Watching recordings on PVR without an active Rogers account - Canadian TV, Computing and Home Theatre Forums
Old 2010-12-08, 05:40 PM   #1
arcin
Default Watching recordings on PVR without an active Rogers account
Hi,
If I cancel my subscription with Rogers, and want to watch the recordings on my PVR (8300) (I own the unit btw), will i be able to do that? Or will the unit communicate with Rogers and completely disable the unit?
arcin is offline
Old 2010-12-08, 05:44 PM   #2
The unit will function/boot for a while (not sure how long) without a connection to the cable (do not connect it after you cancel). If there's anything on there you want to keep long term, copy it to DVD recorder or HTPC. If you're not planning to go back to Rogers, sell it.
57 is offline
Old 2010-12-30, 09:45 AM   #3
ladybugg1629
This should work:
http://www.digitalhome.ca/forum/show...6&postcount=49
ladybugg1629 is offline
Old 2011-01-12, 02:20 PM   #4
mdej
With my 8300 all I did was unplug it in one room and move it to the other room (no cable connection). Connect to the TV and power, powered it on and I got a message saying something like "you can watch while disconnected". I was able to access my recorded list as normal.
mdej is offline
