PDF Download instead of in Tab/window in Firefox - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Computing > Apple Computing
Old 2010-11-16, 08:03 PM   #1
Default PDF Download instead of in Tab/window in Firefox
I had my old version of FF set up so that when I clicked on a pdf or similar link the item would be downloaded to my desktop. I prefer things this way rather than viewing pdfs in the browser.
Now with FF5.0 on OS 10.5, it tries to open in a new tab/window, or sometimes doesn't open. I can't find the setting to change this under preferences, whatever.
I can get it to download by right-clicking on the link, but sometimes I don't know that the link is a pdf and it sends me to a new window and I have to backtrack, etc.
Is there a setting I'm missing? I found it 6 years ago when I got this computer, but I can't find it now after I updated the computer OS/browser...
57 is offline
Old 2010-11-16, 08:33 PM   #2
jvincent
If you put "about:plugins" in the URL bar, minus the quotes, it should tell you name/location of the plugin.
Delete it and you should be OK.
In Chrome, you can disable them from the "about" page, which is a nice feature.
Android rocks!
jvincent is online now
Old 2010-11-16, 08:51 PM   #3
romulus
If you use Adobe Reader for PDF's, under Edit-Preferences-Internet,
there is an option to Display(or not) PDF in the Browser.
Sharp LC40E77UN, SONY STR-DE685 AVR
SA8300HD PVR, Pioneer DVR-543HS DVDR
romulus is online now
Old 2010-11-16, 11:34 PM   #4
Thanks romulus, that did the trick. It was under Adobe Reader-preferences, not Edit-preferences, but easy to find. The preferences may be in a different spot for various versions or Mac versions.
I believe these sorts of settings used to be under Internet Explorer and if I made the changes there, they would somehow be transferred to Safari and FF, but not this time.
Appreciate the help - saves me a few extra clicks.
I also noted that you can have the file open automatically after downloading, saving another step if desired.
jvincent Thank you also, I decided to go with romulus' suggestion. In FF there's also an option under "preferences" to manage add-ons, plugins, etc, but I didn't wish to delete.
57 is offline
