#91 | |||||
Has Canada ever purchased an untested/vetted design before? Quote:
Can you explain how adrenalin of the moment is less likely to affect a fighter pilot than a person watching a monitor? Quote:
#92 | |
The following program contains immature subject matter. Viewer discretion is advised. |
#93 | |
Explain how this is compatible with how you intercept an enemy aircraft. No one has ever had an opportunity to test what an F22 can actually do, but you can be sure that people are thinking of alternate ways to figure out how to 'see' it. |
#94 | |
BTW, the '60s vintange SR-71 Blackbird employed some early stealth technologies. It could do better than 3x the speed of sound and while never engaged in combat (it carried no weapons), it was certainly targeted. Bottom line, if you're likely to be shot at or want to use the element of surprise, stealth comes in handy.
#95 | |
cr9527, welcome here and thanks for citing previous posts.
Nothing personal, but I can't just take your word on it, and I hope you won't use the "um, no" anymore. I get the sense that your replies somewhat agree but generally don't agree with many of my concerns, but I'm not sensing a convincing set of proofs that the F-35 is the right aircraft for our needs. I think you've misread some previous posts too (i.e. confusing air-to-air refueling with intercontinental air-to-air refueling capability, "ground-based detection" and it's command-and-control with SAMs, remotely-piloted drones with Artificial Intelligence, etc.). Quote:
As the North and the Arctic are opened to greater investment and the coastal ice floes melt away, speed and reliability are of the essence for interceptor/patrol aircraft investigating sudden incursions and irregularities in our air space. While routine patrols by more traditional aircraft will remain important, the rapid response of NORAD-controlled interceptor aircraft will be increasingly important to sovereignty. So, for the interceptor role, the F-35 would be a slower, more expensive, single engined aircraft with wasted features. By comparison, a tried-and-true aircraft such as the Super Hornet, Rafale, Eurofighter, or equivalent would do what is required at a much higher speed, along with the increased survivability of a twin-engine layout, all at a lower cost for the package now and in the future. As I've stated, the Super Hornet is the most sensible way to go. Today we face the need for speed and reliability of our interceptors in our air space. For many reasons, the F-35 is not the answer. Last edited by stampeder; 2011-05-09 at 01:06 PM. |
#96 | |||
The second you turn on your air combat radar or use your radios you are no longer in any way stealthy. Quote:
#97 | ||
#98 |
And not be detected while getting there fast. If your target doesn't see you coming (they also use radar etc. just to find you) you're more likely to be successful as the enemy is less likely to be able to evade or fire back at you. The Blackbird's defences relied largely on altitude and speed. It could simply out climb anything chasing it. However, reduced radar signature etc. means it'll also take longer for the enemy to find you. Also, the Blackbird had the same "ancestor" as the YF-12 Interceptor. Interceptors and reconnaisance planes share some common characteristics such as high speed, altitude and *STEALTH*.
#99 |
NORAD interceptors are vectored towards their targets based on satellite and ground-based detection, along with other less direct means (SIGINT, spycraft, etc.) so any aircrew aboard a hostile aircraft already know that we are trying hard to "paint" their aircraft for lock-on and that our birds are coming at them. Our interceptors would never have the element of surprise, so the need for our interceptors to likewise be stealthy is moot since they know just as well as we do that a world of hurt is on the way. They hope that their stealthiness will either prevail or at least buy them some time to attack their secondary if the main objective is aborted.
By the same token, sovereignty flights definitely don't need stealth as they are meant to show the flag! |
#100 | |||||||||||||||
Looking at it another way, should the enemy perform SEAD/DEAD missions against us, legacy fighters will be completely useless should they use stealth fighters for cover, along with our SAM network. And yes, having fighters patrolling the arctic provides far more coverage than a SAM network against a competent foe. Fighters are far less vulnerable to NOE. Quote:
Stealth, while the purpose is to remain hidden, also provides excellent survivability in aerial combat. Quote:
Let us remove stealth from the equation, and strap on wing tanks on the F-35. What we get is a great fighter with the most advanced active and passive sensors in the world, second only to the F-22, with tremendous range. Adding onto that, the fighter is fully network integrated, meaning all data, including those that supply targeting data, allowing for shared sensors and weapons between aircraft. This is unparalleled by any other fighter, including the F-22. On range, F-35 while maintaining stealth, has a combat radius of a patrol missing > 750nm. This is comparable to the competitors, i.e. Typhoon of 750nm, although rafale with 3 giant fuel tanks can put out 1000nm. F-35, when having 8,000lb of external fuel in theory can achieve as well. Then we have flexibility, when NATO calls us to provide air support, or air cover, F-35's multirole capability is unmatched by any other aircraft. This is due to the combination of F-35's EOTS, HMDS, network integration and large payload capability. Then we have price. F-35 at roughly the price of 75 million a plane as shown in my previous post, is comparable to the Super Hornets and Rafale, while lower than the Typhoon. Gripens while relatively cheaper at ~50 Million, is no where near as capable in payload, range, sensors, avionics, or just about any aspect of the plane. So to sum it up, F-35, while disregarding stealth, costs less, performs better, and can fly just as far as the competitors. QED? Quote:
