Looking for some guidance on a speaker package to hook up to a Yamaha HTR4063/RXV467 (same machine different stores), I have decided on the Yamaha since the reviews are half decent I was considering the Denon AV-591 (I'm a current Denon "stereo" Customer...don't laugh)but there seems to be issues of setup and learning curve on the 591. I can get the Yahama for about $400 at FS.
My budget is around $400-500 for the speaker package and I have been looking at the Klipsch HD Theater 300 as a possibility. Currently on sale at FS for $300. But I'm also looking at just buying a Yamaha HTIB YHTB4670 which contains the RXV467 for the same combined price ($700) as above instead of separate pieces. I know you guys don't like HTIB, and would appreciate any guidance you can give me for a $700-800 budget for receiver and speaker package. |
have you considered buying used? Do you have a deadline in mind? With Boxing Day just over a month away, you may be able to find a better deal.
DHC Supporter
sorry guys, perhaps this should be in the deals section. simply indicating to the OP, there are very good buys available.
the Denon AVR 890 is on final clearance for $ 499 @ FS. sold out online, maybe still available at your local store (as is the case in my area). check it out. PSB Alpha, Polk RTiA1 speaker systems should be on your list too, i think they may be within your budget. buying used is an option i agree on with Blue11, buying used from classified such as Canuck Audio Mart (CAM) is a great way to save on very good HT-stereo gear. |
Thanks for the quick replies guys. As you will see I am a rookie to the forum, so if I posted to the wrong thread please forgive me.
I will check the Denon AV-891 at my local FS to see if it is available. I assume by your recomondation this is a product worth looking at. I will also research the PSB Alpha, Polk RTiA1 speaker systems. Lastly I would consider used on the receiver, but not the speakers. I will have a look at CAM to get an idea of pricing. My timeline is not urgent, but was being driven by the prices I was seeing at FS for the items mentioned. |
DHC Supporter
Denon AVR 890 (not the 891). FS website offers a feature allowing users to check in store inventory from home.
I assume this web feature is reliable, current etc Best Buy probably carries denon too, same scenerio re: clearance The 890's msrp was $ 899 - $ 999 (min) regardless, this thread should be focused on speaker packages, seems i have sidetracked alittle. other's (including myself) can lend a hand re: your AVR also, in the A/V Receivers and Amplifiers forum. keep checking back with questions if you like |
If time isn't a big issue, check out other stores for deals during Christmas. A few years ago I got an incredible deal on the receiver and speaker set up for about the same price you are looking to spend. the speakers were the Paradigm Cinema 110 package.
I would also advise you to listen to your options before making a decision. When I was looking for a set up a few years ago I listened to the Polk RM series, Energy Take 5 and C-50, Klipsch HD, PSB LCR, and Paradigm Cinema 110. Overall I enjoyed the Paradigm set up best. And it came with a 10"sub (one of the few from the ones I auditioned that did). |
DHC Supporter
i had the paradigm cinema 110's and the 220's. decent enough, i liked them, but plastic containment didn't do it for me ultimately, verses the acoustic properties of wood housing. having moved to studio series however, there's no comparison.
keep an eye out for deals on RTi series (RTiA1's for example) .. PSB Alpha's ... Mini Threatre or Studio Threatre .. (i was thinking primarily the PSB B1 Monitors) .. i do think both are out of your budget currently for surround packages, but that could change. FS really blow out select speakers during boxing week. (i STILL think i should have bought those RTiA10's for the ridiculous low price @ the time) I just think that the above mentioned are quite better for reasonable more $$ .. than the $ 399 packages. i would rather pay $ 600 - $ 700 for very good .. than $ 399 for marginal. dampen that .."what if" factor somewhat anyways. |
Thanks again for the advise guys, I think I will listen to every option I can before buying.
One last question, I just found a Polk RM6750 package, paired with a Yamaha HTR4630. The normal price for the RM pacjake is $599, but paired with the 4630 they are selling at $699 total. So basically they are throwing in the HTR for $100. Any thoughts on this speaker package? |
#9 | |
If you already had a good knowledge of speaker products, online purchase could provide substantial savings IE: "newegg dot ca" comes to mind. When talking about Polk RTiA, IMO the Monitor series offers a better bang for the buck. Quite comparable SQ wise but you can get a better performer in the Monitor series for the same dollards spent. |
#10 | |
DHC Supporter
#11 | |
For music listening, the M70s can be used without sub back-up which I much prefer for music. |
#12 |
TECHNOKID,
You bring up a great possibility for me... If I was to reuse my Celestion Ditton 33's (in excellent condition) as the front's, and a pair of M40 II's (in the nice cherry finish that would match the 33's finish) for the rears would that be enough, or would I still need a Center and a sub? The Ditton 33's have fanastic base anyway? |
#13 | ||
