Brilliant App for Sat location!!! - Page 2 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Free to Air Satellite Television
Old 2012-05-26, 04:59 PM   #16
Kraven
Good find! Given more free time and better coding skills, I'd be interesting in attempting an FTA/OTA app. These sort of tools are almost a must have for any hobbist.
Cheers, K
6 ft BUD, motorized 39" KU, S10, Viewsat Ultra, CM 4228, home made SBGH
Kraven is offline
Old 2012-05-27, 03:13 PM   #17
ChannelMaster
Foks, I've been using the Dishpointer AR for Iphone for the past two years and even though it does a fair job at showing elevation along the arc, there's little accuracy to be had from a device that uses a mixture of Assisted-GPS (not true GPS), gross compass and gyroscopes.
As you get used to the app, you'll, of course, want to stay clear of any metallic structure (like appartment buildings and such. You can use it for instance to evaluate if a bird is clear of tree lines but you'll have to swing the iphone left and right quite a bit before settling on an average result if you know what I mean.
Going digital with a pair of CM4228a pointing due south fed into a Winegard SD-3700 antenna coupler @220 ft
ChannelMaster is offline
Old 2012-05-29, 09:03 AM   #18
Jake
A-GPS is actually GPS + network or cell positioning. So that is a good thing. So unless you are in a heavily obstructed environment GPS will be sufficient. Also, there are no gyroscopes in these devices. Just a 3-axis accelerometer plus a digital compass.
Jake is offline
FTA Forum Sponsor
