Wiring basement - Need to run twisted pair to utility room -What do I buy? - Page 2 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Telus > Telus High Speed Internet and Home Phone
Old 2011-03-27, 05:54 PM   #16
aqua
Wow. Thank you all for your comments. I don't have any demarcation points on the house for either Shaw or Telus - both just run in through the wall. What I have decided to do is run cat5e (either one run or maybe two) to two different spots on the house and leave access panels in the ceiling so I can get at them later and drill out from the wall if I need to punch them out later. I'm also going to have to extend the ground wire to the second location. Right now the services both come in to the old power mast but there is a new one as it had to get moved when I upgraded to 100 AMP service so I will run near both masts, in case the old one gets removed when I reside the house.
It is all a major pain but it is what it is. I don't think I can do anything else right now seeing as I am going to reside soon and there is no demarcation point to run to.
aqua is offline
Old 2011-03-27, 06:39 PM   #17
dscott01
That sounds like it will cover all of your bases.
dscott01 is offline
Old 2011-03-27, 07:09 PM   #18
JamesK
The ground lead is supposed to be short. If it's too long, the wire inductance will prevent lightning discharges from easily reaching ground and causing them to take another path through your equipment.
The following program contains immature subject matter.
Viewer discretion is advised.
JamesK is online now
Old 2011-03-27, 11:27 PM   #19
aqua
I know Telus says it shouldn't exceed 6 meters but if I have to move to the new mast I can only do so much and might be a bit over that. Again, I can only do so much.
aqua is offline
Old 2011-03-28, 07:44 AM   #20
JamesK
Better see what Telus wants to do first, as they're responsible for ensuring a good ground connection.
