#646 |
I don't believe that reading one file at approx. 20Mb/s and writing another at 20Mb/s is as easy as you seem to believe. All that data has to be moved around and processed by the entire system, so the hard drive itself is but one component.
Yes, the 8000HD is a little rough around the edges, but I don't have the bitterness towards it that you folks seem to. Aside from one corrupt recording that caused a reboot everytime I tried to play it, I've been free of major problems. (knock on wood!) |
#647 |
One thing that I do to minimize "glitches" with the unit is to wait for the unit to respond, or complete a task before pressing another button.
For example, If I ask the unit to begin playing a programme, but realize that I want to change the "format" from 480P to 1080i, I wait until the programme has started playing. If I press the "settings-scrollup-format" buttons while the unit is still searching, I sometimes get a "lockup" (unit unresponsive to remote). Since it doesn't take any longer to "wait", I avoid the "lockups". If possible, I schedule recordings for "early morning", or during the day, when I'm not watching something (recorded) on the unit, so that it doesn't have to "multitask". Same on my computer, I try to minimize multitasking. Yes, computers are supposed to multitask, however, the number of "issues" or "crashes" that arise from "doing too much" increase. It's also been shown that personal productivity actually decreases with multitasking. It's better to do one thing well, then go on to the other...
#648 | ||
Toshiba 62HM84 | SA 8300HD | HD-DVD/Blu-ray HTPC | XBox360 | Playstation 3
Denon AVR-2807 | URC MX-650 |
#649 |
I'll tell you what. Start playing back an HD clip on your PC, then start copying two huge files in the background. Let's see if your PC does better than the 8000HD!
#650 | |
Pioneer Elite PRO-730HD | Elite DV-59AVi | Marantz SR8200 | Mirage OM series | Rogers/Cisco 8642HD, SA4250HD |
#651 | |
That being said, with a custom OS, a whole lot more knowledge in programming, a bunch of cash, and a bit of extra EEPROM, I'm quite sure I could make a PC that does FAR more than the 8000/HD does with (basically) standard PC components.
#652 | |
If all you want to do is dump pre-compressed files to the HD at less than 10MB/s, then no sweat at all. Playback is another matter, but for obvious reasons. Playback requires MPEG decompression, which the PC architecture is not optimized to reproduce (especially since it does everything else). Sure, a pentium II, III, IV could do it...but it is not dedicated for this kind of work. Now, if you had a dedicated AV subsystem (say on a card) solely for decompressing and output of mpeg 2 signals, then all of this would be childsplay on some of the cheapest PC's on the market today. A machine like the 8000HD clearly has dedicated mpeg decoder hardware...its the same hardware that allows you to watch live TV without dropping frames or audio. The rest is run-of-the-mill (and cheap) file IO...handled by an independant bus system....capable of much better than 10MB/s. There really is no good reason why the HD bus can't match the bitrate of a single HD playback, even if it is recording two other shows at the same time. Just as a side note: I have tried Hi-Def recording on my new unit (just recieved today). I recorded a PBS broadcast with tons of fly-overs and pans...didn't notice a single frame drop (some of it was fairly quick). I will post my experiences with the unit here once I get more experience with it. |
#653 | ||
#654 | ||
#655 |
OK, you guys win! How can I argue against all that great theory!
#656 |
I still think its trying to compress something - if it was a problem with playback by taxing the system then it shouldn't always happen at exactly the same place, regardless of whether there are other programs being recorded, etc. Seems like when there's too much work to compress between frames it simply gives up and moves to the next frame, probably just repeating the last. Again, I never see these problems live, but they are readily reproducible on playback regardless of what the unit is doing. I still think the problems with the Sopranos are different, maybe some sort of problem in how CTV gets the material and broadcasts it. I'll have to try watching it live sometime to be sure.
Jethro - LG 60PG60, SA8300HD, Yam HTR6190, Polk, Harmony 680, Xbox360 (Games), PS3 (BluRay Player) |
#657 | ||
Still, I can't think of any good reason why the 8000HD would do that, since there is (as i said), plenty of bandwidth and buffer to go around. Quote:
Now, we know that the SA8000HD decoder can handle the 'busy frames' without drops via a live feed. This means that if HD playback drops frames, the problem is coming from the system that passes the data to the decoder. (edit: IOW, our data transfer is not able to feed the bits into the decoder fast enough on busy frames compared to live feed coax). But it would be to every hardware engineer's amazement if SA couldn't build a system that could pass data to the decoder from the HD at ~10MB/second in this day and age. I have only watched a single Hi-def recorded program (a PBS program about the everglades that seems to repeat quite often). I have not yet noticed any dropped frames in the fly-bys and pans. I'll keep looking. Last edited by mike infinity; 2004-11-03 at 01:43 PM. |
#658 | |
Sent the following today to Rogers...
#659 |
Now don't you dare be asking for an 8300HD upgrade!
#660 | |
I would exchange for the simple reason that SA are likely to have fixed several of the little niggles and glitches that are (apparently) present on the 8000HD. For existing 8000HD owners, I sincerely hope that SA addresses whatever firmware bugs that come up...and that they activate the ports that should be active on that unit. I also sincerely hope that the new unit does not come along with alpha or beta firmware...bringing forth another swath of frustrating experiences for the end-users (the people who are giving everyone at rogers and SA their paychecks). |
