house alarm dialing - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Digital Industry Forums > Internet, Landline and Wireless Phone
Old 2010-12-19, 12:46 AM   #1
crowbar36
Default house alarm dialing
if phone calls into my house are being awnsered by the alarm , what can i do ? the alarm should be able to be programmed ? i know the alarm calls out on its own to the monitoring station , but the alarm picks up incoming calls and callers hear tones , like fax .
crowbar36 is offline
Old 2010-12-19, 08:54 AM   #2
ALSto
Isn't this something you should call the alarm company about? Sounds like something is not correctly wired.
Allen...
ALSto is offline
Old 2010-12-25, 11:06 AM   #3
dogxray
the programming of the alarm has to be setup to wait until about 8 or more rings before it picks up. Having it set to answer is so the alarm company can program the alarm from there office or look into any types of faults like false alarms or low battery. Get them to reset the number of rings before it picks up
Jeff
dogxray is offline
Old 2010-12-26, 01:07 AM   #4
Macman
I agree about the wiring. If the alarm is not seizing the line, causing people to hear the alarm calling out to the station, it sounds like it's not wired for priority/line seizure over the other jacks in the house.
From my training/experience, alarms are supposed to be wired like this:
Phone line from outside ---> Alarm "in" (red/green pair)
Phone jacks from inside ---> Alarm "out" (black/yellow) *Better to have each jack terminated on a block instead of all the pairs twisted together.
This is so that the alarm cuts off the phone jacks in an alarm situation so that someone can't just pick up the phone and prevent the alarm from dialing out.
I don't know too much about alarms, but it seems to me that alarm control panels check for dial tone (or at least phone line voltage) every so often (5 or 10 minutes?) and if it goes away, most systems make the keypad beep to indicate trouble.
I've personally experienced this with another phone company's service in the MIDDLE OF THE NIGHT on 2 different occasions But anyway! If the system is armed, it may (or should?) even set off the siren.
Sorry if that's a little long.
Authorized Service Provider for MTS Allstream. Any views expressed are my own.
Macman is offline
Old 2010-12-26, 02:37 AM   #5
Paolo
it sounds like the alarm IS seizing the line, but when a call comes in, the alarm is dialing, when it should be "detecting" a dial tone first before calling out to the monitoring station. there might be a change in configuration to "wait for dialtone" before it calls out, otherwise it should hang up and try again acording to the retry parameter
Paolo is offline
