BBC World News made in SD widescreen - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Entertainment > What's On Television?
Old 2010-12-11, 08:02 PM   #1
2415
Default BBC World News made in SD widescreen
Do you know that BBC World News is now in SD widescreen? The international news channel owned by the BBC went widescreen probably in 2007. It's real, so see this (from a British website):
Although its graphics are in 4:3 safe area, it is broadcasting in 14:9 on a 4:3 version of this channel (with top and bottom black bars).
The widescreen version of BBC World News is not available in Canada (using the 4:3 version), but I think it's available in Europe (excluding the UK). I saw BBC World News on KCTS-DT (the HD version, where I have it on Bell TV) and it's in 4:3 version instead of a widescreen version.
You can see more pictures of BBC World News in widescreen here, but if you see some images that just says "BBC News" at the bottom in addition to the clock, it's from the BBC News Channel (which is available only in the UK and is commercial free) where BBC World News programs are simulcasting on this channel.
2415 is offline
Old 2010-12-11, 08:25 PM   #2
DT1
When BBC News comes on BBC America HD late night/early morning it just about reaches the edge of the screen.
DT1 is offline
Old 2010-12-11, 09:35 PM   #3
JamesK
FWIW, I just tuned to BBC World on Rogers ch 37 and saw a letterbox that was the same width as a SD screen, but with narrower bars than typical letterbox. I guess that's the 14:9 (I wonder where they got that ratio?) wide screen on SD channel.
IIRC, there's also a 5:3 format in Europe.
The following program contains immature subject matter.
Viewer discretion is advised.
JamesK is offline
Old 2010-12-11, 10:45 PM   #4
2415
BBC World News broadcasts in SD, not HD as BBC News does not have HD equipment.
I think you're right about this. BBC World News broadcasts in three aspect ratio versions, made in SD; 4:3 (with 14:9 letterbox), 16:9 widescreen and 5:3.
2415 is offline
