Ceiling recess size for projector screen - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > Home Theatre Construction
Old 2011-02-22, 08:40 PM   #1
lastyear4gt
Default Ceiling recess size for projector screen
Im just in the stages of framing the bulk heads in my basement and want to rough in a recess in the bulkhead to accept up to a 106" projector screen with a plug and cat 5 cable for triggering drop down. I've done some searching on line and found no info as far as dimensions of the pocket. Can anyone help?
lastyear4gt is offline
Old 2011-03-02, 08:38 PM   #2
mct123
My theater pics:
http://s842.photobucket.com/albums/zz343/mct123/
mct123 is offline
Old 2011-03-02, 08:46 PM   #3
asaood
i have the same problem. i am going to finish my basement. i like to put my projector in the bulkhead. any body help me how . i am thinking to put grill in the front with the hole for the lens for ventilation. any idea please help
asaood is offline
Old 2011-03-03, 11:16 AM   #4
eXcessive
Its a fairly difficult thing to do until you actually have the screen, my solution was to just mount the screen to the bulk head then I mounted L brackets to a piece of wood and covered the housing.
This way its covered unless your directly underneath it and if anything ever happens to the screen I can still access it to get it out pretty easily.
eXcessive is offline
Old 2011-03-03, 08:56 PM   #5
lastyear4gt
I'm not so sure putting the projector in the bulkhead would be a great idea I would say over heating would be an issue.
I found a place in Toronto that seems to have very reasonable prices on motorized screens I think I will just have to get the screen and work it into the finishing of the drop ceiling.
Old 2011-03-11, 10:43 AM   #6
eXcessive
The motors aren't big enough nor run long enough or fast enough to cause any kind of heating concern.
And you wouldn't mount it in the bulkhead just on it then I put the board infront of the screen housing and it then looks like its coming out of the ceiling.
Old 2011-03-11, 12:37 PM   #7
lastyear4gt
You might want to read my post again
