I have Bell's Fibe-12 which comes with their 2 wire modem with built-in G router. I am able to get 11 MBps, wired or wirelessly which is close enough (probably more than 12Mbps at demarc point) but the range / signal strength isn't very good throughout the house (given G-router).
So, I decided to try another router (Dlink Xtreme N 655). I disabled the Bell G router and put it in bridge mode, and connected D-Link router to it, but for some reason my bandwidth cuts into half (5 Mbps) - doesn't matter if the test device is wired directly to D-link router or wirelessly. I also tried another D-link G router and same result (5 Mbps). With the built-in Bell G router, I am able to get 11Mbps (wired or wirelessly). Any obvious reason why this is happening and what can I change to get the full bandwidth on the D-link router (or any other N-router that I should consider)? Thanks for any suggestions. Bell online tech played around with their modem / router with no change in results but it didn't seem like she knew what she was doing. |
The Bell 2wire is a good modem/router. You can increase the power for the wireless in the modem settings.
I found exactly the same thing ... speed is cut to half!
With the 2-Wire router, as mentioned, you can up the power output of the Wirelss signal. I've played with mine an can actually pick up a strong signal from 4 houses away.
Why would you need an additional router? You can have 4 wired devices and 4 wireless devices attached at once? Nem, who loves taking his PS3 to his neighbours house and streaming video.
The preceding post and all opinions expressed are solely those of the poster and do not reflect the opinions of any other person or business |
Many reasons, here are a couple
1) N wireless vs G on the 2wire 2) Lack of any meaningful port forwarding options |
Agreed, but for the average user, they don't need or use those things.
Nem, who is without a witty comment about averages.
Has anyone been able to set up the 2 Wire modem so that you can access a Windows Home Server. It requires port 443 to be open which I believe I have done in the 2 Wire modem setup, but when I try to access the server’s web page it says it can find it but security is blocking it. Any advice would be appreciated. Thanks.
