Flickering on black/white lines close together - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Rogers Communications > Rogers Cable TV
Old 2011-01-08, 02:26 AM   #1
compguy
Default Flickering on black/white lines close together
I am noticing that I get flickering on say small black text and a white background. This is especially true of any black/white/black lines that are close together. It's kind of had to describe. Anyways if freeze the frame (my Sony tv can do that) the flickering stops so I know it's not the tv. Anyone else notice this? I wonder if it's just crappy compression?!?
compguy is offline
Old 2011-01-09, 10:19 AM   #2
PannyPlasmaMark
not sure of flickering but in general i feel my hd picture looks not as crisp as of last night. Not sure why. The only change i made was adding a ps3 and another HDMI port used...but thats gotta be paranoia on my part. Still i dont think my HD picture is the same.
PannyPlasmaMark is offline
Old 2011-01-09, 10:33 AM   #3
Mark: Did you use another input on the TV that is calibrated differently, or not calibrated? It's possible if I didn't copy the settings over to the other input that you're seeing differences in the input calibration. Check the picture settings on both inputs.
compguy This is pretty normal, especially for SD signals. If you're seeing it on true HD, that's pretty rare and a proper optimization may help.
http://www.digitalhome.ca/forum/showthread.php?t=76161
57 is offline
Old 2011-01-09, 01:13 PM   #4
ScaryBob
Flickering with interlaced modes is quite common, especially with computer generated graphics. To get rid of it, use a progressive mode at the source (480p, 720p or 1080p), instead of interlaced (480i or 1080i.) This might not get rid of all flickering since some sources use scaling for interlaced content.
ScaryBob is offline
