mpix hd is unwatchable - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Videotron
Old 2010-10-17, 10:56 AM   #1
bradpitt
Default mpix hd is unwatchable
The pixelation on Mpixhd is soo bad, I usually go back to the sd version. I undestand from another forum that this is notdue to limitation of the illico ntwork but it is due to the supplier cramming 3 hd channels into one QM. Let's flood videotron customer service with our disappoint and get them to upgrade their link to the supplier. We deserve better!
bradpitt is offline
Old 2010-10-17, 11:03 AM   #2
I assume you're talking about macroblocking. There is simply no way that the SD version would be better if things are working properly. You may have a signal problem - check your signal strength and S/N ratio. Also, a proper TV optimization will minimize the effects of macroblocking.
http://www.digitalhome.ca/forum/showthread.php?t=17719 SA Tips
http://www.digitalhome.ca/forum/showthread.php?t=76161 Optimization
The "supplier" (Astral) is not cramming 3 channels into one QAM, that is the service provider - in this case Videotron. Videotron have limited bandwidth, hence the use of 3 Ch/QAM for many channels. Your information was incorrect.
http://www.digitalhome.ca/forum/showthread.php?t=57741 Useful Post.
57 is offline
Old 2010-10-18, 12:03 PM   #3
Fulvio
FYI, I've been watching MPIX HD pretty regularly since it started and I have never seen any pixelation. Like 57 said -- you should probably check your system.
Fulvio is offline
Old 2010-10-19, 01:26 PM   #4
joepro
It was my understanding that Videotron gets its TMN (+HBO & MPIX) feed from Rogers. If Rogers overcompresses the signal, it will also look like crap on Videotron.
Panasonic 50GT30 | Yamaha HTR-6063 | Energy Take Classic 5.1 | Oppo BDP-93 | Illico - 8642HD
joepro is offline
Old 2010-10-19, 02:43 PM   #5
bradpitt
Hi 57, thanks for the reply.
It's strange because all my other channels are fine but you may be right.
I was refering to *********.com. On this web papge, there's a table that indicates that there are two HD channels in QAM 72 (ie. Mpix hd at 11.88 mbps and SE2 hd at 17.86).....
The narative (which is in French) goes on the say that MPIXHD AND SPEED HD
have poor quality that varies depending on the movement on the screen. The reason for the poor quality (according to the *********.com) is Videotron receives the signal from a distributer that has already trasncoded the signal to fit 3 hd channels into one QAM.
If Joepro is correct that Videotron receives these services from Rogers, then perhaps it's Rogers that is transcoding.
But I hope you're right 57... especially since nobody else has replied that they also are having issues with MPIXHD.
However, I'll call Videotron tonight and check my sdignal for this channel and I'll let you know.
bradpitt is offline
Old 2010-10-19, 09:36 PM   #6
bradpitt
I called videotron tech support and when they moniter my line, they could see that the signal was very bad on mpixhd ...so they're sending as technicien on friday.
bradpitt is offline
Old 2010-10-19, 11:58 PM   #7
Did you not check the signal yourself as suggested in post 2 and the link(s) provided?
57 is offline
Old 2010-10-26, 05:27 PM   #8
joepro
Were they able to fix it, or are the issues in the source?
joepro is offline
Old 2010-10-27, 12:43 PM   #9
SonyWE610Owner
Lightbulb
I don't think its the source.
MPIX HD is clean as a whistle chez moi.
I've watch several films since we FINALLY got access!
I have Videotron Internet, Phone & TV.
My phone was really noisy for a bit. Turns out it was an internal problem.
So...
SonyWE610Owner is offline
Old 2010-10-27, 01:18 PM   #10
bradpitt
There was a cabling problem at my condo and the videotron technicien resolved the issue. Mpix hd is now clean as a whistle chez moi also. They're rerunning Nashville in hd on Friday morning ...gotta set the PVR for that one.
bradpitt is offline
