#31 | |
OTA is doomed for extinction if it cannot keep up with competing services in terms of picture quality. If 1080 streams have to be sacrificed for lower res just because people want more channels, OTA will quickly fall behind. I am confident that after investing billions into digital transmission gear, broadcasters will not allow this to happen. |
#32 |
Location: Dunnville, Ontario on the Grand River, North shore Lake Erie
Broadcasting in 1080i is wasteful bandwidth use. Some will argue that 720p is better than 1080i. With newer technology on the horizon, it is possible to broadcast full 1080i quality at the same band usage as 720p using current consumer receiving equipment. If you have a 42+ screen size, then you can choose between cable's compromised compressed version of 1080i or you can go free with uncompressed OTA at 720p. I believe that the standard will end up at an enhanced 720p for all OTA anyway and it will be done using only 2 Mbits. Currently there are too many formats and resolutions for broadcasters to juggle with and that's why they are seeking the ultimate standard. Of course the benefit will be capacity for extra subchannels with extra bottom line advertising revenues. In the broadcast business, it's alway about how to make more advertising dollar$ show up on the bottom line.
3D SSH III with ZZ4 refl. http://imageshack.us/user/jmsdigital |
#33 |
There's not a lot of difference in bandwidth between 1080i and 720p. 1080i has 2.25x as many pixels as 720p, but 720p scans twice as often, so 1080i uses only 12.5% more bandwidth for the video. However, other things, such as audio, will be the same for both. |
#34 |
For the foreseeable future the use of OTA bandwidth to achieve a given picture quality cannot be improved. There are hardly any TVs/PVRs with ATSC tuners that support MPEG4 part 10 (H.264) codecs, so we are stuck with MPEG2 and its greater use of bandwidth. The train has left the station. H.264 was added to the ATSC standard only in 2008. No broadcaster will begin to experiment with MPEG4, because nobody can watch it. Things look much better with DVB-T in Europe.
Let's not forget that a good deinterlacer can produce great motion flow before we make arguments like 720p is better than 1080i. High resolution is what blows us away! Further reading: http://www.gizmolovers.com/2008/09/2...e-it-used-soo/ |
#35 |
All sports and action is much better and more crisp in 720p than 1080i, also the higher res is not needed on hdtv's smaller than 42 inches. It should either be 720p or 1080p instead of interlacing HD picture which adds blur and lag. Watch OTA football on a 720p channel vs the 1080i channel and you will see.
#36 |
Some recent national adopters of ATSC in the Americas have opted to go immediately to ATSC Standard A/72, which includes ITU-T H.264 (MPEG-4), so clearly there is a pool of devices that will operate with it. The payoff is the capacity for several 1080p/DTS audio HD sub-channels within one channel's bandwidth, or of course all sorts of other slice-and-dice options for lower grade programming and data.
As I've said before, a Canadian move to MPEG-4 would require consumers to purchase STBs or other external devices while production of HDTVs with the newer system becomes more commonplace. New A/72 devices would be backward compatible with existing A/53 MPEG-2 channels or act simply as downconverters feeding an A/53 signal via HDMI, Component, S-Video, Composite, or RF signal to the consumer's existing gear. Shelling out more $$$ is quite a lot to ask of many people who only just bought an HDTV, OTA STB, or tuner device that uses the original A/53 MPEG-2. We all know that many of the regular addicts here in the OTA Forum would gladly drop more $$$ into their systems if MPEG-4 was rolled out! Last edited by stampeder; 2010-10-19 at 11:11 AM. |
#37 |
I've watched MPEG-4 1080i — not over-the-air but through satellite (experimental PBS feed via Ku-band FTA). The picture quality is atrocious compared to the regular 1080i program encoded in MPEG-2. The MPEG-4 image isn't as crisp, there's more macroblocking, and the sound is different, too.
Would OTA MPEG-4 look/sound just as bad? Or would this depend totally on how individual broadcasters chose to set their MPEG-4 encoders? |
#38 |
Even though they were using MPEG-4 the satellite company's use of the actual H.264 codec was probably not compliant with the ATSC's A/72 implementation. Also once they add their secret encryption sauce the satellite companies can really mess up programming.
#39 | |
#40 | |
#41 | |
#42 |
I would love to see cp24, CBC Newsnetwork, CTV Newsnet, and on the more mindless side, although I assume it highly unlikely, TSN or Muchmusic.
#43 |
In the recent decision allowing Shaw to buy Canwest, the CRTC said - again, after the decision back in 2008 - that it is "pursuaded of the benefits of multiplexing", this time adding that mulitplexing could help with "diversity of voices and access, and [has the] potential to offset some of the negative impact resulting from media consolidation." Not sure exactly what they're talking about, but it certainly raises the possibility of adding community channels and the provincial broadcasters on private stations' subchannels. That would be a good service.
#44 |
How would, for example, french CBC stream english audio track? How many times have I seen something cool on french CBC I wish had an english track...
#45 |
I'm pretty sure the ATSC standard provides for alternate audio on the same channel. Much like SAP in the analog world....
DMX 68' tower, HyGain HAM 5 rotator, Antennas Direct 91-XG & C5, Channel Master 7777 preamp, Siemens surge protection |
