Connecting Xbox 360 to PC? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Entertainment > Video Game Consoles and PC Gaming
Old 2011-01-01, 05:07 PM   #1
Keebler Elf
Question Connecting Xbox 360 to PC?
I have connected my Xbox 360 to my PC via wireless network and I can get access to movies in my Public Videos folder so I know it works.
However, is there a way to change this so I can access a different folder or folders? I don't want to move all my movies to the Public Videos folder and it would be much better if I could access other folders on my PC via my Xbox 360.
Can anybody help?
Keebler Elf is offline
Old 2011-01-01, 06:43 PM   #2
Eluder
Got add the other folders to Windows Media Player (assuming that is what you are using to share).
Eluder is offline
Old 2011-01-01, 07:10 PM   #3
Keebler Elf
Thanks. How do I do that?
Old 2011-01-01, 11:31 PM   #4
Eluder
Depends on the version of WMP you're using but for WMP 12 under Win7, it's File->Manage Libraries->Video then click Add and select the folders you're looking for.
Eluder is offline
Old 2011-01-02, 06:50 PM   #5
Keebler Elf
Thanks. Does it physically move/copy the files to the library or just link to them?
Old 2011-01-02, 11:20 PM   #6
Eluder
Just a link.
Eluder is offline
Old 2011-01-03, 06:44 PM   #7
Keebler Elf
Thanks! Much appreciated!
