Do Bell PVR's Support USB 3 External Hard Drives? - Canadian TV, Computing and Home Theatre Forums
Old 2010-10-23, 06:08 PM   #1
Quivox
Default Do Bell PVR's Support USB 3 External Hard Drives?
Do any of the Bell PVR's support USB3? I noticed in the latest Bestbuy flyer they are advertising the increased transfer rate using USB 3 external hard drives. The example they used was 3 minutes to transfer a 2 hour HD movie vs 15 minutes fro a USB 2 hard drive.
Quivox is offline
Old 2010-10-23, 07:24 PM   #2
Pinza
I would highly doubt it, surely this would need a new software update from Bell at the very least, if indeed this is even possible via software.
Pinza is online now
Old 2010-10-25, 08:46 PM   #3
jhawken
USB 3.0 is fully backwards compatible to USB 2.0.
However the bell boxes, only have USB 2.0 support, so you will not gain any performance with a USB 3.0 drive.
jhawken is offline
Old 2010-10-30, 01:18 PM   #4
angus.black
The Bell receiver would require a USB controller chip replacement in addition to the firmware update to run at USB3 speeds.
angus.black is offline
Old 2010-10-30, 01:36 PM   #5
dirtroad
I looked at those USB 3.0 drives at BB yesterday, the price is certainly good, but the Hard Drives in them are only 5400 RPM, so even if Bell supported USB 3.0 the drives would be the limiting factor I believe.
USB 2.0 uses half duplex transmission (first one way, then the other), and USB 3.0 bidirectional (both transmit and receive at same time). USB uses 4 extra conductors, which means it would have to be a hardware upgrade, again I believe.
See http://www.everythingusb.com/superspeed-usb.html for details on USB 3.0
If Life is a Highway,...then why is there no end to this dirtroad?
dirtroad is offline
