Hauppauge Colossus HD-PVR - Page 7 - Canadian TV, Computing and Home Theatre Forums
Old 2012-06-08, 09:15 PM   #91
birdguy
If you can manage with the Hauppauge pre-learned IR codes, their blaster is okay. If not, good luck because it sucks at learning new codes.
An alternative: order a Windows Media Center remote and transceiver (HP OEM) on ebay, about $25 from China. Download the IR Server Suite from the MediaPortal forum. Teach it the codes and write a script for channel changes. Examples are provided with the software.
Should work with MediaPortal, NextPVR and with Media Center if you use the Colossus Bridge for DVBLink from 1geek1tool.
birdguy is offline
Old 2012-06-09, 06:27 PM   #92
nickia
I bought one from Canada computers and the quality is quite good so far. I'm capturing 720p of Xbox 360 gameplays to upload to Youtube. The one I had was open box so an extra 10% OFF.
nickia is offline
Old 2012-06-18, 03:03 PM   #93
pdub11
Thanks for the response. I had to take a break from it for a bit.
I have a Antec HTPC case that comes with a remote so I will look into getting the IR server suite to work.
pdub11 is offline
Old 2012-07-09, 04:37 PM   #94
pdub11
I eventually got a 4250 cable box, installed the drivers and firestb.msi.
When I plug in the 4250 into the PC it is recognized as shown below under device manager:
-Imaging devices
- Scientific Atlanta AV/C Panel Device (Explorer 4250HD)
- Scientific Atlanta AV/C Tuner Device (Explorer 4250HD)
- Unknown IEEE 1394\5068 Device
- Unknown IEEE 1394\989 Device
But I am unable to change the channel using channel.exe. Below is the output:
Any ideas?
C:\Program Files\Timmmoore\MCE 2005 STB Controller>channel -v
Firewire STB channel changer V1.0.15, by timmmoore
1 "FireBus MPEG2TS Tuner Subunit Device"
'Scientific-Atlanta AV/C Tuner Device'
"@device:pnp:\\?\avc#scientific-atlanta__inc.&explorer(r)_4300&typ_5&id_0#daca2c
3a2200#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global" 0
2 "AVC Panel Device"
'Scientific-Atlanta AV/C Panel Device'
UniqueID 'daca2c3a2200'
VendorID '223a'
ModelID '10cc'
VendorText 'Scientific-Atlanta Inc.'
ModelText 'Explorer(R) 4300'
"@device:pnp:\\?\avc#scientific-atlanta__inc.&explorer(r)_4300&typ_9&id_0#daca2c
Calling CoUninitialize
Called CoUninitialize
C:\Program Files\Timmmoore\MCE 2005 STB Controller>channel -v 2 30
Device 2 Channel 30 Timeout 100 Dec 0
VendorID '223a'
ModelID '10cc'
This device is not supported, if you are sure then add the -f flag
pdub11 is offline
Old 2012-07-09, 10:36 PM   #95
pdub11
I was eventually able to get it to work with the sagechanger.exe from the link Wayne provided.
Thank You,
pdub11 is offline
Old 2012-07-15, 09:19 PM   #96
riffer
Use the Scientific-Atlanta 8300HD setting for the Cisco 4642HD.
riffer is offline
Old 2012-07-15, 09:22 PM   #97
riffer
Now for my own question. I can't get the WinTV remote to work. Hauppauge even sent me a replacement remote and cable and still no joy. Has anyone had the same problem and could recommend some troubleshooting tips? (Already cleaned out the drivers and reinstalled).
riffer is offline
Old 2012-09-24, 01:06 PM   #98
nambi
Default IR Blaster with Expressvu 6131
I purchased a Colossus with hopes to broadcast my expressvu to multiple locations / remote locations. It works OK.
As for a PVR I'm so used to the 6131 that this setup is cumbersome and feels a bit archaic but it does work. I'm not really using it for the PVR function but I want to access my BELL PVR broadcast it with the ability to Fast Forward through commercials. Now my main issue here is the IR blaster.
1 I need to put in all the channels manually, or put in a range, which to make things simple I did 200 - 1600
now upon testing I went to the weather network which is interactive (I'm doing this remotely) now I'm stuck on the interactive channel and can't remotely turn off the receiver or exist out. More importantly I want to go into my PVR select a recording watch it and have he option of FF through commercials. The IR blaster seems limited can i do this? if I access my TV via http I only have the options of pausing or stopping. How can I achieve this?
nambi is offline
Old 2013-04-20, 07:40 PM   #99
DCor
Location: Barrhaven (Ottawa), On. Canada. (3 blocks north of Strandherd Dr. & 2 east of Claridge Dr.)
Default Setup
I"m having issues getting my Colossus working.
Probably something simple with the cables. You may already know that I have many, many in back of the system!
I have a HVR-2250 up and working with OTA, but not via the STB.
Have the HTPC HDMI'd out to the TV, and audio coax'd out to the amp.
The STB is component & optical to the Colossus, and then out to the TV again with component cables & optical to the amp via the pass through port.
DCor is offline
Old 2013-04-20, 11:20 PM   #100
riffer
Some STB's don't allow you to use the HDMI and component outputs at the same time. Disconnect the HDMI and see if the Colossus works.
riffer is offline
