Recommend a 32" TV? - Canadian TV, Computing and Home Theatre Forums
Old 2011-03-21, 03:18 PM   #1
Positive Climb
Default Recommend a 32" TV?
Can somebody please recommend a 32" TV preferably between $300-$350?
Also, is there going to be a huge difference between 720p and 1080p?
Thanks.
Positive Climb is offline
Old 2011-03-21, 07:23 PM   #2
cooper83
See this thread: http://digitalhome.ca/forum/showthread.php?t=137950
If you are using it as a computer monitor, 1080p is best.
What are you connecting to?
Lots & lots of info in this forum if you spend a bit of time reading & searching.
Panasonic TH-42PE7U plasma, Toshiba HD-D3, PS3, Shaw DCX3400, Yamaha HTR-6160, Polk 6.1, Belkin PF30, Harmony 700
cooper83 is offline
