Bell Fibe TV problems and Complaints - Page 21 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Bell Canada Enterprises (BCE) > Bell Fibe TV
Old 2012-06-13, 03:46 PM   #301
nitra
You would need to detail the 'audio glitch', there's been many of them over the years.
If you're talking about the dropout 15-45 seconds after tuning to a channel for 1-2 seconds, this is normal, it doesn't always happen, but it's to do with the swap to the multicast stream.
nitra is offline
Old 2012-06-13, 03:49 PM   #302
Bri in Mtl
Do the Fibe terminals have an external power outlet that can be used to control something like a bias light behind the TV?
You can have the option of having the outlet always on OR have it go on and off with the terminal.
Bri in Mtl is offline
Old 2012-06-13, 04:23 PM   #303
Raceleader
Thanks Nitra for follow up on my issue.
Actually i'm talking about cut in the sound for 1-2 sec that happens on channels and even when listening to recorded stuff on the pvr it does the glitch without warning. Image stay sharp and only sounds cut for 1-2 sec often.
Raceleader is offline
Old 2012-06-15, 11:50 AM   #304
nitra
I take it you're connected with HDMI?
nitra is offline
Old 2012-06-15, 12:05 PM   #305
Raceleader
Indeed Nitra
PVR to TV = HDMI
TV to sound bar = Optical
Old 2012-06-15, 06:49 PM   #306
nitra
Would you mind trying, HDMI to TV, and Optical from PVR to sound bar?
nitra is offline
Old 2012-06-17, 09:07 AM   #307
frankmar
Default Changing channels sound delay
My PVR is connected to my Denon Receiver via HDMI, when I change channels the image comes instantly but the sound is delayed by 1 - 2 seconds.
If I connect my PVR directly to the TV, I have no lag.
My nephew has Fibe tv same connection with Yamaha Receiver and has no lag.
I even upgraded my HDMI cables and no luck.
Anyone has an Idea, to remedy the problem or have the same problem. tia
frankmar is offline
Old 2012-06-17, 06:51 PM   #308
nitra
Do you have upscaling enabled on the Denon?
It sounds like the Denon is taking a second or 2 to start the audio stream, this would only happen if you had upscaling enabled.
nitra is offline
Old 2012-06-17, 08:37 PM   #309
frankmar
I think it upscales automatically, unless there is a place where I can turn it off. But then I lose some quality picture in the SD channels.
frankmar is offline
Old 2012-06-17, 10:49 PM   #310
frankmar
I turned the upscaling off and no change
frankmar is offline
Old 2012-06-18, 07:48 AM   #311
nitra
What model of TV/AVR do you have?
This isn't something to do with FibeTV btw, it's something with the rest of your hardware.
Also, can you try running direct to the TV?
nitra is offline
Old 2012-06-18, 03:21 PM   #312
frankmar
if I connect directly, there's no lag, the model is Denon 1910
frankmar is offline
Old 2012-06-18, 04:46 PM   #313
Dr.Dave
@frankmar, it sounds like your AVR is taking a few seconds to figure out the audio format. Have you tried changing the audio settings on the AVR?
Do you have the PVR set to stereo or surround sound?
Dr.Dave is offline
Old 2012-06-18, 04:58 PM   #314
nitra
Channel to channel, there are sometimes different formats, I have the Denon 3311CI, it doesn't have this issue at all, you might have something enabled that's shifting the sound to Matrix mode, this will cause a delay if I turn it on in mine.
On the remote, you should have a button at the bottom D/ST, press it, see if that helps.
nitra is offline
Old 2012-06-18, 05:54 PM   #315
frankmar
I had my pvr to surround sound, then I changed to stereo and VOILA no more lag.
BUT I lose my 5.1
I tried different setup in the Receiver to get Prologic or Dts 5.1 No dice.
frankmar is offline
