What to look for in a Blu-ray player (At FS) - Canadian TV, Computing and Home Theatre Forums
Old 2010-11-26, 11:53 AM   #1
lastyear4gt
Default What to look for in a Blu-ray player (At FS)
Ok so I did everything I could to rectify the problem with my BD player with no success. I took it to futureshop because I had the extended warranty and it looks like I may just be given a credit and told to buy another unit. So what should I look for now? What's decent? I have had bad luck with samsung first my tv and now my bd. Maybe a 3D blu-ray? Any Other features I should look for? Brand name? I'll have about $350 to spend.
lastyear4gt is offline
Old 2010-11-26, 12:23 PM   #2
jvincent
My two cents, look for the best load time.
For BD playback there should be no difference in PQ between any of the units. Assumption here is that you have any effect modes turned off and the player does not mess with the signal in any way.
Android rocks!
jvincent is online now
Old 2010-11-26, 12:27 PM   #3
If you have a lot of (regular) DVDs that you wish to play on the BD player, some players are better at upconversion than others and the quality of upconversion doesn't appear to be price-related either. Once you have your eye on a particular unit or two, check out the internet reviews and also search for the model numbers here to see what people say.
57 is offline
Old 2010-11-26, 02:21 PM   #4
hugh
Consider whether you want a 3D capable one or not.
Sony PS3 is a bit loud and DVD upscaling is good but not the best, however, it is fast, has stellar Blu-ray playback and is 3D capable. Lots of threads discussing around here.
hugh is offline
Old 2010-12-17, 09:17 PM   #5
lastyear4gt
OK, Future Shop called me today, they put a part in my BD but it still had the same problem. I have to come in and choose a replacement. This is now the second samsung products in the same amount of years I have had go on me (a TV and now the BD player). I am a little gun shy to get another one but they seem to offer the most amount of features.
Can you tell me what you are using, or what brands seem to be better. Unfortunately I am limited to the players that Futureshop carries.
DVD playback, nextflix streaming are important.
I am thinking at this point in time I might as well go 3D. However, does 3D work with a projector?
Old 2010-12-17, 11:43 PM   #6
cdn_tbird
Personally, based on my experiences with Samsung's service dept. I'll NEVER buy another Samsung product again. You're gun shy for a very good reason.
I purchased the Sony BDP-S570 earlier this year and couldn't be happier. Great load times, no complaints about how it handles my extensive DVD library, and it will do Netflix streaming.
Samsung FP-T5084; Yamaha RXV1400; Sony BDP-S570 & SS-X speakers; SA 4250HD; JVC SVCR (STILL ticking), Panny TH42PZ800.
cdn_tbird is offline
Old 2010-12-18, 01:38 PM   #7
cooper83
If your budget is still $350, I'd spend that on a PS3 as hugh already suggested.
If you want to save a bit of cash, I like cdn_tbird's suggestion of the Sony BDP-S570.
Panasonic TH-42PE7U plasma, Toshiba HD-D3, PS3, Shaw DCX3400, Yamaha HTR-6160, Polk 6.1, Belkin PF30, Harmony 700
cooper83 is offline
Old 2010-12-18, 09:55 PM   #8
lastyear4gt
So is the PS3 blu-ray package basically what you would find in any of their other purpose specific players?
Old 2010-12-20, 05:41 AM   #9
lastyear4gt
One more question and I will make my decision. Would the PS3 make a good enough blu-ray player for a purpose built home theater or do you think a stand alone unit would be the better way to go? Sorry 2 questions. Does the PS3 do 7.1 surround that is decoded by most AVRs out now?
Thanks for your help everyone! I have to make a decision tonight.
Old 2010-12-20, 08:06 AM   #10
hugh
PS3 will do anything other players will do except it does not have an IR remote so you can't use it with a universal remote like Harmony UNLESS you buy an adapter. Discussed on other threads so search if you are interested.
hugh is offline
Old 2010-12-20, 10:13 AM   #11
The PS3 can handle 7.1 audio, however, remember that there are two PS3s. There's the old "fat" PS3 that must do the decoding and send LPCM out the HDMI connection and then there's the new PS3 Slim which sends bitstream HD audio out the HDMI for the AVR to decode.
http://www.digitalhome.ca/forum/showthread.php?t=76082
See the section near the end of the AVR features. If you wish to use an IR remote dongle for the PS3, search this forum for "IR4PS3" or IR2BT, or IR4BT, etc.
57 is offline
Old 2010-12-20, 10:37 AM   #12
scampbell
If you buy a PS3, you might also want to get a PS3 Bluray remote, which works much like a regular remote, rather than using the standard PS3 controller. They are not very expensive.
scampbell is offline
Old 2010-12-20, 12:50 PM   #13
cooper83
scampbell, this is what hugh & 57 are referring to. Logitech also makes an adapter for their Harmony remotes. Discussed in other threads.
cooper83 is offline
Old 2010-12-20, 01:06 PM   #14
expressmoria
I do not recommend anyone pay more than $100 for a new blu ray player.
Choose a brand name (Sony, LG, Toshiba etc.) and do not waste your money on no-name brands offered from the various retailers.
Next year prices for regular blu ray players will be less than $100 with the 3D players become cheaper to own.
expressmoria is offline
Old 2010-12-20, 01:07 PM   #15
cooper83: scampbell was referring to the Bluetooth (not Bluray) remote that you can purchase for the PS3 for about $20-30.
expressmoria: Although the PQ from any BD player is going to be the same, whether you spend $100 or $500, the upconversion of DVDs and various audio options available from various players - often more expensive - may make it worthwhile to purchase something "better" depending on a person's specific needs. Some players also have more/different features and are faster to boot, change chapters, etc.
The OP also has $350 to spend, but I suppose he could purchase other items to make up the difference...
57 is offline
