw.Those co -channel interference zones are stated on the contour map by the experts not me.I hope they are wrong.People in Buffalo/Niagara area are having problems with CFTO on 40 tho.
rob50312 is offline
Old 2011-05-19, 07:39 PM   #12
wilspin
Corporate Supporter
I don’t know if that’s a good argument. 40 in Rochester is low power analogue. I only get is during ideal conditions. I can’t see it affecting Toronto. 10 is rock solid here I can’t see what the power increase need are about. CFTO will be fine after they go back to 9.
60' Delhi tower,91XG,Y13-10,DB8,Tin Lee Traps,CM9521A,CM7777,CM7000,Winegard RC-1010 & HDA200,Samsung 32 LCD,2 WTV950Q
Twinntech supports Digital Home
wilspin is offline
Old 2011-05-20, 07:57 PM   #13
rob50312
Wilspin people near Rochester along lake ontario report problems caused by CFTO-dt because the Toronto CN tower stations are not directional yet Industry Canada expect the US signals to be directional.
rob50312 is offline
Old 2011-05-20, 08:30 PM   #14
majortom
very rarely have i ever seen cfto-dt / rf-40. maybe twice very brielfy.
I've always attributed that to the weak signal toward Buffalo, (-3dB Tvfool NM) and being co-channel with CBLN 40 in London.
Never noticed the LP Analog 40 in Rochester.
majortom is online now
Old 2011-05-21, 07:59 PM   #15
wilspin
Corporate Supporter
I have not heard of this co channel complaint in Roc. I cannot get CFTO 40 here, how can Rochester have issues with it?
wilspin is offline
OTA Forum Sponsor
