Windows Firewall won't allow me to connect to Airport Express or ATV - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Computing > Windows Computing
Old 2010-12-09, 10:05 AM   #1
hugh
Default Windows Firewall won't allow me to connect to Airport Express or ATV
I have an Airport Express and Apple TV that I like to use as speakers when playing music from iTunes.
Recently I have been getting an error (-15000) in iTunes when I try to use those speakers for output. Interestingly, if I turn off the Windows Firewall, I can stream music through both devices.
I had the problems months ago when I upgrade my Airvideo server. I downgraded to an older AirVideo server and the problem appeared to disappear. I upgraded back to Airvideo a few weeks and everything seemed fine but the problem returned in the last two days.
When I check "Allow a program through the firewall", I find that Apple Bonjour and Itunes are allowed.
Anyone have similar issues?
hugh is offline
Old 2010-12-09, 10:07 AM   #2
hugh
Also noteworthy:
If I turn off the firewall, I can connect. If I turn the firewall back on, iTunes remains connected to the Airport Express BUT if I shut iTunes down and restart, the problem returns.
hugh is offline
Old 2010-12-09, 11:56 AM   #3
stampeder
Anything in here from Apple that helps?
http://support.apple.com/kb/HT2553?viewlocale=en_US
http://support.apple.com/kb/ts2709
stampeder is offline
Old 2010-12-09, 12:30 PM   #4
hugh
Unfortunately nothing that I can see. The most obvious is checking permissions for iTunes and Bonjour in the Windows Firewall allow programs list.
I have Googled like crazy on this issue and tried several solutions with no long term success.
The weird thing is that it should cut off the streaming when I turn the firewall back on but it doesn't.
hugh is offline
Old 2010-12-09, 12:34 PM   #5
stampeder
Hmmm... it seems to cut off only the initiation of the stream... (?)
Old 2010-12-18, 02:00 PM   #6
hugh
For anyone reading this.
My advice.
Uninstall and then install Bonjour. It seems to fix the issue.
hugh is offline
Old 2010-12-18, 04:54 PM   #7
99semaj
Airport Express firmware update was released yesterday; don't know if that's material in your issue or not.
99semaj is online now