This leaves the super hornet as the only contender, but if you look at the capabilities of the super hornet, the F-35 is still a better choice. Quote:
[QUOTE=GrimJack;1259644]Right. Except that when you're an interceptor, which to my knowledge is the main reason these planes are being purchased, you're the hunter. They don't have the range to fly around and hope to passively encounter the enemy. Another mission for interceptors is routine patrols. Quote:
Remember you require 3 things in order for an enemy to shoot at you. 1. He needs to detect you. Turning on radar would allow the enemy to know your presence, but not necessarily where you are. 2. He needs to track you with his radar. This means, his radar must be able to maintain prolonged detection of your aircraft, and has nothing to do with your radar being on. 3. Finally, the hardest of all, his Missile needs to track you. The tiny radar head of the missile makes it extremely difficult tot rack onto a stealth fighter. So, even if you are waving a giant EM flag that you are here, they still can't shoot at you, therefore, you are still "Stealthy". Quote:
As one fighter pilot said when fighting against F-22 in mock exercises, The most frustrating part was when "I"'m right behind the Raptor, I still cannot provide a lock. While surprise is a big advantage of stealth, Survivability is a far more important one. People always confuse air to air combat as if once a fighter knows where the stealth aircraft is, then the fighter can provide a firing solution. |
#101 |
I see that there is still confusion about SAMs, misunderstandings about the interceptor role of our new fighter, as well as disbelief of financial estimates from the government watchdogs responsible for tracking such expenses. I do not accept enthusiastic superlatives as "proof". To me it is the kind of cheerleading that got us into this mess in the first place, especially with no competitive bid process that would be based on a well published, debated, and transparent definition of the role it must fill.
My stake in this deal is as a taxpayer, and I do not accept that it has been properly handled. What is your stake in the decision? |
#102 | |
Australia for example purchased Super Hornets at $191.7 Million per copy including infrastructure, training, and support for 10 years Using Harper Government's calculations, We are paying $138.5 Million per copy with infrastructure + $92.3 Million per copy for support over 20 years, or $46.15 million for 10 years. or Using my calculations based on DoD's budget data, $121.5 Million per copy with infrastructure, training, etc + $121.5 million per copy for support over life time, assume life time costs of 30 years, meaning for 10 years, $40.5 million for maintenance and support per plane. Or from pentagon on $443 Billion for 35 years for 2443 aircraft for support and maintenance in 2002 inflation rate, putting it @ $121.5 Million + $62.3 Million for 10 years Hell, for a good measure, according to NAVAIR, F-35 will cost $30.7 thousand per flight hour to operate. Given the full service life of an aircraft is 8,000 flight hours, and for 10 years/35, the maintenance costs is estimated at around $70.2 Million for 10 years. To compare the 2, Purchasing Super Hornets will cost us $191.7 million for 10 years vs F-35 costing us $184.7 Million(Harper), or $162 million (mine) or $183.8 Million (pentagon) or $191.7 Million (NAVAIR) for 10 years. Food for thought, F-35 out performs the Super Hornet in EVERY aspect of a fighter imaginable, and yet comes out cheaper (or same with NAVAIR est) No other "contender" costs less than the F-35, or performs better in any task. What more do you need to know? P.S. The Sec of Air Force has officially stated that F-35 is the best and only jet to meet our requirements. I don't know about you, but this is a strong indicator that F-35 fills in our needs. So, something that costs less, and fills our role better than any other fighter, I think it's a no brainer. Last edited by cr9527; 2011-05-10 at 12:24 AM. |
#103 |
Your arithmetic is contradicted by governmental authorities who officially go on record with documentation. Since we can sink our teeth into those numbers, they prevail.
BTW, I am not Admin. Again I ask you, what is your stake in all this? |
#104 | |
PBO's methodology in estimating price is flawed and has been demonstrated as such by numerous sources. GAO's Mike Sullivan doesn't know heads or tails with regards to acquisition process as evident by his contradictory statement compared to the Actual official budget estimates here: http://www.saffm.hq.af.mil/shared/me...110211-038.pdf Both of them have demonstrated zero knowledge in this field. Here is the comparison between costs of PBO, SAR, and actual costs. ![]() My arithmetic based on actual budget information is far more accurate than PBO's claim of 130-150 million and GAO's 100-130 million a piece. My stake, is that I love the plane, and I am sick and tired of seeing misinformation, both official and unofficial. |
#105 |
Wouldn't it be more fair to say you love the "concept" of the plane, since the real plane is still far away? It's certainly less than clear, as far as I can tell, that it'll end up performing anywhere near to what it's supposed to.
