Will a plasma fit my scenerio? - Canadian TV, Computing and Home Theatre Forums
Closed Thread
Old 2011-01-28, 06:30 PM   #1
cableRules
Default Will a plasma fit my scenerio?
I was told to stay away from plasma for 3 reasons. Crappy pic in room with daylight. 1 repair shop I talked to say today's plasmas are better then the first ones, but still behind LED in quality and amount of repairs needed. Colors are on the dark side, not bright.
Depends where you go the sales people are pushing one over another. Future shop/BB push LEd. Another big seller here hates LED and push plasma.
I have a room where there is a large window with no direct sunlight. But I do have blinds that totaly block out most day light. I took back a LG 55" because even at 12 ft away it bothers my eyes. So I look for a 50" LED, but most are either 46 or 55.
Will mostly be used for reg programs some HD, some gaming, some DVD.
So long story short, I was thinking of trying a 50" plasma as a clerk told me the picture is less bright and less blurring, a more natural picture. So maybe it won't bother my eyes.
What you guys/gals think? Which model is good for $1499 price max?
Thks
Wayne
cableRules is offline
Old 2011-01-29, 02:10 AM   #2
jlet
Also see: http://www.digitalhome.ca/forum/showthread.php?t=68800 Five Reasons to pick Plasma over LCD (Aug 2007)
SA8300HD; Panasonic TH-50PZ850; Sony STR-DA5ES; Tannoy: Arden, S8C, S8LR; SVS 16-46PC+; Oppo 971; Harmony 659/680
jlet is offline
Old 2011-01-29, 01:07 PM   #3
Spike4881
Let me put it to you this way: when I was looking for my tv, most of the sales reps I talked to try to sell me a Samsung LCD or Sony, as I was looking at a LCD at the time. When I asked what THEY had at home, every single one said plasma.
Take that for what it's worth.
I'm not a plasma fan boy either - it just suited my needs.
Panasonic TC-P50G10 - Sony HT-CT150 - Sony PS3 Slim 250gb - Nintendo Wii - WD TV Live
Spike4881 is offline
Old 2011-01-29, 03:54 PM   #4
cableRules
I just want to correct part of this topic. After talking to now 3 repair shops. 2 were ok with plasma that do warranty work. It's only the out of warranty shop that gives them the thumbs down. I think this is because he sees the older plasmas and not the new improved ones of past few years.
Old 2011-01-29, 04:05 PM   #5
legacy
I bought a Panny 50 inch Plasma in early Dec/10. I love the thing. I am still amazed at the color and contrast ratio it offers every time I turn it on. I bought the entry level C2 model and have no issues at all. The TV is in a controled lit room so light reflection is not a issue.
The picture is natural, no Soap opera affect, clean sharp no blur picture. SD even looks decent on it. The TV is so so much better then my older 50 inch rear projection 3LCD. When shopping around for a TV a couple months back, most sales guys I asked what they owned also said plasma's too. One FS. sales guy said he had a Insignia LCD . I had a open mind to any set. I am glad I chose a Plasma over LCD or LED for the money spent.
legacy is offline
Old 2011-01-29, 04:24 PM   #6
cableRules
Does DH have the content of that link to review? Or did any one save it?
Thks
Old 2011-01-29, 05:10 PM   #7
peano
If you want the best blacks, no motion blur, realistic colours and quite decent SD - go with plasma.
LCD (LED) looks good in torch mode in the stores and thats about it - with the rare exception.
peano is offline
Old 2011-01-29, 09:24 PM   #8
cableRules
2009 pany plasmas have a problem with black levels turning grey in 1500 hrs or 1 yr aprox. Don't know if that's improved for 2010. This includes the G10 model.
Old 2011-01-29, 09:41 PM   #9
cableRules
Well today I was instore and have to tell you that the plasma S2 & G20/25 picture detail is very grainy, fuzzy when compared to a Samsung 6300 LED. The clerks even agreed with me. I saw this in 2 stores on the G25. Side by side they don't cut it with LEd.
Now I know you will tell me they in torch mode and when you get them home and tweak them they will be better. OK maybe. But I think that the better quality pic in torch mode will still be the better quality at home. Unless Plasma has some kind of miracle switch.
Old 2011-01-29, 09:43 PM   #10
DSgamby
or that the plasma was hooked up to show SD and the LED hooked up to show HD
DSgamby is online now
Old 2011-01-29, 09:45 PM   #11
cableRules
In this case I asked them. They said everything was running on same shaw signal.
Old 2011-01-29, 09:55 PM   #12
DSgamby
and you believe him?
Old 2011-01-29, 09:58 PM   #13
filper
I have a Panasonic 50G25 in my media room on the second floor which faces due South with a wall of windows, the anti-reflective screen on this model works great.
simplicity is genius...
filper is online now
Old 2011-01-29, 10:25 PM   #14
Spike4881
So I've heard. I'm not too concerned as I've had it for a year and have seen no difference yet. I'm not going to defend plasma - if you prefer LCD that's your choice. Good luck with your purchase.
Old 2011-01-29, 11:03 PM   #15
cableRules
Yes why not, the entive TV department was running the same thing and was up on all the TV's. The clerk said shaw cable 720P. I asked him why a best buy promo was coming off shaw cable? No logical answer. Well whatever signal and picture, it was up on all screens.
Closed Thread
