#1 | |
Customers will be able to enjoy MTS Ultimate TV and faster Internet speeds
Steinbach residents will soon have access to the next generation of high definition television and the fastest broadband connections available as MTS deploys its fibre-to-the-home network (FiON) in the community over the coming months. Quote:
They haven't updated their FiON website yet.
First booze, now this? Whooo hooo!
I wonder what are the exact internet speed plans you can get on the FiON network, or are they the same as in Winnipeg?
I checked an address in Selkirk that has FTTH. The plans are the same as Winnipeg except they don't have the Bolt plan (which is basically shared bandwidth with TV). The plans are:
Light 256 Kbps Lightning 7.5 Mbps MAX 15 Mbps Super MAX 25 Mbps |
Are they the same prices?
Yes, the list prices are the same. They probably have local promos they advertise with flyers or custom mailers as a new neighbourhood is lit up.
Kildonan Green is also a Fion development though I do not offically see it listed anywhere.
#9 |
#10 |
I'm moving to the Sage Creek development and MTS has told me I'll be on their fiber network.
Does anyone know if I'll be keeping my 2wire router, or do they use something new for fiber? If its new, is it wireless? I kind of like my 2wire router because I prefer using wired connections for my equipment. Too many problems with wireless. Thanks |
#11 |
You'll probly even carry over your current equipment as the 3800 2wire is common for running off of the fibers ONT. Unless you allready have the 3801, then i dunno, cause there is no just cause for the boosted 3801 upon the fiber. p.s. expect twice the internet speeds you were getting. (Y)
#12 |
they will give you a 3800. 3801s serve no purpose in a fiber install becuase you are not using the modem part of it. the fiber ONT plugs into the red broadband rj45 on the back of the 2wire. they want to use the 3800's for fiber installs becuase we have so many of them and need to use them somewhere and eventually no one on copper will use a 3800, only a 3801.
#13 |
there is separate equipment for fiber compared to copper. the 3800 wont be used at all, a 3812 is.
#14 |
Actually, i think you are confused
Authorized Service Provider for MTS Allstream. Any views expressed are my own. |
#15 |
Great news for Steinbach.. Too bad we can't get MTS internet services in the Morris area..
-C. |
| Tags |
| fibre, ftth, mts tv |
